Old October 24th, 2017, 07:21 AM   #1
redonninrf
Motorcycle(s): 2008 Ninja 250R, 2017 Triumph Thruxton 1200 Classic (not the 'R')
Couple Questions on AiM Solo and 2008-2012 Ninjette
First question is really a favor. If anyone has mounted an AiM Solo on their 2008-2012 EX250 would love to see a picture of the mounted device.
Second question is two part: The DL version of the Solo can read a bike or car's ECU. AiM does not officially support the EX250. Has anyone managed to adapt a Solo DL to read their Ninjette's ECU? If so, does the ECU give anything useful other than RPM?
Thanks in advance.
redonninrf is offline   Reply With Quote
Old October 24th, 2017, 11:42 AM   #2
AwDang
Motorcycle(s): 286, 296, 599, 799
Ninjette doesn't have a CAN driver so DL will do you no good.
You'll need to go to something with analog channels to datalog.
I removed the dash and welded a piece of sheet metal to the fairing stay for our Solo.
AwDang is offline   Reply With Quote
Old October 24th, 2017, 01:56 PM   #3
redonninrf
Thanks! After submitting my post realized my second question about the ECU was, how shall I say, 'uninformed'. I've got a couple leads on used Solos and just wanted to make sure there wasn't a good reason to hold out for a Solo DL. For now it is a track day/daily rider so a plain Solo should be good enough.
Old October 24th, 2017, 03:00 PM   #4
The ECU is just controls a 2D RPM-based ignition map. So all you're gonna get out of it is RPM data.
Although if you tie in to the crank-sensor signal, you can obtain the actual amount of ignition-advance. Not sure how helpful that is though.
Old October 24th, 2017, 06:25 PM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Here is my set up, had a buddy weld a plate for me.
TEAM ALFALFA
www.apexassassins.com
Old November 10th, 2017, 03:58 PM   #6
Mechanikrazy
Mechanikrazy's Avatar
Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold)
I think it's the same set up on the 250s and the 300s. Since I have clip ons, I just used the OEM handlebar mounting holes. Used a small piece of aluminum plate to mount the AIM mounting bracket.
Mechanikrazy is offline   Reply With Quote
A Couple of questions bigreddog 2008 - 2012 Ninja 250R Tech Talk 2 August 27th, 2015 05:19 PM
Thanks Ninjette.org, and a Couple Questions Dredgshadow General Motorcycling Discussion 16 June 26th, 2013 03:37 PM
Couple of questions ninjaryda 1986 - 2007 Ninja 250R Tech Talk 7 April 20th, 2013 05:14 PM
Couple of quick questions zach 1986 - 2007 Ninja 250R Tech Talk 10 July 8th, 2009 06:47 PM
Couple of questions pantera 2008 - 2012 Ninja 250R Tech Talk 5 May 6th, 2009 01:27 AM
