Old July 26th, 2018, 11:01 AM   #41
Zww1019
Motorcycle(s): Ninja 250r
As temporary troubkeshooting step, bypass starter circuit relay by back-probing/jumpering the BL across to Y/R wire. Then push start-button. Does it crank now?
Nope I jumped the two wires like you said and the ignition button still didn’t do anything
Zww1019 is offline   Reply With Quote
Old July 26th, 2018, 12:04 PM   #42
Did you measure voltage along path? where does it stop?
Don't skip steps. Here it is again. Give me a voltage reading at EVERY step along path.
battery +terminal -> ??? voltage?
30a fuse -> ?
W wire at ignition switch inlet -> ?
BR wire at ignition switch outlet (switch ON) -> ?
leave ignition switch ON for rest of tests
10a IGN fuse -> ?
BR/BK wire -> ?
Y/R wire inlet stop switch ON -> ?
stop switch ON for rest of tests
R wire outlet wire stop switch-> ?
BK/R wire into start button-> ?
BK/R wire out of start button ON -> ?
rest of these tests with start button pressed ON
BK/R wire at inlet diode B -> ?
outlet diode B at BL wire -> ?
starter circuit relay outlet Y/R -> ?
Y/R at starter solenoid -?
Important thing I'm trying to get across is critical-thinking process of troubleshooting. Not quick-fixes like "swap these parts" and it'll work. You have to understand why it's broken first, then fix is apparent. MOST important piece of data is where +12v stops in chain. That's only thing we need from very beginning. Once that's known, fix is easy.
Blown fuse. Then another. mrudich 1986 - 2007 Ninja 250R Tech Talk 34 July 30th, 2020 08:26 AM
Bike won't start and backfires when trying to start TrickyTriggs General Motorcycling Discussion 30 April 16th, 2018 08:35 PM
Headlight out/fuse blown... tsdexter 2008 - 2012 Ninja 250R Tech Talk 4 June 18th, 2013 12:43 PM
bike wont start. fuse box is buzzing rabies 1986 - 2007 Ninja 250R Tech Talk 13 October 6th, 2012 03:40 PM
blown headlight fuse sombo 1986 - 2007 Ninja 250R Tech Talk 15 July 4th, 2009 11:00 PM
