Old June 10th, 2022, 08:48 PM   #121
punishum808
punishum808's Avatar
Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250
More custom parts.
My buddy from Mullaney Cycle Works is cutting some custom triple tree tops.
Mike was the chassis fabricator for Vance and Hines. He built all the team bikes. Now he has done the bikes for Bostick, Phillips and Oehler. He does grudge, pro mods and more.
We may offer some of these custom pieces to others if the interest is there.
punishum808 is offline   Reply With Quote
Old June 16th, 2022, 06:37 PM   #122
punishum808
So changes were made to make the clamping bolts on the bottom. For anyone who has converted to clip ons they will know why.
Old June 19th, 2022, 06:08 PM   #123
punishum808
Fabricated the fairing support cage.
Old June 25th, 2022, 02:26 PM   #124
punishum808
Aloha,
So we had a little guest checking out what we were up to. A Gecko, 'NOT' to be confused with the one on TV.
Till next time ALooooooHA 🤙🏽
Old November 13th, 2022, 09:02 PM   #125
punishum808
*** ALoooooHA ***
How are yall doin?
Just got back to button things up.
We just got through with the exhaust tip.
Old November 13th, 2022, 09:03 PM   #126
punishum808
*** Mahalo WWB ***
World Wide Bearings are simply the finest bearings in the world.
The WWB Hybrid Ceramic bearings provide weight savings of up to 60% verses OEM which equals pounds when you add it all up, less friction and rotating mass is lessened where it counts the most.
World Wide Bearings, when only the 'BEST' will do.
Old November 13th, 2022, 09:07 PM   #127
punishum808
Trying to button things up by December as I have been busy in politics. The hard work paid off as I will now be the Office Manager / Chief of Staff for a legislator.
So hopefully there will be swift progress on this build and a dump load of updates before the Motortrend airings in Q1 of 2023.
As winter approaches for many of you on the BIG rock Happy Holidays will soon be upon us.
So till next time, ALooooHA, Book UM Danno.
Old November 15th, 2022, 05:51 PM   #128
Awesome work!!!
Old November 16th, 2022, 11:13 AM   #129
punishum808
Awesome work!!!
Mahalo Danno, We Booking UM
Old December 27th, 2022, 03:07 PM   #130
punishum808
Mahalo to Ducatiman for getting my carbs sorted out. Will be sending him my dragbike carbs that i will be using on another build.
Hauoil Makahiki Hou and a prosperous and healthy 2023 to y'all.
ALooooooHA
Last futzed with by punishum808; December 27th, 2022 at 11:21 PM.
Old December 27th, 2022, 06:57 PM   #131
Ceeloo Yello
Motorcycle(s): 250
Congrat on the political position.
Old December 27th, 2022, 11:21 PM   #132
punishum808
Mahalo
Old February 4th, 2023, 11:51 PM   #133
punishum808
*** ALooooooHA ***
So as more parts trickle in here is one upgrade that is a must.
2 vs 4 pistons.
Till next time MAhaaaaaaLO and Book Um Dano
Old February 18th, 2023, 11:51 AM   #134
punishum808
ALooooHA
So got a little more work done and parts coming in.
Definitely titanium.
Book UM Danno, Speed Safely
Old February 18th, 2023, 12:17 PM   #135
Four pistons of a given diameter acting directly against the disk exert the same clamping force as two pistons of that same diameter, acting against the disk and the other pad, like the stock calipers.
Old February 18th, 2023, 02:06 PM   #136
punishum808
You build things the way you do and I will do my builds.
Apparently you have not followed the build and only saw this latest post.
Go Troll elsewhere.
Old March 26th, 2023, 10:26 AM   #137
punishum808
ALoooooHA,
So the motor was in rough shape aesthetically.
Old March 26th, 2023, 10:27 AM   #138
punishum808
So I steam pressure washed, prepped and masked.
Last futzed with by punishum808; March 27th, 2023 at 02:11 PM.
Old March 26th, 2023, 10:28 AM   #139
punishum808
Then applied some hi-temp engine paint.
Old March 26th, 2023, 10:32 AM   #140
punishum808
Every nut, bolt or fastener will be an AN, titanium or converted to aluminum bolt or nut.
Nearly $2,000 in titanium or aluminum nuts and bolts. Axles, swingarm pivot, motor mounts will ALL be titanium or custom made 7075 billet.
A 415 conversion.
All of this will reduce the weight by another 13 pounds.
Old March 26th, 2023, 10:34 AM   #141
punishum808
Custom lines to add in an oil cooler.
So till next time.
Book UM Danno . . . ALooooooooHA
Old April 3rd, 2023, 06:42 PM   #142
punishum808
ALoooooHA,
So been racking up the titanium bolts count. The weight differential is significant.
Old April 3rd, 2023, 06:43 PM   #143
punishum808
And it adds up when you are changing out every nut or bolt for weight savings.
