Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old March 27th, 2018, 12:33 PM   #1
sprinter
Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...)
Ninja 400 Track/Race Bike Mods
Anyone else building one? I ordered up (pre-ordered) Ohlins suspension, Rapid Bike fuel controller, some Bonamici rearsets, and some Driven clip-ons. Still shopping for a full race exhaust and bodywork.
sprinter is offline   Reply With Quote
Old March 27th, 2018, 02:43 PM   #2
Looking forward to the build thread!
Old March 31st, 2018, 09:53 PM   #3
tuscani451
Motorcycle(s): R6, Kawi 250
Been working a little on mine, clip-ons, front steel brake line, Speedcell battery is all so far. I have a hook up for full K-tech but can't afford to pull the trigger yet. Race in two weeks, hope to break some hearts.
tuscani451 is offline   Reply With Quote
Old April 1st, 2018, 03:01 AM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Be sure to give us updates.
Old April 1st, 2018, 10:09 AM   #5
Burphel
Burphel's Avatar
Motorcycle(s): Triumph Bonneville, Ninja 300
I was looking at Spears this morning, and they have a section up for 400 goodies already. Not sure how much of it is just 300 stuff that still fits the 400, but at least you know it'll fit.
https://www.spearsenterprises.com/ex400.html
Let he who has never re-used a crush washer cast the first stone...
Burphel is offline   Reply With Quote
Old April 1st, 2018, 05:43 PM   #6
How about some carbon-fibre wheels?
Old April 2nd, 2018, 02:18 PM   #7
tuscani451
I am curious about the Rapid Bike Controller. I had not heard of it so I looked last night, seems pricier than a Power Commander for example. Is there a benefit and whats your experience?
Old April 5th, 2018, 04:35 PM   #8
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
300 bits fit on a 400?
Anyone know if bodywork and suspension from a 300 fit on a 400? Or if a 400 motor will fit in a 300 chassis? :-)
JBinSD is offline   Reply With Quote
Old April 5th, 2018, 05:00 PM   #9
mgentz
Board Member
I love spears. Most of their stuff says available soon, so it would seem they are working to get stuff in stock.
Old April 6th, 2018, 09:27 AM   #10
sprinter
I think no on the suspension, Ohlins has all-new part numbers for both shock and forks. The forks are 41mm now instead of 37mm, so that's a definite no. Not sure on engine, but probably not since it's a new frame.
Old April 6th, 2018, 09:28 AM   #11
sprinter
I've only used them on Ducatis so far, but in that application they work very well and can tune more parameters than the PC-V can, and the auto-tune function is more advanced. I've had great luck with them.
Old April 6th, 2018, 09:35 AM   #12
tuscani451
Someone on another forum said the shock from their 300 worked but there was some minor modifications required to fit it. Also Ninja 650 shocks may fit as well.
Thanks for the info sprint, so do you adjust on the fly? I assume you still have to dyno tune and not just adjust the map?
Old April 6th, 2018, 09:56 AM   #13
sprinter
You don't need to dyno tune with the Rapid Bike, it self-tunes. It comes pre-mapped for the particular bike and exhaust setup you have, and is usually pretty close out of the box, but then it auto-tunes to fine tune the settings. You can use the software to manually adjust if you want to, and you CAN dyno tune and manually adjust based upon that also, but I've never found the need to.
Old April 6th, 2018, 10:00 AM   #14
Engine is all new as well.
I wouldn't expect anything to work between the 300 and 400.
Old April 6th, 2018, 03:44 PM   #15
tuscani451
Oil drain bolt, anyone know if its the same from the 250/300?
Old April 21st, 2018, 07:24 AM   #16
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
I'd look into upgrading the clutch, as there are already reports of track/race 400s having clutch problems.
GregS is offline   Reply With Quote
Old April 21st, 2018, 08:45 AM   #17
Topaz
Topaz's Avatar
^^ What kind of problems?
Old April 23rd, 2018, 07:39 AM   #18
taz
taz's Avatar
MOTM - May '17
yea what kind off problems and from who have you heard this from.
Old April 23rd, 2018, 09:21 AM   #19
tuscani451
My clutch was slipping on hard acceleration, also need to upgrade the shift detente and spring as hitting multiple down shifts as problematic
Old April 23rd, 2018, 09:24 AM   #20
tuscani451
I thought I read somewhere that the front and rear sprockets are interchangeable with the 300, anyone confirm this?
Old April 23rd, 2018, 07:17 PM   #21
GregS
Oh great - another Ninja with shifting problems. Please keep us updated on any shifting mods you do. I did the spring on my 300 and it solved most of the problems.
Old April 24th, 2018, 04:54 AM   #22
Topaz
Topaz's Avatar
Can't confirm, but I've heard the same.
I ride an N300 now, and thinking in getting a 400.
The lack of interchangeability of aftermarket parts is discouraging.
It looks like starting all over again.
What I've heard so far is:
Levers, OK.
Sprockets, OK
Pipe, not ok
Power commander, not ok.
Suspension, not ok.
Clip ons, not ok.
Again, what I've heard. I don't have an N400
Old April 24th, 2018, 04:56 AM   #23
Topaz
Topaz's Avatar
What problems did you have? Slipping too?
I get a false neutral quite often when riding high revs. Either up and down shifting.
But maybe is just me screwing up.
