Old March 25th, 2011, 04:02 PM   #1
speedgsx98
Motorcycle(s): 250 ninja 2002, 2008 ZX10-R
$15 ZX-6R LED Flush mounts/integrated tail mod/mini-mirrors & fender chop =)
OK, so at least today, D2moto.com is doing their 40% off with code WS40. Enter it in and both these parts come to around $15 plus shipping.
I just bought this 2007 ninja 250 used last week and threw on some Volar Motorsport mini mirros as well that I had laying around. I don't recommend them as they give you a horrible/unusable view...but they do look cool. I turn my head anyway. If you do decide you want some of these which are also sold on D2Moto's site, you'll need some micro sized open end/boxed end 10mm wench and some patience as the area is VERY hard to get to...trust me. If you want more details on the mirrors...pm me. They are not convex but a flat mirror and they're 3-4 times smaller than the OEM mirror. But I changed them out for vanity's sake and to give me better clearance when lane splitting.
http://www.d2moto.com/showproduct.as...signals-lights
http://www.d2moto.com/p-7046-1994-20...h-signals.aspx
Now, here's some pics. Went from standard OEM signals to these. You have to cut out a fingernail size hole behind the OEM fron signal cutout...you'll see in the pics below.
with the OEM signal out:
you can see the backing piece is too large in diameter to fit behind the signal at the moment:
Grind it down on some concrete =)
And you end up with this!
You'll want to take a soldering gun or silicone or some sort of something to keep the signal from unthreading due to vibration and coming off while riding. I used a soldering gun to melt a little bit of plastic together here:
This is what needs to be cut on the fairing...about a thumbnail sized piece to make way for the threaded part of the LED turn signal:
And here's what the other side looked like after it was cut. I used a hacksaw blade on it's own, not in the hacksaw, and then a razor blade to skor the last bit then pop it out...careful not to cut yourself
Drumroll please!!!!
And now some more pics of the tail before:
And after:
And the whole bike with the new mirrors, frt/rear signals and fender chop. removed reflectors...
The mirrors from the cockpit view:
At first I thought my signals were going to flash at double speed. But once I soldered them in, they're flashing at normal speed unlike some other bikes I've had that I've run LED's on. Not bad for a bike I got for $1,260 with 6k miles eh? I will admit it looks better in the pics. It does have some rash that is thankfully not all that visible due to the black color scheme.
90 EX250 Ninja, 92 FZR600, 86 CR125, 77 GS750, 73 RD350, 86 CR250, RD350 in SRX250 frame, 75 RD350, 99 RM125, 99 GSXR750, 07 Reflex, 02 250 Ninja, 02 GSXR1k, 08 ZX10R, 07 250 Ninja, 05 250 ninja
Last futzed with by speedgsx98; March 26th, 2011 at 07:34 AM.
speedgsx98 is offline   Reply With Quote
Old March 25th, 2011, 04:49 PM   #2
Those look really good! congrats on making something work. The hyperflash, while attention grabbing, I believe is technically illegal.
http://www.superbrightleds.com/cgi-b...html%23flasher
Get the one that has the proper connector (it's the LF1-S-FLAT) It'll run you like 8.95. Plug and play
Old March 25th, 2011, 07:28 PM   #3
speedgsx98
So, I've soldered everything in cause I hadn't finished yet when I took the photos and it's actually flashing normal speed. So, I'm legal and I saved $8.95 =) But thanks for the link!
Old March 25th, 2011, 08:55 PM   #4
BTW those tires look interesting. What are they?
Old March 26th, 2011, 02:19 AM   #5
Would the 40% have worked on this had it been in stock?
http://www.d2moto.com/p-8224-2008-20...LAID=557052602
Old March 26th, 2011, 07:17 AM   #6
speedgsx98
Tires are Kenda 657 rear and 671 front 120/90/16 and 100/90/16.
Yes, the 40% would have worked. They run sales all the time, but 40% is the most they ever do. I'm on their email list and they do something at least twice a month or more it seems from 20-40%.
Old March 26th, 2011, 12:44 PM   #7
bhalv
Motorcycle(s): 93 ninja 250
looking good man
bhalv is offline   Reply With Quote
Old March 27th, 2011, 09:09 AM   #8
So, what is that coupon good for? Everything on the site? Blinkers only? I have a lot I want to order.
Old March 27th, 2011, 03:58 PM   #9
speedgsx98
^^^Everything provided it's still valid. Try it out! I ordered the Type 1 Volar Motorsport gloves which came out to $24 after the discount. They're very good for the money although the placement on the knuckle protectors isn't spot on, it's good enough for $24. I order a size larger than normal and glad that I did as the larges were snug.
Old March 27th, 2011, 10:19 PM   #10
Thanks. I have to wonder if they are actually out of stock of certain items or they are waiting for the coupon to expire (integraetd tail light comes to mind).
Whole order or single item from an order?
TST Industries Integrated Tail Light, Fender Eliminator & LED Turn Signals NurseWest 2013 - 2017 Ninja 300 Farkles 2 September 1st, 2014 04:01 PM
Flush mounts and fender eliminator stegser 2008 - 2012 Ninja 250R Farkles 7 June 17th, 2014 04:54 AM
Shinto Clip-ons, Bike Monkey Integrated Tail and Proton Flush Mounts Mac Motorcycle-related 9 November 21st, 2010 02:52 PM
[twistingasphalt.com] - Monster Mod #3: BoomTube it Baby… And Chop that Tail too! Ninjette Newsbot Motorcycling News 0 May 31st, 2009 07:30 AM
DIY: Pregen Fender Chop/Flush mount turn signal mod brian997 1986 - 2007 Ninja 250R Tech Talk 8 March 29th, 2009 09:37 AM