Old April 3rd, 2023, 06:45 PM   #144
punishum808
When i began racing in 1985 if u told me that i would have a case of titanium fasteners i would have 🤣😂😂 because back in those days it was Un-Obtanium due to costs and unavailability.
The CASE weighs more.
So till next time keep it off the street and 'Speed Safely' ALoooooHA, Book UM Danno.
Old May 1st, 2023, 11:10 AM   #145
Guaire
ALooooooHA
On the silencer, is it hi temp paint or an industrial coating?
Old May 1st, 2023, 02:16 PM   #146
punishum808
Which one?
Old May 1st, 2023, 02:18 PM   #147
punishum808
ALoooooHA . . .
So some work has been done.
Got back the carb pieces from powder coat.
Old May 1st, 2023, 04:22 PM   #148
Guaire
ALooooooHA
The one in the picture on this post.
Old May 2nd, 2023, 11:57 AM   #149
Project coming along nicely!!
When i began racing in 1985 if u told me that i would have a case of titanium fasteners i would have ������ because back in those days it was Un-Obtanium due to costs and unavailability.
heh, heh... back then, primary consumer of Titanium in U.S. was military. Products were made with mil-spec certifications* needed, so costs was exorbitant. Meanwhile, in USSR, anyone can walk into hardware store and buy Titanium shovels and fasteners!!! It's one of most abundant ores on planet! Although most of it is used to make white paint pigment.
I was managing bicycle-shoppe back then and was quite excited about relaxation of Cold War and many military suppliers branched out to private-sector with their titanium products. Suddenly titanium bike frames because much more reasonably priced!
* While at university in Santa Barbara, I was involved with firm contracted to provide picnic benches to Vandenberg AFB. They were to be deployed on hillside to watch missile launches, so had to be tested and certified for:
- altitude
- weather-resistance: sun-exposure, fog/dew, rain
- longevity: materials, prep and coatings guaranteed for 20-yr lifespan
In end each bench was billed at $45K apiece! They were off-the-shelf items from local home-improvement centre. But due to all testing and certifications involved: atmospheric chambers had to be built, jigs, numerous instrumentation and datalogging equipment, it drove amoritised price per item through roof! And to cover costs of 20-yr warranty.
Old May 2nd, 2023, 02:51 PM   #150
punishum808
- altitude
ALooooHA my friend, so glad you are still around. Yes on Ti- we called it Un-obtanium back in the day AND you had to re do the thread pitch to match so it meant going bigger.
Old May 2nd, 2023, 06:26 PM   #151
punishum808
In that pic it wasn't any coating or paint. We just got it back from the welder where he helped to take care of the flaws.
Last futzed with by punishum808; May 21st, 2023 at 09:03 PM.
Old May 2nd, 2023, 06:29 PM   #152
punishum808
Soooo . . .
Weight is key on a bike. When you can shave 60% of the weight vs OEM times 120 nuts and bolts that is where things will pay off. Thus the word PAY cause it ain't cheap.
Old May 4th, 2023, 05:28 PM   #153
punishum808
Every nut or bolt has been converted. Even on the carbs and with clear float bowls.
Old May 8th, 2023, 03:37 PM   #154
punishum808
And here are the carbs thanks to Ducatiman.
Old May 11th, 2023, 01:44 PM   #155
punishum808
More powder coated pieces and reassembling the motor.
Old May 20th, 2023, 01:52 AM   #156
punishum808
ALooooHA
We been slowly getting back parts and pieces.
Here are the rearsets, reservoir delete, the coated megaphone and every nut and bolt is titanium or custom billet aluminum.
Everything was shortened and customized to all lineup for that MotoGP look.
Old May 21st, 2023, 07:49 AM   #157
Guaire
*** Mahalo WWB ***
Good to know. Sometimes bearings are where someone decided to save money.
Old May 21st, 2023, 08:43 PM   #158
punishum808
Its amazing how smooth they are. You can feel / see it when you just spin it by hand and it just keeps going and going.
Old May 31st, 2023, 11:13 AM   #159
punishum808
The mock up of the motor. Every nut or bolt is aluminum or titanium.
Old June 2nd, 2023, 11:18 PM   #160
punishum808
More pics of the motor coming back together.
The clear float bowls from Japan and every bolt has been changed out to an aluminum bolt.
[webbikeworld.com] - Harley-Davidson Announces New Parts for Customizing You Bike Ninjette Newsbot Motorcycling News 0 March 19th, 2020 07:30 AM
[motorcyclistonline] - Harley-Davidson Custom Kings Dealer Customizing Contest: Sport Ninjette Newsbot Motorcycling News 0 March 1st, 2016 10:21 AM
Customizing Accessories bbbrandy19 General Motorcycling Discussion 12 March 24th, 2011 10:13 AM
