Old August 11th, 2017, 05:51 PM   #1
TedBull
TedBull's Avatar
Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes)
Valve clearance range.
I inspected my valves at 8,500 miles and all the exhaust valves are out of spec. All the intake are in spec but on the tight side. I have the hot cams kit and will go ahead and just re shim all the valves I think. My question, is it best to shim to the middle of the specified range or on the loose end?
Exhuast clearance: .007 .011 .008 .006
Existing shims: .112 .113 .113 .110
Intake clearance: .006 .007 .007 .006
Existing shims: .114 .114 .111 .113
Note, all the shims showed slight wear and none of the size markings were legible. Measurements taken with digital calipers.
So who wants to help me figure out the new shim sizes?
TedBull is offline   Reply With Quote
Old August 11th, 2017, 06:33 PM   #2
Flying
Motorcycle(s): 2010 Ninja 250
Its common for folks to set the new clearance a bit loose because wear on the valves decreases the clearance. I personally think that isn't necessary and its just insurance against neglect.
So I'd say set it a little loose, not at the end of the spec, if you know you're not going to be 100% on top of the next adjustment. Otherwise, set it in the middle.
Old August 11th, 2017, 07:39 PM   #3
Flying makes a valid point. I'm a fan of the loose end of spec however. The difference between the tight end and loose end is so small in these engines that any performance difference is probably more in one's head than in reality. I'd much rather have a thou or two extra clearance than have the gap close up and unleash all the starting and warmup difficulties it causes.
Old August 12th, 2017, 04:53 AM   #4
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
do you have a part# for that hot cams kit?
"trying not to get old"
Old August 12th, 2017, 08:09 AM   #5
Ralgha
Ralgha's Avatar
If you have the time to wait for shims, I'd recommend buying the individual ones you need instead of a whole kit. It's a lot cheaper, then only downside is the waiting time involved, since you have to measure your existing shims before you know which ones to order.
I purchased from https://procycle.us/hotcams/valve_shims.htm
Scroll down to the refill packs, it's $6 for a pack of 5 shims, I only needed 3 different sizes for my adjustment, $18 instead of $80+.
Of course if you ride year round, you might not be able to spare the time, I don't ride in the winter, so it wasn't a problem for me.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old August 12th, 2017, 12:27 PM   #6
TedBull
TedBull's Avatar
Hot Cams HCSHIM01
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
What is the Optimal Valve Clearance? krolinked 2008 - 2012 Ninja 250R Tech Talk 2 March 15th, 2013 02:25 AM
valve clearance specs dotsony 1986 - 2007 Ninja 250R Tech Talk 20 March 17th, 2011 02:46 PM
valve clearance??? what are they supposed... ecannon1 1986 - 2007 Ninja 250R Tech Talk 3 May 20th, 2010 10:41 AM
