Old August 5th, 2017, 07:26 PM   #1
kvgeorge1
Motorcycle(s): EX250J
Broken sprocket cover bolts
Stupid me! When I read the maintenance manual on my 2008 250R, I mis-read the torque specs for the engine sprocket cover bolts. They are supposed to be 87 ft-in, but I read it as 87 ft-lbs. Now, I over torqued 2 bolts, 1 broke off, the other I think is broken in the threads.
Now what? Do I have to get them professionally removed?
I am so mad at myself.
kvgeorge1 is offline   Reply With Quote
Old August 5th, 2017, 09:32 PM   #2
Old_Six_Fitty
Old_Six_Fitty's Avatar
Motorcycle(s): DL1000 V-Strom, KLR650
Well, plus 1 for actually having the main manual and for using it.
Makes for a powerful lesson -don't over tighten the dam thing.
Don't sweat it too much, every mechanic has done this as well.
Did your break off one or more of the three mounting screws?
Fiche says these are 6mm x 20mm, 6mm x 25mm, and 6mm x 50mm
Flange head screws /bolts ...
1) Try to remove the stub of the remaining bolt -if any- using vice grips
2) If no stub is left to grab, then you need to drill out that little b~tch
--take off the final drive cover, being careful not to break anything else :^)
--take a small size drill bit, say about 1/8th inch
--carefully drill into the stub of the bolt and try to keep the bit centered
--drill in about 1/2 inch
--tap into this hole the extractor tool
--then use a wrench and back out the broken bolt
Sometimes the screw just strips the threads out of the case ... (swearing ensures)
If that happens you need to install a thread repair kit.
This might help orient you on the process ...
http://www.wikihow.com/Use-a-Screw-Extractor
Old_Six_Fitty is offline   Reply With Quote
Old August 5th, 2017, 09:49 PM   #3
Ghostt
Ghostt's Avatar
Another victim of overuse of a torque wrench.
Do yourself a favor on by a good quality 1'4" drive socket set, save the torque wrench for the things that need it, which is almost nothing on the bike doing normal maintenance. I personally can't remember the last time I used my torque wrench on the bike.
As far as how to get those broken ones out, did they break flush with the surface of the block?. If so you'll need to get an easy-out, if your not familiar with them, let a professional so it, you could make the problem a lot worse.
But if your diehard wanting to use the torque wrench on everything, here's a chart that might help you out.
violente et ignorantia
ZX-2R BLOG
Old August 5th, 2017, 10:20 PM   #4
kvgeorge1
Thanks everyone for replying. I know for sure that one of the bolts broke off - how far into the threaded hole, I have no idea because I think I broke 2 and can't seem to back-out the other one I think I broke.
I agree with the torque thing. I thought I was being smart by torquing the bolts, but I was just being really stupid because I misread the manual and set it for foot-pounds instead of foot-inches.
That's what I get for being a noob at all this.
Old August 5th, 2017, 10:23 PM   #5
Here's decent screw-extractor kit I've used. It comes with left-hand drill-bits and about 1/2 time, drilling hole will back out the broken end. Otherwise, use the extractor and that'll remove it for sure! Nice thing about this kit is bits are sized properly for each extractor, so no guessing needed.
In certain extreme cases, I've welded smaller bolt onto broken one. Then I can use the hex-head to unscrew with socket.
Old August 6th, 2017, 06:45 AM   #6
Skip the torque wrench on the small stuff like that, and just go "snug" with a 1/4" drive ratchet and a dab of blue Locktite if you want more security.
As far as the broke bolts go, post a photo if you can. Start by removing the cover and seeing how much is sticking out to work with.
Since the bolt is not seized or corroded, you should have an easier time backing it out. Sometimes you can use a sharp punch to spin it enough that you can clamp a visegrips on the end. If not, drilling and using an extractor is another option.
Old September 26th, 2017, 12:00 PM   #7
kvgeorge1
Ok, here's another stupid question - where can I find the bolts? I've been looking around and cannot seem to locate them. Is this something I need to special order from somewhere?
Old September 26th, 2017, 01:05 PM   #8
Pretty sure those are shouldered bolts, probably M6s.
I'd personally get the OEM bolts, but you could find the exact specs ("M__ x __mm") and get replacements.
Old September 26th, 2017, 01:46 PM   #9
kvgeorge1
Where do you get your OEM parts - Kawasaki directly or is there a parts house that carries them?
Old September 26th, 2017, 02:12 PM   #10
Motorcycle shoppes typically have all those bolts.
Otherwise, I order from https://www.belmetric.com or http://www.mrmetric.com.
McMasterCarr has wide selection also; tends to be pricey.
I like MrMetric because I can place order in morning and go pick up.
Amazon also has large selection of metric nuts & bolts.
Old September 26th, 2017, 02:22 PM   #11
I guess I'd call the local Kawi dealer if you have one close and see how much they want for what you need. It would be a bit more than the online cost, but you shouldn't have to pay additional shipping.
You can find the OEM bolts online also, but may end-up paying more in shipping than the actual bolts.
If you want replacements that are not the exact oem black shouldered bolt, you could check out a local hardware store once you know the exact dia and length you need. Some carry socket head cap screws that would work. Stainless Steel is always nice for anything that gets wet.
Old September 26th, 2017, 02:51 PM   #12
Ram Jet
Ram Jet's Avatar
If you want exact replacements - Partzilla.com. You might try Lowes or Home Depot or Ace hardware. Three stainless steel Allen head cap screws would be cool. Plus if you reinstall them with the typical Allen wrench there's little danger in over tightening them.
