Old May 5th, 2009, 09:39 PM   #1
PinkNinja81
PinkNinja81's Avatar
Motorcycle(s): Soon to be a Ninja 250!
Is lowering a bike safe?
Hi everyone, so I just got my very first bike!! yay! I'm 5'1" and I can put my left foot down flat, however the bike has to lean as far over as it would if it was on the kickstand. I already dropped it yesterday after having it for only one hour! heartbreaking it was!
I've been told I can have it lowered which I know would give me more confidence, but I've also heard lowering it can cause problems, has anyone had experience with this? I'd greatly appreciate any advice!
Thanks!
PinkNinja81 is offline   Reply With Quote
Old May 5th, 2009, 09:51 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
http://www.ninjette.org/forums/showthread.php?t=18193
I was a participant in this thread a little while ago. I may have been wrong on pretty much everything I said, but I learned from it. I hope it answers your question.
Oh, by the way, welcome to the board. Make sure to head over to the new member's forum and tell us a little about yourself.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old May 6th, 2009, 07:35 AM   #3
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
If you go to other forums, they make it sound like you are signing a death warrant. I lowered both the front and rear 1 inch (I'm only 5'2") and the bike doesn't feel any different handling wise. I DO feel more confident having my feet on the ground when I stop. That was my, and I'm guessing your, issue. The only thing you may have to do is adjust the preload on the rear shock if you know you will be taking big bumps. I haven't had my bike bottom out yet, so I haven't adjusted mine.
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old May 6th, 2009, 10:26 AM   #4
Apex
Livin' the Minimoto Life
Apex's Avatar
I haven't looked into lowering a bike, since I have a 34" inseam, I normally have no issues reaching the ground.
I know you have to be careful about how you lower vehicles. In my old Mustang, I swapped to Steeda Springs all the way around. I learned real quick that I was needing to upgrade my shocks because the lowered suspension altered the shock throw. This started to cause the shock to age prematurely and occasionally bottom out before the suspension did.
I am not saying the 250 would have this issue, but it is something to be aware of. Needless to say, I do not suggest cutting a spring in order to lower it since the spring rate would not be able to handle the forces any longer. Smaller, stiffer springs would work. I suggest new springs all the way around, new rear shock and new fork oil.
I will be looking into new suspension if I decide to make this bike a track bike. I at least need to upgrade the front end to reduce the diving effect (maybe new oil would do that).
Just make sure you lower it both in the front and back. If you just do one side and not the other, you can seriously alter the handling characteristics of the bike in a very negative way.
Old May 6th, 2009, 10:46 AM   #5
lower it an inch... you'll be fine.
Old May 6th, 2009, 02:53 PM   #6
girlygirl69
girlygirl69's Avatar
im 4'10" and mine is lowered and its much better.
girlygirl69 is offline   Reply With Quote
Old May 6th, 2009, 04:01 PM   #7
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I am also much more confident with mine lowered - I even did a DIY for it Just be sure that you lower the front and the rear at the same time to keep the geometry as close to the same as possible.
Old May 6th, 2009, 04:10 PM   #8
ManyCavies
ManyCavies's Avatar
Motorcycle(s): . . . . . . . 2000 Suzuki Intruder VS800 "Suzi", 2008 Kawasaki Ninja EX250 "Yoshi"
Welcome My bike is lowered an inch.
GO GREEN!!
GOT MY PINK ON!!
ManyCavies is offline   Reply With Quote
Old May 6th, 2009, 06:15 PM   #9
Daeldren
two wheel addict
Daeldren's Avatar
Motorcycle(s): 94 xlh 883, 1984 kawi gpz money pit
Personally I believe in leaving the stock height on sport bikes due to the fact that you do effect the performance by lowering it. 1" like everyone said, is the general rule without effecting the handling too much. However keep in mind that Im 5'2" and I was riding a stock R6S without problems except for backing it up, I usually just hopped off and pushed it back. I'm surprised that you would need to do that to a 250 though as I can almost flat foot it at my height with my boots on plus its a light bike and is not that hard to keep stable with one foot. But if it makes you feel more comfortable then I agree don't go anymore than an inch.
Daeldren is offline   Reply With Quote
Old May 6th, 2009, 06:16 PM   #10
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Ya, but you dropped it at least once, Ken.
Old May 6th, 2009, 06:47 PM   #11
Daeldren
two wheel addict
Daeldren's Avatar
Hey, it was still rideable
Old May 7th, 2009, 05:55 AM   #12
zail
zail's Avatar
Motorcycle(s): 08 Ninja 250r
Hi there! I'm 5' and manage my ninja unlowered with the preload on lowest setting (I only ever get the ball of my foot down on one side but hey!... Other vertically challenged people I know swear by Daytona Ladystar boots which have a built up sole and may provide a good solution for you? Don't know if you can get thet model in the US but I'm sure there must be something similar? However, I would advise you to try before you buy as they tend to be expensive and although a lot of people I know like them I have never got on with them as they won't fit under the gearshift well (although I could get it altered) and they reduce the sensitivity in my feet as the soles are so thick!
zail is offline   Reply With Quote
lowering my bike lowdown112 1986 - 2007 Ninja 250R Tech Talk 2 May 25th, 2013 08:18 PM
lowering the bike question...but i have an EX500 spring rabies 1986 - 2007 Ninja 250R Tech Talk 5 September 8th, 2012 06:42 PM
A nice safe way to stay in touch while on the bike codestp202 General Motorcycling Discussion 37 August 11th, 2012 04:16 PM
Lowering a bike further with 16' rims??? snowlife 2008 - 2012 Ninja 250R Tech Talk 23 June 3rd, 2009 03:48 PM
[motorcycle.com] - Safe riding being promoted at Bike Week Ninjette Newsbot Motorcycling News 0 March 2nd, 2009 07:20 PM
