October 5th, 2020, 05:15 AM | #1 |
Join Date: Mar 2020 Motorcycle(s): 2004 Ninja 250 Posts: 74
Offset keyway ignition advance question
Anyone done the ignition advance offset key way on a 88-07 ninja 250 from Factory Pro? I am reading the instructions and it says the offset needs to be to the right. I believe the motor spins counter clock wise, so wouldn't having the offset to the right of the key way slot be retarding the timing? Any help is appreciated I only have one generator cover gasket and want it on correct the first time.
Last futzed with by ssrsupermoto; October 5th, 2020 at 07:08 AM. |
October 5th, 2020, 05:42 AM | #2 | |
Of course if you remove the flywheel and look at the keyway, that "to the right" becomes "to the left". |
October 5th, 2020, 07:08 AM | #3 | |
October 5th, 2020, 07:38 AM | #4 |
October 5th, 2020, 07:52 AM | #5 |
October 5th, 2020, 09:00 AM | #6 |
They follow the standard of turning the same way as the wheels.
October 5th, 2020, 10:06 AM | #7 |
So counter clockwise. Wouldn't putting the key way offset to the right moving the flywheel according to the instructions be retarding the timing?
October 5th, 2020, 10:41 AM | #8 |
Yes, want key to left to advance timing.
Factory Pro messes up A LOT. Such as sending pre-gen needles with their new-gen jet kits, wrong-sized jets, etc. |
October 5th, 2020, 10:54 AM | #9 |
October 5th, 2020, 01:24 PM | #10 |
yeah, I have lexdysia too! Sometimes I get lost and end up riding in circles... for hours!
October 23rd, 2020, 08:47 AM | #11 |
Join Date: Oct 2019 Motorcycle(s): Ninja ZZR250 (EX250H) Posts: 213
07 ninja 250 ignition switch question. | NewtoNinjettes | 1986 - 2007 Ninja 250R Tech Talk | 26 | October 9th, 2019 08:06 PM |
07 ninja 250 ignition switch Ninja 500 Ignition switch question. | NewtoNinjettes | 1986 - 2007 Ninja 250R Tech Talk | 0 | September 30th, 2019 01:31 PM |
2012 ninja 250R ignition coil question | webfoot | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 22nd, 2014 10:18 PM |
woodruff offset key for timing advance? | Lucagst | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 13th, 2013 08:25 PM |
Milwaukee Offset Screwdriver | THE BIG SITT | Items Wanted | 9 | January 8th, 2012 03:35 PM |