Old April 24th, 2018, 03:30 PM   #24
tuscani451
Yeah same on my 300, the upgrade from factorypro solved the issue though. I have a buddy who is working with a 400 in MotoA. He says they are getting a clutch upgrade through Spears racing, not sure what all that involves. He also says the sprockets are interchangeable and I should be able to confirm in the next day or two
Old April 28th, 2018, 09:29 AM   #25
GregS
The clutch on my 300 has never slipped. The biggest problem I had was the transmission jumping out of gear. It had a particularly bad habit of doing it under hard braking and usually just when you were tipping into a corner. The sudden loss of engine braking at a critical time was very disconcerting.
The heavier detent spring solved 99% of the problems though
Last futzed with by GregS; May 2nd, 2018 at 05:00 PM.
Old April 28th, 2018, 10:28 AM   #26
Topaz
Topaz's Avatar
The clutch on my 300 has never slipped. The biggest problem I has was the transmission jumping out of gear. It had a particularly bad habit of doing it under hard braking and usually just when you were tipping into a corner. The sudden loss of engine braking at a critical time was very disconcerting.
LOL! 'disconcerting' is a nice way to put it. It happens to me once in a while and I'd say it scares the $hit out me. It made me visit the grass more than once.
Specially because the N300 has a lot of engine brake so you adjust your braking to that, and when you loose it you're in trouble.
Old April 29th, 2018, 11:38 AM   #27
GregS
Yes I've made a few trips into the grass as well. I'd be interested to know from anyone with a 400 if it also suffers from the same issue of popping out of gear. The slipping clutch on the 400 should be an easier fix, with the replacement of the friction plates and springs.
Old May 1st, 2018, 08:50 AM   #28
sprinter
Finished my first race on the 400 this past weekend, and didn't have any shifting problems other than it's really easy to overwhelm that factory slipper clutch and have it "free wheel" for way too long. I'll be looking into an aftermarket slipper clutch for it.
Old May 1st, 2018, 09:04 AM   #29
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Thank you for the updates, I haven't seen or heard all that much about the 400 yet other than it's stupidly fast compared to the 300
clutch issues are interesting, I hope they upgraded the transmission. Mine didn't show issues until later in it's life
Old May 1st, 2018, 05:03 PM   #30
Angel-be-Good
Angel-be-Good's Avatar
Motorcycle(s): '08 Ninja 250, '11 Street Triple R
Can you elaborate on this? This is the first bike I've ridden with a slipper clutch, not sure what effects/feelings I should expect with it.
One thing I've noticed is that if I'm WOT and shift up, as the clutch engages it almost feels like it's spinning a bit before full engaging. Not sure if this is an imagined feeling, or if it's at all related to the slipper clutch, or similar to what you're describing. Just something I've noticed when riding hard.
The Sunday Best | Current mileage: 50,000
Angel-be-Good is offline   Reply With Quote
Old May 1st, 2018, 05:34 PM   #31
sprinter
Well, no. This is when racing, going from 6th to 4th at the end of the straight and banging the two downshifts late in the braking zone, let the clutch out smoothly and expect the engine to pick up and start providing some engine braking but instead it just freewheels the slipper for a couple of seconds until it finally catches up. Not a good feeling, it's not predictable how much engine braking you're going to get, so you end up using a little more front brake and then have a hard time holding the apex. It might be possible to just put in some stiffer clutch springs and solve the problem.
Old May 6th, 2018, 06:27 AM   #32
Burphel
Burphel's Avatar
Can't speak to the 400, but on my 300 I barely notice the slipper - other than that I don't grease the rear on downshifts unless it's rainy. Personally, I like that I can pay a little less attention to the clutch on corner entry and just have the power pick back up when the revs are matching again. If you feel like it's too light, I'd definitely try stiffer springs before you go nuts on an aftermarket unit. Springs are cheap, and it might even help a bit with preventing false neutrals.
Old May 7th, 2018, 07:36 PM   #33
GregS
More on the shifting issues, there is quite a lengthy thread one of the other Ninja 400 forums, with several people having problems in everyday use.
Old June 4th, 2018, 07:20 AM   #34
mgentz
Board Member
@sprinter , what did you do with the old bike?
Old June 5th, 2018, 02:28 PM   #35
sprinter
The 300? I sold it last year.
Old September 18th, 2018, 11:08 AM   #36
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Penguin school has N400 race bikes to try. I was going to yesterday but decided I was too tired and sore so I stayed on my 636. Their sister company woodcraft has lots of N400 stuff available.
Old November 26th, 2019, 05:10 PM   #37
BretSV
Motorcycle(s): Shopping
I’m building a 400 for next year
BretSV is offline   Reply With Quote
Old February 8th, 2020, 06:21 AM   #38
How's N400 build coming Bret?
Found some cool articles on 400. I hung out with Rocco at some races last season. He was racing both stock 400 and his MotoAmerica bike.
https://www.motorcyclistonline.com/j...u-can-buy-one/
https://ultimatemotorcycling.com/201...pec-bike-test/
FS: 2009 Ninja 250 race/track bike walk_n_wind Ninjettes At Speed 2 May 18th, 2016 03:24 AM
FS : 2010 Ninja 250 Track/Race Bike abhijitz Motorcycle-related 21 November 23rd, 2015 02:28 PM
2008 Ninja 250r, tons of mods! Track ready! Pennsylvania ChrisJuliano Motorcycle-related 19 January 24th, 2015 10:47 AM
Race bike mods #19 Ninjettes At Speed 14 August 9th, 2014 09:37 AM
Parting Out :: 08+ Ninja 250 Track/Race Bike abhijitz Motorcycle-related 14 May 10th, 2014 07:32 AM
