Old February 17th, 2010, 02:52 PM   #81
jesus... it's not like our bikes have the power to rip the bars out of your hands if you give it too much throttle.
try the mod... I think you'll like it. start w/ one zip tie and if you think you need more, try and add another later. there have been instances where there was not enough room for 2 ties w/o binding.
it's all about personal preference. for me, I wanted to be able to go from closed to full open throttle w/o having to regrip or pregrip. How much precision you have over it is directly proportional to the amount of gray matter between your ears.
with that said, I just went to a slower throttle on my trials bike this weekend to gain more slow speed throttle precision because that bike does have the power to rip the bars out of my hands.
Old February 17th, 2010, 03:08 PM   #82
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Just out of curiosity, any other bikes out there (aside from R1/R6) that have a 1/5 or more aggressive throttle? Specifically, are the 2009+ ZX6R's 1/5? I think the 6R's would fit in ours with the same grip and everything. Might be a better option than the Yamahas.
Betlog is offline   Reply With Quote
Old February 17th, 2010, 09:14 PM   #83
Zim
Motorcycle(s): '04 EX250F
The R6 tube already slips on and costs $10 on eBay. No need to reinvent the wheel, IMO.
Posted via Mobile Device
Zim is offline   Reply With Quote
Old February 18th, 2010, 12:58 AM   #84
null0
Motorcycle(s): Ninja 250 F17
What year R6?
'03 w/ full muzzy exhaust - Racetech .80 springs/emulators - Galfer SS Lines - EBC HH pads - Uni 6" Dual Stage Pods - 110 Dynojet jets - Uni crankcase breather - EX500 adjustable levers
null0 is offline   Reply With Quote
Old February 18th, 2010, 11:46 AM   #85
Zim
Originally Posted by null0 View Post
What year R6?
http://www.rcramer.com/bikes/ex250/throttle.html
Old February 23rd, 2010, 06:00 AM   #86
caliente103
caliente103's Avatar
Motorcycle(s): Red 08 250r
I live in NYC I need this mod now R6 throttle tube or The BRG 1/5th Turn Throttle Adapter?
caliente103 is offline   Reply With Quote
Old February 23rd, 2010, 06:05 AM   #87
caliente103
I think r6 throttle tube Yamaha part number is 5SL-26240-01-00 for $8
Old April 7th, 2010, 12:49 PM   #88
caliente103
I did the r6 swap works a little better then stock go's right on needs no mods:-)
Old April 22nd, 2010, 06:38 AM   #89
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
I had a problem with the R6 mod. It took up so much slack out of the cable that I couldn't adjust it back down against the idle adjuster stop. I would need a longer inner cable to make it work on my pre gen. I loved the way the quick twist felt though and would use it in a second if I could make it work.
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old April 22nd, 2010, 11:15 AM   #90
did you try adjusting the cables at the carb end, too?
Old April 22nd, 2010, 04:04 PM   #91
caliente103
that's funny I had know problems
Old April 22nd, 2010, 04:54 PM   #92
drstimpy
two wheels good
drstimpy's Avatar
went full slack on both ends and still had 3 or 4 mm of distance to idle set stop. I suppose I could cut off a little housing to shorten that length and increase relative length of cable but I don't know if the shorter cable would bind more. hate for the fix to be the start of another adventure...
Old April 22nd, 2010, 06:57 PM   #93
caliente103
That may work
Old April 22nd, 2010, 07:33 PM   #94
I wouldn't. I had issues with a quick tube that I purchased and it didn't fit correctly out of the box. Unless you don't mind replacing parts that you need to hack up to get things to work, I would advise against trying to modify the throttle to get the tube to work.
Old April 22nd, 2010, 07:48 PM   #95
Momaru
Momaru's Avatar
any chance the throttle cable routing is nonstandard, creating a longer path to travel eating up your slack?
Proud member of the Blue Army
Old April 22nd, 2010, 08:05 PM   #96
the routing would not make a difference.
