July 29th, 2012, 10:49 AM | #1 |
Join Date: May 2012 Motorcycle(s): ninja 250 r Posts: 48
what slip on exhaust
what slip on exhaust should i get, i was stongly leanign towards a mgp growler but ive heard there just way too loud, i live in uk and the noise law is 80 decibels, im thinking on the hmf exhaust.. thoughts?
July 29th, 2012, 10:58 AM | #2 |
im just gonna tell you because everyone else is gonna tell you...AREA P...and just get the full exhaust but i guess its about what you want...
oh and yeah... http://www.ninjette.org/wiki/Exhaust_Info |
July 29th, 2012, 11:03 AM | #3 | |
July 29th, 2012, 11:05 AM | #4 |
Join Date: Aug 2011 Motorcycle(s): 2009 NinJa 250 Posts: 21
if you have a noise restriction i would go with a two brothers or vince hynes. they are a little more expensive but you can put the restrictor in it.
July 29th, 2012, 11:06 AM | #5 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
If you have a noise restriction, just stick with the stock exhaust. Don't waste your money.
There is no aftermarket exhaust that will meet your 80dB requirement, even with restrictors; the only exhaust that will allow you to pass it is the stock exhaust.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
July 29th, 2012, 11:11 AM | #6 |
i think it is 80 db at idle 80 under high revs is stupid,
July 29th, 2012, 11:15 AM | #7 |
Jigglin' your Jiglets
MOTM - Apr '13
Why not spend $400 to be annoying???
July 29th, 2012, 11:19 AM | #8 |
the only thing i find annoying are 2 stroke mopeds just realy loud hairdyers!!!
July 29th, 2012, 11:26 AM | #9 |
Join Date: Jul 2012 Motorcycle(s): Ninja250r(2012PR) Posts: 86
July 29th, 2012, 11:31 AM | #10 |
From the quick Google searching I did, it looks like the laws where you are located are kind of a mishmash and are subject to where you are riding your bike.
I would say just play it safe and stick to the stock exhaust. It's one less thing the cops can nail you on if they pull you over.
July 29th, 2012, 07:07 PM | #11 |
Join Date: Apr 2012 Motorcycle(s): 2012 Yamaha FZ6R, 2014 Suzuki GSX-R600 Posts: 299
Maybe Akrapovic
July 30th, 2012, 02:06 PM | #12 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
July 30th, 2012, 02:20 PM | #13 |
dont bother with a slipon. if you want a pipe get a full pipe, anything else is just a fart can.
the real question is why do you want it. is it for looks? then buy the shiniest carbon fiber thing with the most recognizable name you can find. the more expensive the better so you can brag about how much it costs. maybe slap a gsxr sticker over the ninja sticker while you are at it. if its about noise, maybe you should instead tape your horn button always on? it will annoy people just as much, and save you just as few times times as a loud exhaust would (zero times). if its about just doing something to your bike... modify the stock exhaust. if you want it for power. a slipon will do nothing. full pipe + jetkit.
July 30th, 2012, 03:26 PM | #14 |
MOTM - Apr '13
If you think you're ninjette sounds like a lawn mower, then you don't know how to ride it
try 12k rpm for once
July 30th, 2012, 07:13 PM | #15 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Slip-On Exhaust | Mrudloff | 1986 - 2007 Ninja 250R Tech Talk | 8 | October 11th, 2014 01:19 PM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
slip on exhaust? | NinjaLINY | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 30th, 2014 07:00 AM |
Looking for a Slip-on exhaust? | mariorivera830 | 2008 - 2012 Ninja 250R Tech Talk | 32 | August 26th, 2012 01:16 PM |
Slip On Exhaust | Little Green Machine | General Motorcycling Discussion | 10 | June 18th, 2012 09:43 AM |
