January 24th, 2012, 10:44 AM | #1 |
Join Date: Dec 2011 Motorcycle(s): Black 2011 Ninja 250R FI Posts: 102
Top speed 92 mph.. Sigh QQ
Bought bike on 30th december and clocked at 1400 km.
I only removed snorkel and since it's fuel injected with o2 sensor, there was no need to do anything else. So i tried to test it's full speed and in 6th gear it doesnt go beyond 145 kmph? I even bend down for reducing air drag and my kerb weight is 60 kg XDDD So i wonder what's wrong.. I expected it go beyond 170 kmph easily.. I even use premium 91 octAne fuel with friction busters. And i get my fuel from best and most renowed petrol pump. Ugh.. This is irritating QQ Anyone else facing such issue?
dat road rash game |
January 24th, 2012, 10:50 AM | #2 |
Put the snorkel back in and try it. Many of us here have the US bike, so not much is readily known about the FI version.
Is gas measured on the RON system in India? |
January 24th, 2012, 11:00 AM | #3 |
change out the front sprocket
January 24th, 2012, 11:07 AM | #4 |
Terminal velocity is a power thing. You're getting to the point where the power made by the bike is the same as the power of the wind you're going into on the surface of the vehicle. Changing the gearing without making any other modifications won't raise top speed. If you're really into top speed, get the bike on a dyno, and get the ECU reprogrammed (or use a Powercommander) so that you make as much power as possible. Changing gearing just moves the power band to a different speed, which doesn't do anything for top speed unless there's more power to be found there
January 24th, 2012, 11:13 AM | #5 |
i thought he was close to hitting the redline
January 24th, 2012, 11:21 AM | #6 | |
I don't really understand 'RON system' i googled it and found ron weasely And what exactly you said.. I feel my bike lacks power.. Getting a dyno test is a pain.. I have to go 350 km away. In india people prefer cars.. There are no bike shops here where i live.. Heck i couldn't even find rear tire of 150/70/17 size!! All asked me to go to 350 km away to delhi. In my city, people have so many expensive cars but no expEnsive bikes.no one cares for bikes here QQ
January 24th, 2012, 11:24 AM | #7 |
I reach that speed in 5th gear too and at 13k rpm.
6th gear.. I am stuck at 10-11k rpm -..- And yes, i even have 30 psi in front tire and 35 in reAr -..-
January 24th, 2012, 11:34 AM | #8 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
My ninjette is fuel injected and I can get to 145 kmph with ~4000-5000 rpm left over. That was with the recommended 28psi in front and 32 in rear.
Next time I'm on the motorway I'll see how fast it will go and get back to you. |
January 24th, 2012, 12:54 PM | #9 | |
About the RON, I only ask because in the US, we use a different system, so our 87 is like a RON 91. I was wondering if you were quoting a 91 RON number, or a 91 (RON+MON)/2 how octane level is measured |
January 24th, 2012, 12:56 PM | #10 |
Jigglin' your Jiglets
MOTM - Apr '13
if you bike produces the same power curve that our bikes do then you maximum horsepower is at 10k which explains why you cant go past that point in 6th. To go faster you would probably need a new exhaust system and get a power commander
January 24th, 2012, 01:05 PM | #11 |
Nooblet
MOTM - Oct '13
Hmm... I never tried to get past about 10/11K in 60th. I'm super curious now. I've gotta give this a go on Sunday and see what the top speed is. I always expected it to be just about 100MPH
January 24th, 2012, 01:08 PM | #12 |
MOTM - Apr '13
My top speed right now is 100mph, thats with a full exhaust and poorly tuned carbs
January 24th, 2012, 01:15 PM | #13 |
January 24th, 2012, 01:17 PM | #14 |
Is that indicated or actual?
January 24th, 2012, 01:18 PM | #15 | |
Nooblet
MOTM - Oct '13
Wellll... to get the extra gears you have to give the dash board a tug. The whole things folds back on a hinge and there are lots of flip-switches that you use to get the other gears. There's also a wheelie button... the manual says only to use that button when you're late for work... it's dangerous to use it otherwise. |
January 24th, 2012, 01:19 PM | #16 |
January 24th, 2012, 01:38 PM | #17 |
MOTM - Apr '13
Indicated
I don't currently have a way to accurately measure my true speed while riding. However I do feel like my speedo is quite accurate based on the indicated speed and the speed of other cars on the freeway. i.e. I'll be passing cars in very light traffic on the freeway while going 70-75mph indicated. If it's off at all then it's only by a very small percentage. Now my pregen on the other hand, that things speedo is waaaayyyyyyy off. At least 10% or more
January 24th, 2012, 02:01 PM | #18 | |
Love Rival
Join Date: Jun 2010 Motorcycle(s): 2008 Ninja 250r Posts: 449
“Comparison is the thief of joy.” -Dwight Edwards |
January 24th, 2012, 11:00 PM | #19 |
Pics or it didn't haPpen!!
We want to see a racing toilet seat!!
