Old January 10th, 2009, 07:57 PM   #1
Sailariel
Sailariel's Avatar
Chain question
The 08-09 Ninjette takes a 106 Link O Ring chain--a 520SR, to be exact. I have been reading my shop manual, and the chain removal process is quite elaborate--necessitating the removal of the swingarm, shock, etc. Sounds pretty elaborate to me, not to mention labour intensive. Is there any reason that the chain to be replaced cannot be broken with the proper chain tool, that a master link be added, the new chain be pulled through, and then put together with the appropriate master link? On the older bikes I have ownrd in the past, that was the procedure. Is there a particular reason that Kawasaki wants you to use a "continuous" 106SR O ring chain? Can a 520 X ring chain be used on the Ninjette?
Old January 10th, 2009, 08:08 PM   #2
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
just cut it or break it with a chain tool. i've used a dremel to grind links off before.
if you're replacing it then get a rivit tool so you have a good masterlink on there. if you don't have a rivit tool, then get it all together, put your bike in the back of the truck and go to your local MC shop and see if you can get someone to do it real quick.
you can use the clip style link, but they're not really the safest thing to use on the street.
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old January 10th, 2009, 08:46 PM   #3
Sailariel
Sailariel's Avatar
Broome, Thanks for the comeback. I`ll get a rivet tool for the 520 chain. I have one for my bicycles and use it all the time. An MC chain can`t be that difficult. I really needed to know if the Quick Links they sell are safe--and appearantly they are not.
Chain Maintenance Question dcj13 General Motorcycling Discussion 10 January 27th, 2014 04:08 PM
Chain Question checho323 General Motorcycling Discussion 21 December 21st, 2012 10:36 PM
Chain question RyderRider15 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2012 09:16 PM
Question about the chain... Cookie Monster 2008 - 2012 Ninja 250R Tech Talk 10 August 10th, 2012 04:03 PM
Another Chain Question Sailariel 2008 - 2012 Ninja 250R Tech Talk 2 January 20th, 2009 05:30 PM
