Old August 30th, 2009, 04:32 AM   #1
KELPHYN
KELPHYN's Avatar
Talking Mods, how did they help?
Okay I sure this has been discuss already but I can't seem to find the answer I'm looking for. "Exactly how did the mods affect performance" Did they make a noticable difference or not? Did top speeds improve? I guess what I'm looking for is if there was any real noticable difference in the upper roll on range. Primarily from 140km to 160+. My bike is stock except for 15 tooth front sprocket. I know everyone talks about shimming and I know what that is. It's just my bike pulls cleanly to redline with no noticably flat spots and plugs show the proper colour, not lean not rich, so I don't know if shimming will do anything. I know quite afew of the members here have done this and was wondering if it was to cure flat spots or just a performance gain. Also did adding a pipe make that much of difference in top end roll on. I realize these are only 250's and it's not going to pull my arms out of their sockets, that's not what I was looking for when I picked this bike. Overall I am quite happy with the performance but a little extra passing power would be nice. Any response would be appreciated
Old August 30th, 2009, 05:27 AM   #2
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Shimming the needles made the bike actually respond to twisting the throttle, especially when leaving from a stop. When I first rode the bike I was amazed that Kawasaki would sell a bike with throttle response this bad. I tried one, two and three washers and two performed the best. The following day, I drilled the slides and this made a bit of difference in how quick the bike initially responds to twisting the throttle. This is with a stock exhaust system, stock air filter and removed snorkel. The only other power mod I've done is red wheel stripes which add 5-6 rwhp. The other mods were just makin the bike suitable for going around corners.
Old August 30th, 2009, 07:24 AM   #3
noche_caliente
noche_caliente's Avatar
the exhaust you choose may make a noticeable difference - the Area P full system has a very noticeable impact from the reports that I have seen - check out their website for the dynos and do a search on here to see folks responses... it also seems that replacing the CDI with a pre-gen model is having a nice effect as well.
Since you've been searching, you've probably already seen these threads, but just in case, since they're somewhat relevant and actually active right now:
http://www.ninjette.org/forums/showthread.php?p=22910
http://www.ninjette.org/forums/showthread.php?t=27207
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 30th, 2009, 08:29 AM   #4
Momaru
Momaru's Avatar
Somewhere around here was a chart of how each of the various needles/jets affect your bike's power band (ie, what's responsible for giving fuel to your bike at a particular RPM). Someone with a better memory could probably dig it up.
Proud member of the Blue Army
Old August 30th, 2009, 07:25 PM   #5
KELPHYN
KELPHYN's Avatar
Lightbulb
Thanks for the input so far. Guess I'm just trying to decide if it is really worth the $$ for a pipe and don't really want to mess with the jetting as it seems pretty spot on for the area that I ride, ei: starts easy, warms fairly quick depending on temperature, pulls descent from 4500rpm to redline. Just looking for that little more. Oh well, possibly a winter bike fever decission.
Mods Old Lemon 2008 - 2012 Ninja 250R Farkles 20 May 5th, 2012 12:37 AM
First Mods FoxRacerX78X 2008 - 2012 Ninja 250R Farkles 5 April 4th, 2012 03:24 AM
Yes or no on these mods? Kerberos General Motorcycling Discussion 19 December 13th, 2011 10:33 AM
Your First Mods N1nja_N00b 2008 - 2012 Ninja 250R Farkles 32 October 6th, 2011 01:52 PM
What are some MUST have mods? aznboi250r 2008 - 2012 Ninja 250R Farkles 11 June 26th, 2011 09:52 PM