January 24th, 2012, 11:17 PM | #20 |
this? |
January 24th, 2012, 11:43 PM | #21 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
My bike only indicates 150km/h max. But I found out early on that its optimistic because when I'm travelling at 65 km/h on the streets I get people honking at me. So I'm pretty much getting the same results as the OP. I'm 180 lbs though, so probably heavier than the OP is...and that's in full tuck wearing a backpack full of things. If I wasn't wearing a backpack I might be able to gain a few more ticks on my speedo.
January 25th, 2012, 02:49 AM | #22 |
156 kmph with snorkel on
January 25th, 2012, 04:17 AM | #23 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
and i complain about my 115 hope you find a solution
THE GOOD LIFE |
January 25th, 2012, 04:41 AM | #24 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
Just less than 100mph real is about right it’s only 33 ps after all don’t expect miracles.
Steve
Some mistakes are too much fun to make only once. |
January 25th, 2012, 05:11 AM | #25 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
I've hit 102 indicated, but that was going down a large bridge. On a flat with no obstacles, I always top out at 90-95 depending on the air temperature and humidity. Funny enough it does change the speed, only a little though.
January 25th, 2012, 08:23 AM | #26 |
January 26th, 2012, 01:30 PM | #27 |
is the factory ecu able to be flashed?
January 26th, 2012, 02:42 PM | #28 |
Yeah there's a member here who said his was in the shop to have it reflashed. Forget what his name was though...
The guy from Denmark or somewhere with a green 08... |
January 26th, 2012, 03:31 PM | #30 | |
MOTM - Apr '13
Rev away little squirrel
January 26th, 2012, 04:33 PM | #32 | |
you'll be fine akima. Just watch that temp light. |
January 27th, 2012, 01:54 PM | #33 |
Nooblet
MOTM - Oct '13
I just found a gps speedometer app on my phone that will record my max speed. Looking forward to my speed run on Sunday! Hope it goes to 100 indicated... then I can tell people "my bike does AT LEAST 100MPH... probably tops out at like 300" ^_^
February 2nd, 2012, 09:44 AM | #34 | |
Join Date: Aug 2010 Motorcycle(s): Ninja 250r (2009) Posts: 67
My FI 250R goes 107MPH (172km/hr) indicated - I tried changing the OEM exhaust to a BlueFlame Slip-On but that had no effect on my top speed. I weigh around 75kg (165 pounds, 11.8 stone). When I ride 2 up with my girlfriend, total weight around 125kg (275 pounds, 19.7 stone), my maximum speed is around 100mph (160km/hr) indicated. Not sure why you guys have such poor performance EDIT: One thing that sucked about 2-up is economy went down from about 70mpg solo to 58.5mpg riding 2-up - check my fuelly.
http://www.fuelly.com/driver/hackeron/ninja-250r |
February 2nd, 2012, 09:56 AM | #35 |
Damn man, I do wish I could get that performance. You're only 20 pounds lighter than me, although you have the FI, maybe that's the reason...I have no clue.
Can't wait to get a 600cc, but I'll always love my ninja |
February 2nd, 2012, 09:59 AM | #36 | |
wait. 100 indicated is about 91. eh nevermind. |
February 2nd, 2012, 10:07 AM | #37 | |
Not sure what the indicated is, but when I go to 70mph indicated, I go the same speed as cars on the road, when I go 60mph I go the same speed as lorries on the road, so if the speedo is off, it seems to be off by the exact same amount as everyone else's speedo on the road. I will test the top speed with GPS at some point though
February 2nd, 2012, 11:06 AM | #38 |
Check. 0 when your standing still?
February 2nd, 2012, 11:14 AM | #39 |
Instrument cluster standing still can be seen here: http://www.youtube.com/watch?v=YdFJTXGoBmo - stays firmly on 0
February 2nd, 2012, 12:05 PM | #40 |
Close to sea level taking the snorkel off is probably not neccesary. If you're high above sea level it might help though.
Any idea how high you are? Also - your bike is still pretty low on kms, might loosen up a bit over time and get more speed out of it. --- I've got no idea what my top is Cruised pretty well at 140km/h indicated, although I needed a bit of a downhill to get to 160km/h. I'll take it on the highway again sometime after I've done the 15000km service. |
[roadracingworld.com] - Pedrosa Goes 216.858 mph, Sets New MotoGP Top Speed Record Fo | Ninjette Newsbot | Motorcycling News | 0 | August 10th, 2014 07:40 AM |
[roadracingworld.com] - Pedrosa Goes 2016.858 mph, Sets New MotoGP Top Speed Record F | Ninjette Newsbot | Motorcycling News | 0 | August 10th, 2014 06:50 AM |
[motorcycle.com] - 2014 Vectrix VT-1 Electric Scooter Boasts 62 MPH Top Speed | Ninjette Newsbot | Motorcycling News | 0 | November 1st, 2013 07:20 PM |
[motorcyclistonline] - SWIGZ Electric Motorcycle Achieves Top Speed of 190.6 MPH And | Ninjette Newsbot | Motorcycling News | 0 | April 11th, 2011 02:20 PM |
[roadracingworld.com] - Hayabusa Streetbike Sets Top-Speed Record At 272.340 mph On M | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2010 01:10 PM |
