Old August 7th, 2017, 06:29 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
valve cover gasket
Going to adjust valves looking to replace the valve cover gasket anyone know where I could find one cheap went on ebay and lots of different gaskets pop up don't know which one I need
skip is offline   Reply With Quote
Old August 7th, 2017, 08:20 PM   #2
Momaru
Momaru's Avatar
If you're careful, the rubber gasket on the engine top end cover is very reusable. Just need some high-temp silicone sealant to glue it back down to the lower casing when you're done.
Just in case you still want the gasket info though, here's a link to a parts fiche with the right part on the page. It's the bottom gasket, Kawasaki part number 11061-0282
Proud member of the Blue Army
Old August 8th, 2017, 12:35 AM   #3
Use FIPG for that rather than silicone. Yamabond-4 (not 5), Hondabond-4, Permatex Ultra grey, Toyota black, etc.
Old August 8th, 2017, 04:19 AM   #4
Ram Jet
Ram Jet's Avatar
Go to Partzilla.com. they will have the best price. I replaced mine on my 2007 because they were 10+ years old. I used Permatex High Tack on the head and layed the gasket down on that. Don't forget you need the two spark plug valley gaskets also.
Cheers,
Bill
Old August 8th, 2017, 07:51 PM   #5
KikRox
KikRox's Avatar
Motorcycle(s): 2011 Ninja 250r se
i recently ordered the entire gasket set for the valve cover myself along with one float valve needle and it came to $140 CAD.... ridiculous.... Something terribly terribly wrong with that... A bit of lube would have been nice.
They should give me my own section called kik rox is a silly **** who breaks stuff.
KikRox is offline   Reply With Quote
Old August 8th, 2017, 10:59 PM   #6
Ram Jet
Ram Jet's Avatar
You didn't go to partzilla.com did you? I come up with $60.62 USD. Hell, you could have thrown in a pack of KY Jelly and still have been dollars ahead.
Bill
Old August 11th, 2017, 08:12 PM   #7
Momaru
Momaru's Avatar
Thanks for the right listings - been too long since I've done valves since I haven't spent enough time in saddle lately.
Finally looked at my adhesive and it's the Toyota seal packing #103 I've used with my Tacoma as well.
Skip - sorry for the poor choice of words. Hope I didn't lead ya wrong.
Old August 12th, 2017, 01:20 PM   #8
Yep, that's good Toyota FIPG masterial. I use it on engines with metal-on-metal interfaces without gaskets. Oil-pans, balance-shaft housings, cam towers, etc.
I also apply a little when re-using gaskets. Tighten bolts to 25-50% torque and let sealant dry and cure for couple hours. Then torque to final spec.
Old August 18th, 2017, 01:16 PM   #9
KikRox
KikRox's Avatar
Bill
I went through the local stealersh*t... They bend me over every time I see them. I try my best not to ever go there for anything but I was in a rush. Turns out I'm replacing that motor anyways so its of little importance to me now. I guess I have a spare set... I didn't need at rip off prices.
Old August 18th, 2017, 03:36 PM   #10
Ram Jet
Ram Jet's Avatar
I don't get bitten by my stealership. I'm in a hurry for a part, I go there, they have to order it, two weeks, never mind, I order on line. That's only 5 days.
Bill
Coolant drip from the valve cover gasket? Mless5 1986 - 2007 Ninja 250R Tech Talk 26 March 1st, 2017 11:06 AM
Gasket Thickness Valve Clearance HoneyBadgerRy 1986 - 2007 Ninja 250R Tech Talk 4 October 19th, 2015 06:16 PM
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
valve cover gasket drewsley 1986 - 2007 Ninja 250R Tech Talk 8 August 21st, 2014 04:59 PM
cylinder head cover - gasket headshrink 2008 - 2012 Ninja 250R Tech Talk 7 March 7th, 2010 04:22 PM