Old April 23rd, 2010, 03:39 AM   #97
drstimpy
two wheels good
drstimpy's Avatar
Question
I wouldn't know how to just snip the housing anyway...I have some bicycle cable housing cutters but they are not designed to preserve the cable and even if I did manage to just get the housing off...how would I deburr the end?
Hmm. Does anyone know if it is possible to re attach the cable end after you cut it or if anyone sells a throttle pull cable with a bit more slack in the cable?
thanks again I would love to be able to use the R6 tube
Old April 30th, 2010, 01:53 PM   #98
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
I bought a R6 throttle tube Yamaha part number 5SL-26240-01-00 it is actually .005" SMALLER in diameter then the stock throttle tube on my bike now. I ended up just using the zip tie method.
Ken08Ninja is offline   Reply With Quote
Old May 16th, 2010, 07:38 PM   #99
tabogon
Motorcycle(s): 2010 Ninja 250R (Metallic Island Blue)
Could someone point me in the right direction at Cycle Gear? I have been looking, but have not found the R6 throttle tube. A lot of tubes on the site, but non seem to be labeled.
Nevermind, found the 03-05 R6 sleeves at Black Hawk Customs, will that year sleeve work?
tabogon is offline   Reply With Quote
Old May 16th, 2010, 08:40 PM   #100
Ken08Ninja
What's the part number?
I think the 2007 and older 250's have a smaller cam on the throttle tube. The R6 tube swap originated on the older bikes before the 2008 was even produced.
Kawasaki shows different part numbers between the generations.
2008 : GRIP-ASSY,THROTTLE 46019-0001
2007 : GRIP-ASSY,THROTTLE 46019-1077
Old May 16th, 2010, 08:44 PM   #101
tabogon
It isn't a factory part, it's a replacement item made by Motion Pro.
Old May 25th, 2010, 12:48 PM   #102
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Thumbs up
Single zip-tie mod completed. I really like it.
As a byproduct of less twist, it gives that little extra throttle zing when blipping downshifts. This translates into less hand movement = smoother downshifts.
JeffM is offline   Reply With Quote
Old May 31st, 2010, 02:29 PM   #103
Purspeed
Purspeed's Avatar
Save your money...do the zip tie method. It's easy to do and cheap and reversible.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old June 11th, 2010, 11:23 PM   #104
QWK
Motorcycle(s): Ninja 250R
Best bang for buck mod!
QWK is offline   Reply With Quote
Old July 20th, 2010, 10:37 AM   #105
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Just finished doing this mod, just the thing I was looking for. Thanks for posting this up. Putting the housing back together was PITA for me though I wasted like 10 min trying to get it to fit correctly.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old September 11th, 2010, 11:01 AM   #106
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
bloody brilliant!
Old November 8th, 2010, 01:48 PM   #107
tonybhall
knees in the breeze
tonybhall's Avatar
Motorcycle(s): 2007 Kawasaki Ninja 250r
I did this mod using the gen 1 R6 throttle assembly. WOW!. It's like a new bike. I highly recommend this mod to any 250r owner who thinks they've gotten bored or out grown their 250. It makes the throttle so much more responsive.
The bike feels so much quicker. You don't notice much difference at higher speeds, but on the low end, HUGE difference. While it used to feel like there was a lag trying to accelerate through the lower RPMs, now just a slight twist of the wrist throws the tach up to 10K in the blink of an eye.
I was torn between trying the zip tie and getting an R6 throttle assembly. In the end, I decided it was worth the $13 to have a throttle assembly that didn't really need any modification. Turns out it did need a slight modification. I had to take about a 1/4 inch off the throttle stop with my dremmel. But other than that, it was a piece of cake.
If you're looking for a little more pep from your bike, this mod is great!!!
tonybhall is offline   Reply With Quote
Old November 8th, 2010, 02:02 PM   #108
part number for the Yami throttle?
Old November 8th, 2010, 03:36 PM   #109
tonybhall
knees in the breeze
tonybhall's Avatar
The Yamaha part number is 5SL-26240-01-00.
Here is the link I got the info from..
My bike is a 2007. I've heard that this may not work on the 08+ Ninja 250s. Something about the throttle tube already being larger on those.
