Old May 20th, 2016, 05:58 PM   #1
knightdalton
Motorcycle(s): 98 kawasaki ninja250r
How to bypass ignition
I have a 88 ninja 250 it has a 7 pin connection to the key red, grey, white with black, white, white and green, brown, blue. How do I connect the bike so I can make it to a switch or to have the engine on and off switch on the handle bar turn it on?
knightdalton is offline   Reply With Quote
Old May 20th, 2016, 09:01 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
88 or 98? Your previous posts said 98 and one said 97.....
Goin' fast on slow bikes!
Old May 21st, 2016, 06:29 AM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The wiring diagram has a chart showing the ignition switch connections. https://www.ninjette.org/forums/show...75#post1096775
Old May 22nd, 2016, 08:36 AM   #4
knightdalton
My bad I hit the 97 it's a 98
Old May 22nd, 2016, 10:49 AM   #5
knightdalton
I know I have one but how do I mod it tho is what idk how to do
Old June 21st, 2016, 07:01 PM   #6
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
i need too , did you find a solution ?
juliusmichaelhonrada is offline   Reply With Quote
ignition bypass? 100ohm resistor JarodVoss 2008 - 2012 Ninja 250R Tech Talk 11 June 30th, 2022 06:11 PM
seat lock bypass kslane 2008 - 2012 Ninja 250R Farkles 2 August 18th, 2013 06:03 PM
Radiator Bypass fan switch issue FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Farkles 5 October 2nd, 2012 09:42 AM
Oil Filter Bypass Valve Boom King 2008 - 2012 Ninja 250R Tech Talk 2 November 26th, 2010 06:15 PM
Hoover Dam Bypass Bridge HKr1 Off-Topic 9 October 24th, 2009 02:20 PM
