April 20th, 2012, 09:25 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): '08 Ninja 250R Posts: 156
Fuel Mixture Question - Shim or Jet for this set-up?
This site has a ton of info about jetting/shimming and it's all been very helpful! I just bought my bike a few weeks ago and here are some plans I have for it:
-Competition Werkes GP slip-on exhaust -Removing the Snorkel -K&N air filter I was planning on shimming the needles (with 2 or 3 washers) but I need to know: With the 3 mods above, would I need to jet? or would I be alright just w/ the shimming adjustment?
Done: Fender Eliminator Kit, Shogun frame sliders, Rim Tape, Freeway Blaster horn, Protons, Rear LEDs, Brake Modulator Planned: Comp Werkes Slip-on, Snorkel Delete, Shimmed Needles |
April 20th, 2012, 09:34 PM | #2 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Rejetting the carbs (preferably by a professional with access to a dyno) is always going to provide the best, all round performance gain, but since you're only putting a slip-on on and making reasonably minor intake mods, I'd recommend shimming. It's hella cheap and very effective. As to the amount of washers, that you're going to determine for yourself through trial and error, though the generic 2 washers worked perfectly for me. If you are indeed going to go ahead and shim, save yourself the headache of stripped screws and get yourself JIS screw bits and an offset screwdriver. Much luck
April 20th, 2012, 09:52 PM | #3 | |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
I stripped the top right screw on the right carb (a pain to get to)...so I then took a dremel and made a shallow slice down the middle, allowing a flat head to get it out. |
April 20th, 2012, 09:59 PM | #4 |
The oem main jets are Keihin size 98. You'll want to pick up a set of Keihin size 100 mains.
First, make all the desired changes to your intake/exhaust that you want. Here's what you'll have to do to get the jetting right:
That should get it running nicely. notes for jetting: Factory Pro tuning guidelines faq.ninja250.org guidlines DIY how to shim the needles Carburetor photos for reference If you strip screws on either the bowls or the caps, they can be replaced with M4x16 hex key screws. Those make carb work les stressful. |
April 20th, 2012, 10:24 PM | #5 |
Chris, you are the man! Thanks for your post
If possible, I'd like to avoid the jetting / carb syncing process (due to finances and lack of access to a proper garage). Is shimming likely to get me a properly running bike? (maybe not quite optimized, but close to it?) Maybe I'll wait awhile before I go with a K&N, and that would hopefully lessen my need for changing out the jets. (btw - I've already picked up some JIC bits here: RJR Tools and a racheting offset screwdriver from Amazon
April 20th, 2012, 10:29 PM | #6 |
You might be able to get by on just the 98 mains and shimmed needles. It will likely be okay, but from my experience, it pulls better with 1 size larger main jet. As long as it's not giving lean symptoms at WOT and high rpm's, you should be close enough to ride it.
Every bike is different, and it's going to take test riding to be sure that it is right. You might be just fine on the 98 mains. |
April 20th, 2012, 11:16 PM | #7 | |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
April 21st, 2012, 04:24 AM | #8 |
MOTM - Sep '18, Feb '16
Regarding the screws. Cutting a slot to use a flat blade screwdriver is a great way to get the screws out. But if you reuse the screw it has a risk of breaking. I was doing a Lot of tuning when I had stock carbs and wore out the screws .
I went to Home Depo and bought Allen bolts that replace the screws. It cost about ten bucks. |
April 21st, 2012, 09:59 AM | #9 | |
Also, OP: home depot had the offset screwdriver cheaper than amazon, check it out
April 21st, 2012, 10:09 AM | #10 |
Stainless Steel. Don't want them to rust.
That sounds about right. For me, (16) Stainless Steel M4x16 hex key screws were about $10 total. |
April 21st, 2012, 11:39 AM | #11 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Put 2 washers and see how it feels around town, it should make an improvement. If you don't get any surging or bogging around the midrange you're good there. To determine if you need to rejet get on a road where you can do roughly a 50-70mph pull at WOT. If you can't make it to 70 you definitely need new jets, otherwise you're in the ok range. If it surges forward after you start closing the throttle I recommend a step larger on the main jets.
Also you might want to richen up your idle mix a little bit, it's usually pretty lean from the factory and you'll get rid of the jerk when you open the throttle at low rpm. You have to take the carbs out to do this though, so it's up to you. If you want to do everything at once I recommend Area P's special jet kit, it's a Dynojet kit with larger jets in case you take the airbox out and comes with 8 hex screws and a drill bit for drilling the caps over the idle mix screws.
Trust me, I'm a banana! |
April 21st, 2012, 11:50 AM | #12 |
When you drill off the aluminum caps that cover the idle screws. BE CAREFUL. Put something on the drill bit so it does not hit the screws. I have see drill bits hit the screw and drive the idle screw down so tight it damaged the carb.
April 21st, 2012, 12:01 PM | #13 |
This or stop and check frequently. When I did it I didn't drill all the way through, just enough where it broke through in the center and then I stuck a small screwdriver in and pried the cap out
April 22nd, 2012, 08:19 PM | #15 | |
April 22nd, 2012, 08:23 PM | #16 |
nah. That topic is covered enough in the faq.ninja250.org and a few other places here. Just link those instead.
April 23rd, 2012, 10:41 AM | #17 |
lol 5 washers?
April 23rd, 2012, 03:07 PM | #18 |
yepp. that's what faq.ninja250 suggests. they suggest testing up to 5 washers and sticking with the one that worked best. I'm on 3 and that's still surging if I just cruise at high rpms, so I'm moving up to 4 eventually.
April 23rd, 2012, 03:15 PM | #19 |
Just get a real jet kit. 5 washers is ridiculous
April 23rd, 2012, 06:13 PM | #20 |
process
I would think reasonably it goes.....:
Start w/ 2 washers and go up to 3 if 2 wasn't enough. And if 3 wasn't enough, you'd go up to 4 washers. And in the rare case that 4 wasn't enough, then you'd either go to 5 or get a jet kit.
April 23rd, 2012, 06:21 PM | #21 |
I never had to use 5. It was ridiculously rich when I tested it. But I can tell you that for my setup, 3 is not quuiiiiiiiite enough. I just haven't gotten around to going back to 4 because my break ended before I was able to go back to 4 for comparison. I thought 3 was right initially, so I wanted to do some more lengthy testing and then ran out of time.
Jet kits also cost $60+. I spend $12 on a pair of jets. There's not that much improvement in the needles that come in a jet kit except when I'm in a really really gradual roll-on at 3k and there's a weird overlap between the idle mix and the needle height. |
Jet or Shim? | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 21st, 2012 06:05 PM |
Should I Shim, jet or both?? confused | venzz | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 10th, 2011 04:11 AM |
Enrichening the Fuel Air Mixture? | Scattcatt | 2008 - 2012 Ninja 250R Tech Talk | 28 | September 22nd, 2011 06:27 PM |
Idle mixture screw question after jet install... | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 26th, 2010 09:10 AM |
[roadracingworld.com] - 'A Mixture Containing Bio-Fuel' Was Used By All Teams During | Ninjette Newsbot | Motorcycling News | 0 | July 4th, 2008 04:54 AM |
