Old December 27th, 2008, 05:28 PM   #1
g21-30
g21-30's Avatar
Left Turn Signal - Bad Connector
Are any of you having problems with the rear turn signals after your fender chop? The last few rides, my left rear signal has been failing during the ride. Failure meaning lights are not flashing, which usually means a bulb is burned out. Bulbs are fine and it's not the flasher, since the same flasher is used for both the right and left turn signals.
Each time this occurs, I remove the seat and jiggle the connector for the left side. The signal starts working. It did it again today, so I checked the voltage at the bulb....zero.. Removed the seat and jiggled the connector...it worked. Tug on the wire, it continued to work. Jiggle the wires, it quit working. It has something to do with the connector!
I am real close to replacing the connectors with a connector like the Battery Tender uses. Anyone else had this problem?
Thoughts?
Old December 27th, 2008, 05:42 PM   #2
I haven't had a problem.
Try switching the left and right blinkers at the connectors. If the problem moves to the other side, the broken wire is from the connector to the blinker. If the problem stays on the same side, the problem is in the main harness leading up to the connector.
My guess is that it's going to be a connector pin that's barely hanging on to the wire somewhere or the contacts in the connector "pins" themselves are not spread wide enough to make good contact with the other side pins.
Old December 27th, 2008, 05:49 PM   #3
g21-30
g21-30's Avatar
This is exactly what I'm thinking. I like the idea of swapping the sides.
Thanks
Old December 30th, 2008, 11:18 PM   #4
You fix the problem?
Old December 31st, 2008, 05:14 AM   #5
g21-30
g21-30's Avatar
It was fixed, prior to your suggestion of swapping sides. It was the connector leading to the bulb. I wedged the tip of a wooden tooth pick beside the terminal. This stopped the movement and it's working fine.
Old December 31st, 2008, 11:14 AM   #6
Cool... I had a similar problem the first day I brought my bike home. The left front turn signal wouldn't light. It turned out to be the center prong in the socket not being bent out enough to make contact with the bulb base. Bent it out a bit and it's been good since.
thanks for the follow up.
Old December 31st, 2008, 12:32 PM   #7
g21-30
g21-30's Avatar
kkim...Thanks for asking!
Left turn signal lights up both sides onepeon 2008 - 2012 Ninja 250R Tech Talk 2 October 14th, 2016 12:05 PM
Front Left turn signal, 08-12 pop0tart Motorcycle-related 0 June 1st, 2014 04:24 AM
2008+ left front turn signal Riverdale Items Wanted 3 August 31st, 2013 09:31 AM
2008 Ninja 250r Turn Signal Connector locations Sigma.40 2008 - 2012 Ninja 250R Tech Talk 20 April 10th, 2012 11:09 AM
Left Footpegs bracket and turn signal HeteronimoFD Items Wanted 2 June 8th, 2010 01:29 PM
