Old October 19th, 2014, 03:46 PM   #1
TDMX595
Motorcycle(s): 2002 Yellow EX250 F16
Question Brake Light Issue/Front Master Rebuild?
So I've lurked on here for a while, but am just now joining the board because I could use some advice from more experienced people. I've searched the forum but I haven't seen *this* particular issue on here.
My rear brake light is currently always on. I know exactly why it's always on. It's because the front master cylinder is not pushing the brake handle out far enough to turn the switch off. Pictures can be supplied if needed. I'm not sure how long it's been doing this, but I just noticed it. I'm thinking that maybe I need to rebuild the front master cylinder? Should I just buy a used one off of ebay? My other thought was just machining a little brass shim to fix the problem.
Any comments, ideas, thoughts?
TDMX595 is offline   Reply With Quote
Old October 20th, 2014, 06:48 AM   #2
TDMX595
Now with pictures.
This is the problem:
How it should be:
Where the brake handle sits on the plunger:
Where the brake handle should sit:
Last futzed with by TDMX595; October 20th, 2014 at 07:16 AM. Reason: picture size
Old October 22nd, 2014, 10:20 PM   #3
PHMCS
Phoenix Salvage
Motorcycle(s): 2007 Ninja 250R
It may be an issue with the brake switch. Normally when you press lightly on the brake lever you can hear the spring move and the switch activate. If you aren't hearing that, you might want to check there first. also if there is any crash damage (bends and whatnot) in the lever or the perch, there may be a lack of clearance that isn't allowing the lever to move its full stroke.
In regards to the master cylinder, are you having issues with fluid leaks, or spongy braking/poor performance?
See my current inventory of used parts for sale here
PHMCS is offline   Reply With Quote
Old October 23rd, 2014, 06:39 PM   #4
TDMX595
Thank you for replying! It was lonely in here.
The brake switch is working wonderfully. When the switch is depressed, the brake light goes off. My problem is that the switch is always activated.
There was crash damage on that side, but I've replaced the bar and the lever and you'd never know there was. I recall it working correctly when I replaced everything. I'm not sure when this started. There's plenty of clearance, I can move the lever back and forth no problem.
I have no fluid leaks, spongy braking, or poor performance. The brakes work great! The reason I think I need the cylinder rebuild is that the cylindrical piston that the brake lever compresses when pulled is not returning to the correct position when I let go of the brake lever. This results in the brake lever sitting so that it doesn't compress the switch and thus my brake light doesn't go off. I can push the brake lever out with my hand and it turns the switch off, but that doesn't pull the cylinder out of master. Unfortunately when uncompressed the master cylinder doesn't naturally sit in the correct position anymore. This is why I think I need a new one or a rebuild.
My current plan is to buy a rebuild kit and rebuild the front master cylinder to see if that fixes the problem. While I'm at it I'm going to install stainless steel brake lines and new pads. (Since I'll be bleeding the system anyway.) Thus I'm waiting till I get paid again.
I'll post up the results of my efforts when I'm done in case anyone else ever has this problem.
Old October 23rd, 2014, 06:40 PM   #5
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Standard case of blinker fluid leak.
Mods: Offset clutch pressure plate
Old October 24th, 2014, 05:23 PM   #6
Desmoluci
Threadkiller
Desmoluci's Avatar
Motorcycle(s): Yellow '04 stocker, '89 FJ1200, '87 Ducati Paso, '71 Yamaha XS1b, '99 KLR650, '81 FXE 80, '97 KTM 200EXC , etc
Have you tried spraying a little WD-40 on it?
Advantages are taken, not handed out.
MSF 138637
Desmoluci is offline   Reply With Quote
Front brake master cylinder ninjagaiden09 2008 - 2012 Ninja 250R Tech Talk 7 April 22nd, 2014 08:51 AM
Front brake master cylinder piston size old3 General Motorcycling Discussion 3 November 16th, 2012 03:39 PM
front brake issues. master cylinder? Solunatic 1986 - 2007 Ninja 250R Tech Talk 13 June 25th, 2012 11:34 AM
