Old July 15th, 2014, 09:50 PM   #1
Insane Pie
Motorcycle(s): '08 Ninja 250
Changing out the fairing stay. How much of a pain is it to do?
Just got a new fairing stay in hope to fix my fairing alignment issue. I haven't been able to find anything about swapping out fairing stays while searching, but it doesn't look too bad. The only thing that looks like it's going to be a pain is getting the all the wiring and whatnot from between the brackets. Assuming taking a grinder to it won't be the best the idea.
So what's the best way to take this on?
Insane Pie is offline   Reply With Quote
Old July 15th, 2014, 09:58 PM   #2
Brian
Brian's Avatar
Motorcycle(s): 08 250R
Honest to god it is a pain in the butt. I broke about 4 of the fairing 'stay' pieces simply trying to yank the thing out of place. The little black circle ones that attach the two cowlings together (on the bottom) are also a little figgidy. Make sure to stay organized when removing all of them and remember what goes back where (take pictures). The wiring isn't fed through the plastic, it's only held on by just being wrapped around some little plastic catches on the fairing, you will see them when you pull it off. The only thing in the way is the indicator which simply disconnects.
The most dangerous risk of all is the risk of spending your life not doing what you want...
Brian is offline   Reply With Quote
Old July 15th, 2014, 10:21 PM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I took a bolt cutter to mine in order to remove the wiring from within the brackets. Removal was fairly straight forward after that since I had the entire front removed anyway.
Replacing the stay was just the reverse. I had to clip the bracket again the replace the wires and then reconnected it with some thick heatshrink over both halves. I did clip the top to not have the wires cause strain on the bracket.
If someone has an easier solution I am interested as well.
<-- Linky
Old July 15th, 2014, 10:27 PM   #4
Insane Pie
I acutally lost the black pieces, so those won't be too much of a problem. Haha.
I was just thinking about bolt cutters, but wasn't too sure how effective they would be.
Since you clipped the brackets, you didn't have to remove any wires, right? As in not unplug anything
Old July 15th, 2014, 10:51 PM   #5
NevadaWolf
NevadaWolf's Avatar
Nope, nothing unplugged. Wasn't that confident at the time to try removing the wires so just removed the stay from around them.
Er was it a bolt cutter? Now questioning my memory. I know we cut it just suddenly not sure how. May have been a Dremel with a cutting wheel. Err...
<-- Linky
Old July 17th, 2014, 05:12 AM   #6
Insane Pie
Hmmmm..I'll just have ti see what work
Old July 19th, 2014, 06:38 AM   #7
robbyz
robbyz's Avatar
Motorcycle(s): 2009 ninja 250
Changed mine,easy.Cut the bracket stay harness on both .
Bend the piece enough to get cables in and bend it back,done.
robbyz is offline   Reply With Quote
Old July 19th, 2014, 07:33 AM   #8
Insane Pie
What did you cut it with?
Old July 19th, 2014, 09:52 AM   #9
robbyz
robbyz's Avatar
Cutting wheel,bolt cutters will work,talking about the cable holes on each side of stay.
Fairing Stay? N_hutter 2013 - 2017 Ninja 300 General Discussion 1 May 22nd, 2014 07:41 AM
Fairing stay alternatives Greenlawnracing 2008 - 2012 Ninja 250R Tech Talk 5 January 5th, 2014 09:19 PM
09 upper fairing stay jays1 Items Wanted 0 May 29th, 2013 09:16 PM
Changing 2009 SE fairing to 2008 etiainen 2008 - 2012 Ninja 250R Farkles 20 August 21st, 2011 12:56 PM
