Old October 15th, 2013, 01:51 PM   #1
nitehawk
Motorcycle(s): 2012 Ninja 250 - SE Black & Red
Front Brake Issue
The front rotor on my 250 was warped, so I replaced it and changed the pads while I was at it. Went for a test ride and while it was a million times better I could still feel something subtle when braking. Put the front wheel back up and sure enough it would not spin freely. Catches on one side, and definitely not spinning exactly parallel to the pads/caliper. Something still isn't lined up right. Could the caliper be damaged or the rim? I laid the new rotor on a flat surface before installing to make sure it was good. Didn't see any issue. Pads don't seem to be pushing out and leaving any run out.
The bike has been down at about 15-20 mph earlier this year. There are some scratches on the rim, but the shop said it was nothing wrong with it. Didn't give me any problems until few thousand miles later after I had to replace the pads. At some point after that it started showing signs of warping.
Whats the most likely culprit?
nitehawk is offline   Reply With Quote
Old October 15th, 2013, 02:14 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
If your forks are tweaked then it could cause your brakes to drag but if that was the case I'd think you'd no twice your bars not being strait. When you swapped the pads and rotors did you give the caliper its much needed cleaning and some Fresh grease in those slider boots to make sure its all moving freely?
Old October 15th, 2013, 03:44 PM   #3
nitehawk
At one point the stem nut (or bolt, whatever the top one is called) did loosen up. Tightened it up and nothing looked crooked, but I probably could have taken a better look. If so what do I need to do to straighten it all out?
Didn't think about needing to grease the caliper. Makes sense. Any particular type of grease?
Old October 15th, 2013, 06:48 PM   #4
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Ideally, you want something high temp. But unless you take it to the track, cheap wheel bearing grease is fine.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old October 15th, 2013, 09:37 PM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
yeah regular grease will be fine and you should have pumped out the caliper pistons and scrubbed them with some 409 and a tooth brush. then you blow them dry and lube them with a little brake fluid and work the pistons in and out till them move freely. I showed @tfkrocks hoe this was done on her rear caliper that was totally ****ed so she can vouch for how much of an improvement it was.
Old October 15th, 2013, 09:40 PM   #6
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Lol yes and after changing the messed up pads I actually have rear brakes now.
Front Brake Cable issue w/ Driven Clip-ons Sirena 2013 - 2017 Ninja 300 Tech Talk 9 April 2nd, 2015 11:08 AM
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
front brake issue gantt 2008 - 2012 Ninja 250R Tech Talk 15 July 13th, 2014 11:39 AM
Front brake issue. Myst420 2008 - 2012 Ninja 250R Tech Talk 1 May 17th, 2010 01:34 PM