Bill
Old September 26th, 2017, 08:36 PM   #13
redonninrf
Motorcycle(s): 2008 Ninja 250R, 2017 Triumph Thruxton 1200 Classic (not the 'R')
I forget what the base metal for that part of the engine is but stainless steel and aluminum do not mix. Even mixing SS with regular steel, or SS with SS, can seize. And when SS fasteners seize they seize. Trust me I know . One of the reasons I ended up owning a Dremel tool with cut-off wheels. If going with stainless use a generous amount of anti-seize compound.
Those 6mm screws are going to have a 1.0 mm pitch so you're looking for M6 x 1.0 - <length in mm> screws. True Value hardware stores carry the Servalite brand which usually turns out to be a really good selection of fasteners. Guess that's Hillman brand now since they bought Servalite. Anyways, usually a better selection than Lowes or Home Depot. The True Value store in my town even has chrome metric fasteners which would really raise the bling.
The black oxide socket head cap screws are cheaper and will look great at first but they rust easily. Strong screws but not the least bit rust-proof.
I'm very OCD about torqueing things. If the bike or car manual provides a torque setting I use it. For low-torque items like spark-plugs, brake bleed nipples, and cover screws I like the Craftsman inch-lb clicker torque wrench.
Last futzed with by redonninrf; September 26th, 2017 at 08:56 PM. Reason: Added material.
redonninrf is offline   Reply With Quote
Old September 26th, 2017, 09:53 PM   #14
Ram Jet
Ram Jet's Avatar
I have never had a stainless fastener lock-up in aluminum, cast iron or steel. I sure have had steel fasteners lock-up in aluminum and even wood in marine applications. Ask anyone who has disassembled an outboard boat motor. I always lubricate threads on anything I screw together. Maybe that's why. I would be extremely cautious using never/anti seize with a torque wrench. In fact, I will not do it. You need to reduce the torque value by about 50% if you do otherwise you will pull threads of twist-off screws/bolts.
Engine oil is a very good thread lubricant. Type "A" transmission fluid is OK also.
Bill
Old September 27th, 2017, 07:08 AM   #15
That is true for stainless fasteners, but it's also true for most any fastener going into aluminum.
I always use something on threads - anti-seize or medium threadlocker. I have has stainless bolts seize in aluminum (before I started using something on the threads), and they get really stuck.
As far as using a torque wrench on everything goes - be careful. Bolts like the OP was working with just don't need exact torque, and most of the time (especially with anything on the threads) you are going to over-do it, possibly breaking the bolt. Just use a 1/4" drive ratchet on the small stuff and make it "snug".
My son replaced a sprocket on his R6 recently, and torqued the bolts to the recommended spec. 3 out of 6 stripped. I told him I thought it was too much. He double checked. It was the proper amount. After reading some info on the R6 forums I found it wasn't uncommon at all. The published factory spec is too much for the size and grade of fastener. No idea why.
Sometimes you just need to trust your gut and not the specs.
Old September 27th, 2017, 09:04 AM   #16
Torque-spec may be off due to conversion from different measurement, some of metric ones perhaps.
Aluminium (6000) + carbon-steel bolts have 0.05v differential on galvanic series. Aluminium + stainless-steel bolts have 0.50v, so much more corrosive potential.
My friend who's mechanic @ Lucas Aviation in Santa Barbara tells me that no bolt ever goes into plane bare. It's either coated with lubricant or thread-locking compound. And torque used is logged in records.
Old September 27th, 2017, 09:37 AM   #17
In our case, the published spec was "correct" for that part - but over what you would expect for that fastener.
In the last few years I've started coating all fasteners with something as well.
Do they modify the torque spec based on using something on the threads, or is that factored in?
Old September 27th, 2017, 11:34 AM   #18
Ram Jet
Ram Jet's Avatar
See Ghostt's previous post on this thread. Buy the way "lubed" does not mean anti seize compound I'm sure.
https://forum.ih8mud.com/threads/ant...-bolts.604971/
Bill
Old September 28th, 2017, 08:55 AM   #19
Ralgha
Ralgha's Avatar
I've used a torque wrench on everything that the Ninja manual specifies torque for and never had a problem. Anyway, the OP's issue was not incorrect or improper use of a torque wrench, it was misreading the torque spec. The torque wrench was used properly, from what I read.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old September 28th, 2017, 12:12 PM   #20
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
You can also just go with no sprocket cover. One less thing to clean caked grime off of!
My Ninja 300
Old September 28th, 2017, 01:33 PM   #21
Ram Jet
Ram Jet's Avatar
It's good you use a torque wrench. At least you won't strip out the threads on your oil sump drain plug like the previous orangutan owner of my bike did. Good God, you should have seen the rear axle adjusters on my bike. Tightened with a trip hammer. Both were replaced. Thank God he didn't do a valve adjustment.
Bill
Can't get front sprocket cover off Jason5885 2008 - 2012 Ninja 250R Tech Talk 8 April 4th, 2021 04:33 PM
Broken Valve Cover Bolt -- Where Can I Buy Better Bolts? Cra1g 1986 - 2007 Ninja 250R Tech Talk 12 August 31st, 2016 01:55 PM
[crash.net - MotoGP] - Broken sprocket ends disastrous Sunday for Dovizioso Ninjette Newsbot Motorcycling News 0 May 31st, 2015 10:50 AM
[crash.net - MotoGP] - Broken sprocket compounds disastrous Sunday for Dovizioso Ninjette Newsbot Motorcycling News 0 May 31st, 2015 10:10 AM
Sprocket cover demp 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 06:36 PM
