Old February 4th, 2013, 05:41 PM   #1
Maostrapper
Motorcycle(s): Kawasaki Ninja 250
Starting problem with New Battery
Hi everybody!
I have a problem with the starter, because when I push, sound like a "Click". I thing there is a battery problem because mi bike is 2008 and I never replace the battery and the Owner's manual recommend this action each 4 years. After replace the battery the problem continue.
So, I need your cooperation. In this little town don't exist a dependable mechanical.
Sorry for my english
Maostrapper is offline   Reply With Quote
Old February 4th, 2013, 05:51 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
So is this the same problem you had before?
And because of it you have already replaced the battery with a new one?
After installing the battery did it run at all or was it just like in the video?
Sorry I can't help you but I figure with some clearer facts someone else will.
Old February 4th, 2013, 06:06 PM   #3
DaBlue1
DaBlue1's Avatar
What size/model battery did you put in it and was it fully charged before install?
Even though all the lights are on, low amperage will not turn the starter motor over.
Old February 4th, 2013, 06:14 PM   #4
Joshorilla
Bass Master General
Joshorilla's Avatar
Bump start it!
Here's a video some complete idiot made on youtube, if he can manage it between crashing then you'll be fine
Old February 4th, 2013, 06:18 PM   #5
Maostrapper
The video was recorded with the NEW Battery and is fully charged, so, what could be the problem?
To start the bike I just make the same movements of the video xD but I need a permanent solution.
Thanks!
Old February 4th, 2013, 06:53 PM   #6
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
With a solid click noise like heard on the video it's going to be two options. Starter relay or Starter motor.
First and easiest choice is to check and replace the relay is needed. Second choice is to remove the starter motor, disassemble, and inspect it.
LoD575 is offline   Reply With Quote
Old February 4th, 2013, 07:21 PM   #7
Maostrapper
Thanks a lot, I will be check the starter motor and the relay as you recommend me. I post the results jejeje
Old February 4th, 2013, 11:55 PM   #8
KELPHYN
KELPHYN's Avatar
check your cables. loosen them, wiggle them, retighten them. That's at BOTH ends, also check ground strap from engine to frame.
2008 Not starting - battery issue? Ash 2008 - 2012 Ninja 250R Tech Talk 8 April 14th, 2015 08:51 AM
Peculiar starting problem Tom504 1986 - 2007 Ninja 250R Farkles 4 November 6th, 2012 07:11 PM
starting problem b4lt1m0re 2008 - 2012 Ninja 250R Tech Talk 15 September 13th, 2012 04:03 PM
Starting Problem emoyer 1986 - 2007 Ninja 250R Tech Talk 4 July 3rd, 2012 11:00 AM
starting problem gogiburn 1986 - 2007 Ninja 250R Tech Talk 14 July 29th, 2010 03:24 PM
