Old June 21st, 2009, 05:18 PM   #1
250fan
Motorcycle(s): '09 250r
Rattling Noise from 8-9k RPM
Hello Guys and Gals....long time lurker, first time poster. Well, to start, I have a 2009 Ninja 250 (blue if it matters ) with 900 miles on it. Ever since I bought the bike new, there has been a rattling noise from 8-9k RPM. While it doesn't happen every time taking it past 8k or holding it steady at 8k, it happens more often then not. It sounds like it is coming from the engine yet the engine runs strong. It only happens in this RPM range and it doesn't matter what the load is on the engine.
I searched for this issue over here and at kawiforums and it looks like this post here has the same issue http://www.kawiforums.com/ninja-250r...e-noise-2.html However, there was really no response on what the noise was or the fix.
So, my question is any ideas on the noise? Is it normal? MY dealer went out of business shortly after i bought the bike and the nearest one is 100 miles away. I have the service manual and mechanical knowledge so I'm not afraid of working on the bike. Can the camshaft chain be checked or tightened? Thanks all
250fan is offline   Reply With Quote
Old June 21st, 2009, 05:25 PM   #2
hold the clutch lever... does it still make that noise?
does it make it in neutral as well as in gear?
Old June 21st, 2009, 05:25 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Hi Greg! Welcome!
My guess, and it is purely a guess is that it's some of the plastics rattling. That 8-9k range is where it hits resonance - if you notice if you hold it there your ears will start ringing too.... I think that there's probably something loose in the upper fairing that just starts to vibrate when the engine hits that frequency.... but again, that's just a guess...
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 21st, 2009, 07:55 PM   #4
Rawr
Blue Blue Blue
Rawr's Avatar
Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R
i have a similar noise on my 2008 (also blue) not sure if it is the same rpm range...but i have noticed that as i throttle up...sometimes there a strange rattling noise...almost like keys jangling...ive tried to listen where it comes from but not sure...i almost think it is coming from the suspesion but again im not sure
Rawr is offline   Reply With Quote
Old June 21st, 2009, 08:00 PM   #5
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
i feel it on my legs (pressed against the tank) and ass when i hit the resonance frequency. ive noticed this on practically any bike that ive ridden, they all have a certain RPM frequency when all the parts like to dance, and if anything is loose, and able to rattle, it will be audible.
so far my 250r has no rattling, but i wont be overly surprised if it were to start eventually. the wear and tare of the engine vibrations will eventually loosen some parts of the fairing, which is probably the number 1 cause of rattling.
wayanlam is offline   Reply With Quote
Old June 21st, 2009, 08:19 PM   #6
CANTFUNCTION
CANTFUNCTION's Avatar
Motorcycle(s): 09 ninja 250(red)
Mine does it at 10K. When I took in to the dealer for the 4000 miles maintain they said it was normal. I had them put down on paper just incase.
CANTFUNCTION is offline   Reply With Quote
Old June 21st, 2009, 08:22 PM   #7
250Rocket
250Rocket's Avatar
Motorcycle(s): '09 Ninja 250R
Mine happens from 5.5-7k. It's the windscreen hitting resonance.
Back on the road again Season 2010 Dam it feels good!
250Rocket is offline   Reply With Quote
Old June 21st, 2009, 09:11 PM   #8
Tubesock
Tubesock's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
I agree with 250rocket, mine did that and i couldnt figure it out until one day something possessed me to grab the windscreen when it started to happen and it stopped.
"When I die I want mud on my jump boots, magazine empty, and barrel hot."
Tubesock is offline   Reply With Quote
Old June 22nd, 2009, 09:49 AM   #9
CodE-E
Ninja Newbie
CodE-E's Avatar
Motorcycle(s): EX250K9
Mine also starts ringing at around 8-9k RPM. I also think it's just some piece resonating. I thought it might be the keychain, but I'm not sure. I'll try listening carefully if it happens when I'm stationary and revving in neutral...
CodE-E is offline   Reply With Quote
Old June 22nd, 2009, 12:15 PM   #10
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
i would check all screws to make sure all is tight. If any are loosened that part might rattle and make noise.
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old June 22nd, 2009, 12:28 PM   #11
Snake
Snake's Avatar
I had that same noise and it turned out the clutch lever was loose. Tightened the clutch lever and the noise whent away.
Old June 22nd, 2009, 02:20 PM   #12
demp
I have had this happen too, I'm pretty sure its the black plastic under the front fairring for me, I think I stripped the inside of the plastic that the screw sits in, any bright ideas on an easy fix?, aside from loctiting it alltogether?
Old June 22nd, 2009, 11:37 PM   #13
mista350z
Motorcycle(s): 08 CBR600rr, 08 Ninja 250r - sold
I have that rattling noise too around that range. I tried to look around but did not see any loose screws. Mine seems to be coming from somewhere in the front as well. I am thinking it could be the windscreen as well.
mista350z is offline   Reply With Quote
Old July 1st, 2009, 08:03 AM   #14
250fan
All,
Thanks for the help and ideas. I just finished the 600 mile service and checked the tightness of everything. There was nothing loose, but I did notice that the emissions box on the left side of the motor is supported by a single bracket that is not very rigid. It also near the motor/frame and I believe this is where the noise is comming from as I bent the bracket away from the frame and it hasn't made the noise since. Not everyone may experience this as it's a California model. Also, It seems like how they mounted it was an after thought as well.
Old July 1st, 2009, 08:22 AM   #15
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
The plastic likes to rattle under the headlights where it meets the 2 side fairings (pointy part). I wedged a little rubber parts in between to dampen it.
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old July 7th, 2009, 07:18 PM   #16
JaeL
Bike Thrasher
JaeL's Avatar
Motorcycle(s): 2008 EX250r
+1
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns
JaeL is offline   Reply With Quote
Old July 8th, 2009, 07:37 AM   #17
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
same here, especially noticable when decelerating
Old July 8th, 2009, 07:43 AM   #18
tjkamper
tjkamper's Avatar
Try a larger, selftapping screw.
Old August 1st, 2009, 10:05 PM   #19
250fan
Thumbs up
+2....bingo....tested my touching the clutch lever when it was making the noise and it stopped immediately.....Fixed by tightening it down!!! Saaaweeet!
Old August 1st, 2009, 10:36 PM   #20
lol... did you read post #2?
Old August 1st, 2009, 10:52 PM   #21
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
Mine does the same thing, I only notice it on short trips when I don't wear ear plugs, I just think of it as one more reason to use hearing protection.
Cedilla is offline   Reply With Quote
Rattling noise from the engine.. paterick4o8 2008 - 2012 Ninja 250R Tech Talk 15 February 9th, 2021 08:16 PM
Rattling Noise hieuster 2008 - 2012 Ninja 250R Tech Talk 12 July 3rd, 2013 11:13 PM
Sharp Rattling(sorta) Noise Problem Postiez 2008 - 2012 Ninja 250R Tech Talk 6 August 23rd, 2009 08:00 PM
knocking or rattling noise tinng321 2008 - 2012 Ninja 250R Tech Talk 12 May 31st, 2009 09:51 AM
So I'm hearing a rattling noise from my engine ARc 1986 - 2007 Ninja 250R Tech Talk 25 May 11th, 2009 06:06 PM
