Old May 16th, 2014, 08:30 PM   #1
bucky242
Motorcycle(s): 2000 ninja 250
Battery cable bolts and rectangle nut what size and where to find them?
I searched for this on the forum couldn't find anything.
I need/ really want the stock bolt and rectangle nuts that hold the battery cables to the battery.
Where can I find these? and/or What size are they?
bucky242 is offline   Reply With Quote
Old May 16th, 2014, 09:28 PM   #2
http://faq.ninja250.org/wiki/What_ki...hould_I_use%3F
Originally Posted by ninja250.org
If you strip anything on your battery, or lose the terminal nut, the only way you can fix this is by buying a new battery, unless you do one of the following:
1. Go to a dealer or battery store and see if they have any spare nuts lying around.
2. When you buy a new battery, keep the nuts from the old one.
3. Buy a regular nut at the hardware store. Hold onto it with needle nose pliers and grind it down on 2 opposite sides with a dremel.
I should have saved mine from my last battery.
You can probably ask an auto parts store if you can salvage one off their traded-in batteries. Most were willing to hep me dig through for an Exide vent cap from my OEM Toyota Corolla battery when mine went missing, though I never found a match.
Old May 16th, 2014, 09:46 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Or you can get a 6-32 screw and nut and grind two of the flats on the nut to fit in the battery terminal. No big deal.
Old May 18th, 2014, 12:17 PM   #4
bucky242
Ended up cutting and grinding some bolts and nuts to fit.
Clutch cable adjuster nut sparky80 Items Wanted 1 January 25th, 2015 12:34 PM
Clutch cable length and bead size? Insane Pie 2008 - 2012 Ninja 250R Tech Talk 1 December 15th, 2014 08:58 AM
Battery size Sailariel 2008 - 2012 Ninja 250R Tech Talk 18 July 1st, 2014 07:25 AM
Find Jackets by size? nickjpass Motorcycle Gear 19 December 20th, 2011 01:44 PM
Engine mount nut size? FlamingYellowInsanity 1986 - 2007 Ninja 250R Tech Talk 3 February 16th, 2010 02:21 AM