Old November 8th, 2010, 03:39 PM   #110
thank you for that info.
Old November 8th, 2010, 03:48 PM   #111
tonybhall
knees in the breeze
tonybhall's Avatar
I wonder if you are having the same problem I had. When I put the R6 throttle on, the throttle close stop was too long. It didn't allow the carb to close all the way on the return. So, I took about 1/4 inch off with my dremmel and it worked fine after that.
I read where some people dremmeled it down to match the stock throttle. But I didn't have to take off that much to make it work. Now I wish I had taken pics.
Old November 8th, 2010, 06:30 PM   #112
setasai
setasai's Avatar
Did any of you need to adjust the throttle cable down by the carbs?
I used a PVC slice because I was lazy to go out and had time to spare. Will probably go get some zipties to compare thickness but I didn't add more than 2mm to the stock tube and I found it incredibly tight and initially, some binding as well. Once I loosened the cable, it was snug but the binding disappeared.
So far, took it for a quick spin but I can't really tell the difference. I may have shaved off so much that it became less than 1 zip-tie thickness but I can't imagine getting anything thicker on there without it getting caught on something.
Old November 8th, 2010, 10:15 PM   #113
tonybhall
knees in the breeze
tonybhall's Avatar
I didn't have to adjust the cable any at the carbs. The R6 throttle tube is considerably thicker than the stock Ninja tube. And you can really tell. I had some binding inside the housing if I really tightened the bottom screw. But I found that loosening it released the tension. It's still tight enough to hold it together and keep it in place. But it's not as tight as it was originally.
Old November 8th, 2010, 11:07 PM   #114
8gauge
8gauge's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R Limited Edition - R.I.P. 12/2/2010
this is actually the mod i was looking for to fix that lag in the throttle. I know what i'm doing once i get home from work!
"Your truth, is not my truth" -Bruce Lee
8gauge is offline   Reply With Quote
Old November 8th, 2010, 11:24 PM   #115
setasai
setasai's Avatar
Is the R6 tube better fitting for a new-gen as well? I thought I saw a post stating that the pre-gen ninja's tube was smaller than the R6 but the R6 was smaller than the new-gens. I'll need to test with a zip tie at some point. Will probably take it out again in the next couple days to see if I notice a difference.
Old November 11th, 2010, 06:04 AM   #116
8gauge
8gauge's Avatar
so the crazy glue isn't holding so well. is there any other glue I can use to get the ziptie to stick? Maybe I just need to sand it down a lot more...
Old November 11th, 2010, 04:05 PM   #117
setasai
setasai's Avatar
someone suggested spray adhesive. You could try that. I found that super glue tends to be more brittle if it is allowed to cure in a cold place. Try allowing it to cure inside the house where it's a little warmer. Sanding it down rougher is also highly recommended. If you think your not holding it in place long enough, Use another ziptie to wrap around the throttle tube or a clamp until it's cured.
Old November 11th, 2010, 06:43 PM   #118
8gauge
8gauge's Avatar
It's warm enough where i'm at. I probably just need to use a clamp since i'm impatient to hold the stupid ziptie. lol i'll have to remember to "borrow" a clamp from work before heading out...
Old November 11th, 2010, 06:44 PM   #119
00NissanNinja
I hate driving...
There is also a super glue made specifically for plastic and comes with an adhesion promoter you could try that as well. I think its from loctite brand
Old November 12th, 2010, 01:57 AM   #120
8gauge
8gauge's Avatar
so i finally did the mod, and had a hell of a time putting everything back together. took it for a test drive and there's a noticeable kick. the only problem is after releasing the throttle, it sloooowly goes back down. does anyone know how to fix this?
DIY How to Lube and Adjust the 250R Clutch Cable and How to Add 10 HP w/ one Mod!!! kkim 2008 - 2012 Ninja 250R Tech Talk 51 October 11th, 2014 06:42 PM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
(zip tie mod + u-turn) x me being an idiot = no good Monkeytofu !%@*#$%!)@#&!%@ I crashed! 1 July 4th, 2012 07:59 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
