January 19th, 2013, 11:29 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): 03 ninja 250 Posts: 201
Air fuel mix thumb screw
Did a few google searches and didn't come up with much, basically I've misplaced my springs and orings for my air fuel mix screws. I was just about to drop 15-20 dollars when I was reading over the new cycle gear mag and came across these.
http://www.cyclegear.com/eng/product...rew/web1008828 It says it fits keihin fcr carbs just curious as if these would fit our carbs? Could save me some coin and will be easy to adjust!!! |
January 19th, 2013, 11:41 PM | #2 | |
Fast-Guy wannabe
MOTM - Jan '13
January 19th, 2013, 11:44 PM | #3 |
I think I'm gonna swing by cycle gear tomorrow Nd pick them up and compare... If not, ill just the springs and orings if they fit. If not, oh well
January 20th, 2013, 01:03 AM | #4 |
Join Date: Jan 2013 Motorcycle(s): 90 ninja 250 Posts: 10
after messing with the carbs like crazy those would of been nice to have... u might want to see if u can take one of ur needles with u and compare at the store, and see if they are the same size and look..
January 20th, 2013, 11:31 AM | #5 |
Fcr thumb screws are smaller threads than cvk, no go ;(. Still for 10 bucks I can use the spring/oring.
January 20th, 2013, 02:15 PM | #6 |
Bummer those didn't work out for you.
Helpful suggestion for an adjusting tool: I disassembled a bicycle mulit-tool (about $5 or less) and I kept the flat head tool. It's a metal shaft that's about 2.5" long with a loop in the end. The loop at the end does 2 things 1) it gives me a reference point for how far I've turned the mix screws, and 2) it gives me a little leverage to turn the screws. It's definitely the perfect tool for that (without paying for a right angle screw driver) |
January 20th, 2013, 02:32 PM | #7 |
i went to harbor freight and got a right angled screw driver with flex , u can remove the flex part and attach a extension to it with a screwdriver end and it works great. it takes tips so u can change it to any u want.
November 21st, 2013, 09:37 PM | #8 |
I know this thread is a little dated now, but I did indeed recently find thumb mix screws for our 250r. Factory Pro now sells them. -->Factory Pro fuel thumb-screws
Shipping sucks, so if you haven't already bought a jet-kit, now would be a good time. What does not show in the picture on Factory Pro's site is that part of the end is flattened to serve as a reference mark. This way you you know exactly how far you have turned the screw. It's big enough that you can do it all by feel. I installed mine today and couldn't be happier.
[RoadRUNNER] - Bazzaz Z-Fi Fuel Control Unit and Air Fuel Mapping Kit | Ninjette Newsbot | Motorcycling News | 0 | June 3rd, 2013 11:10 AM |
Stripped fuel bowl screw now what? | Slono | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 19th, 2012 12:38 PM |
[superbikeplanet.com] - From Pre-Mix Fuel To Precious Jewels: Life After Racing | Ninjette Newsbot | Motorcycling News | 0 | March 31st, 2011 04:50 AM |
Wanted: Air mixture screw washers and O-rings | dtmbcorp | Items Wanted | 2 | August 4th, 2010 10:51 AM |
[hell for leather] - Honda CG150 TITAN MIX: world's first flex-fuel motorcycle | Ninjette Newsbot | Motorcycling News | 0 | March 11th, 2009 03:27 AM |
