Old June 29th, 2013, 07:46 AM   #1
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
How to know if spark plugs are tight enough?
How can you tell if the spark plugs are tight enough? I was a bit worried going too tight so I did the 1/2ish turn past finger tight.
If they're too loose will it make a significant/noticeable decrease in power?
They're supposed to be 9.5 ft lbs torque... I have a 10-70 ft lbs wrench, is it safe to turn the dial backwards from 10 a bit and tighten until it clicks? It felt like they were getting too tight and I didn't want to break them. How 'over tight' do you really have to go before breaking? They don't turn easily anymore with a short wrench, but again still didn't click the 'slightly below 10' torque wrench...
Lastly, can I loosen them out again and retorque after driving about 20 miles (they have the metal coating that acts as anti-seize - will that be ruined pulling them out) or if I really feel they need to be redone just pay the $10 for 2 more?
tsdexter is offline   Reply With Quote
Old June 29th, 2013, 07:56 AM   #2
k-os
You're torque wrench is going to be most accurate in the middle of its torque range. I wouldn't trust it set below 10 at all.
Old June 29th, 2013, 08:04 AM   #3
Whiskey
Accuracy slightly outside the indicated torque should be reasonably ok, afaik reputable brands test at 25% outside the marked range, if you have one with a calibration cert it should say what it was tested at, and what it actually torqued
Old June 29th, 2013, 08:22 AM   #4
tubarney
Motorcycle(s): Ninja 250r 2010 SE
You can retorque them as much as you want. Just do them up snug. a 1/4 turn more than hand tight is enough.
tubarney is offline   Reply With Quote
Old June 29th, 2013, 09:04 AM   #5
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
they fall out when they're too loose, just snug them and don't worry about it. a little tighter than a drain plug
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old June 29th, 2013, 10:06 AM   #6
tsdexter
You sure about that? I only ask because this bulletin from NGK says the protective anti seize coating comes off on removal... Unless it only comes off when removing them after awhile of usage when they would normally be seized up...
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
Old June 29th, 2013, 10:34 AM   #7
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I think you're over thinking things here. I've never used a torque wrench on my spark plugs. Just always used the 1/4 turn past finger tight rule. I've also taken out and put back the same spark plugs many times with no noticeable difference.
Old June 29th, 2013, 08:04 PM   #8
tubarney
I would say that is just manufacturer talk. There is no need for anti seize, maybe a little oil on the threads would be better. Just don't get oil on the electrode( not that it really matters)
The ones I have in my bike at the moment have been removed at least 10 times.
Old June 30th, 2013, 07:52 AM   #9
This may clarify some questions:
http://faq.ninja250.org/wiki/Changin...d#Installation
In my experience, which goes back to the times before torque wrenches were invented, the big no-no has been torquing the plugs with the aluminum threads of the head being hot.
The approach changes for new or used plugs: new ones will use some of the torquing for deforming the seal washer.
Aluminum and steel tend to make an electrolytic bond with time: that is the reason for the anti-seizure agent.
Old July 1st, 2013, 05:58 PM   #10
1LoneWolf
1LoneWolf's Avatar
Hand tight + 1/4 turn for me as well. I went 1/3 turn once and felt that I might have overtorqued it. I used anti-seize too.
1LoneWolf is offline   Reply With Quote
Old July 3rd, 2013, 11:55 AM   #11
tsdexter
Well, the bulletin seems to agree with what you're saying. They say you don't need anti-seize on first installation because of the zinc (I think?) coating, which on removal will come off... Subsequent installations of the same plug would use anti-seize/oil, but don't torque to spec in that case.
Spark Plugs.... DmbShn41 2008 - 2012 Ninja 250R Tech Talk 13 August 8th, 2014 04:13 AM
Spark plugs, which and why? subxero 2008 - 2012 Ninja 250R Tech Talk 17 June 3rd, 2014 08:49 AM
spark plugs juanpak87 1986 - 2007 Ninja 250R Tech Talk 12 October 3rd, 2013 09:44 AM
Which spark plugs? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 2 July 23rd, 2013 09:13 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
