Old October 25th, 2011, 06:14 AM   #1
Seattle_Chris
Newb since 10/2009
Seattle_Chris's Avatar
Motorcycle(s): 2009 SE. Slowly morphing to ADV bike. :D
Engine clunking, knocking under load.
Yep, I STILL suck at searching. I'm sure I've seen this before, so if you could just point me to the right link I'd very appreciative. Or, we could just start a new thread.
Ok, so I just verified this week. Yesterday and today to be exact. I have a pretty hefty Clunking coming from my engine when I abuse it with too much load. Such as starting up a very steep incline from a full stop. Or compression breaking at too low of RPM's (3k) or so. Along with the sound there is jerking. Feels kind of like it's running on 1 cylinder when it happens.
I'm thinking time to read up on Valve clearances/adjusting. Thinking a valve may be too tight/loose. But could it be something else? At first I was thinking fried valve, but it's only under heavy load. On the freeway it's fine. Though I THINK I can hear it tapping under heavy load around the town, so it's probably happening sometimes on the freeway too I suppose.
Anyway, any ideas?
Thanks in advance!
Seattle_Chris is offline   Reply With Quote
Old October 25th, 2011, 06:36 AM   #2
Seattle_Chris
Newb since 10/2009
Oh yeah, 2009, about 9.5k miles. Had factory maintenance at 7.Xk including valves. I think it was pretty close to 8k. Nothing changed on it lately except for a couple months ago, I cleaned and adjusted the chain.
Hmmm, wait a minute. I DID put in some Stabil with my last fill up a week or three ago. Didn't really measure. Just put in 2 doses from the funky dose meter thing. Would too much Stabil do this?
Old October 25th, 2011, 05:04 PM   #3
I wouldn't think Stabil would be related to clunking, but .
Old October 27th, 2011, 11:36 PM   #4
Jiggyfly
Motorcycle(s): 2008 Kawasaki ninja 250
I'd check that chain, almost sounds like a chain skipping teeth, or even a sprocket missing teeth.....yes, I've seen it. Even on a brand new sprocket with 2 track days on it. (NOT mine!)
Jiggyfly is offline   Reply With Quote
Old October 28th, 2011, 08:02 PM   #5
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Verify the engine mounts are torqued to spec. They may not be severely loose but enough for the engine to shift around when under load.
I have seen it happen in cars during my time as a mechanic.
LoD575 is offline   Reply With Quote
Old November 3rd, 2011, 05:43 AM   #6
DaBlue1
DaBlue1's Avatar
Anyway, any ideas?
Thanks in advance!
What do you mean "under heavy load" ? At what rpms are you getting clunking and what gear are you in? The Ninja does not posses a lot of power down low and really hates rpms under 4k. You can not crack the throttle on the Ninja at low rpms and get high torque. Engine clunking and chain clunking sound really different and should be easy to identify. Check your proper chain tension. Also if you were running on one cylinder you would be able to tell it at idle.
Old November 4th, 2011, 01:33 AM   #7
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
Give it more gas/clutch/rpm and stop lugging it....jus sayin.
2001 SP1 RC51- #62 -Akrapovic Ti, PCIII, Colin Edward's first baby tooth, Honda Racing sticker, some Japanese doods best attempt at Engrish scribbled on my engine block, little touch of soul.
DarC is offline   Reply With Quote
2012 NINJA 250 Engine Knocking/rattling? drosvil 2008 - 2012 Ninja 250R Tech Talk 7 July 28th, 2014 12:13 PM
Clunking Engine, maybe something else? Corona 2008 - 2012 Ninja 250R Tech Talk 36 April 6th, 2013 03:41 PM
Engine knocking noise vinnyirl 2008 - 2012 Ninja 250R Tech Talk 11 March 8th, 2013 12:33 PM
Engine Knocking Noise (w/Video) simmr 1986 - 2007 Ninja 250R Tech Talk 16 July 30th, 2012 01:48 PM
Engine knocking? hoodadooda 2008 - 2012 Ninja 250R Tech Talk 12 January 20th, 2012 01:35 PM
