June 29th, 2013, 07:46 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250R - Kawi Green Posts: 138
How to know if spark plugs are tight enough?
How can you tell if the spark plugs are tight enough? I was a bit worried going too tight so I did the 1/2ish turn past finger tight.
If they're too loose will it make a significant/noticeable decrease in power? They're supposed to be 9.5 ft lbs torque... I have a 10-70 ft lbs wrench, is it safe to turn the dial backwards from 10 a bit and tighten until it clicks? It felt like they were getting too tight and I didn't want to break them. How 'over tight' do you really have to go before breaking? They don't turn easily anymore with a short wrench, but again still didn't click the 'slightly below 10' torque wrench... Lastly, can I loosen them out again and retorque after driving about 20 miles (they have the metal coating that acts as anti-seize - will that be ruined pulling them out) or if I really feel they need to be redone just pay the $10 for 2 more? |
June 29th, 2013, 07:56 AM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
You're torque wrench is going to be most accurate in the middle of its torque range. I wouldn't trust it set below 10 at all.
June 29th, 2013, 08:04 AM | #3 |
Accuracy slightly outside the indicated torque should be reasonably ok, afaik reputable brands test at 25% outside the marked range, if you have one with a calibration cert it should say what it was tested at, and what it actually torqued
June 29th, 2013, 08:22 AM | #4 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
You can retorque them as much as you want. Just do them up snug. a 1/4 turn more than hand tight is enough.
June 29th, 2013, 09:04 AM | #5 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
they fall out when they're too loose, just snug them and don't worry about it. a little tighter than a drain plug
Trust me, I'm a banana! |
June 29th, 2013, 10:06 AM | #6 | |
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf |
June 29th, 2013, 10:34 AM | #7 |
Que Buenos Son!!!
MOTM - Nov '14
I think you're over thinking things here. I've never used a torque wrench on my spark plugs. Just always used the 1/4 turn past finger tight rule. I've also taken out and put back the same spark plugs many times with no noticeable difference.
June 29th, 2013, 08:04 PM | #8 | |
The ones I have in my bike at the moment have been removed at least 10 times. |
June 30th, 2013, 07:52 AM | #9 | |
http://faq.ninja250.org/wiki/Changin...d#Installation In my experience, which goes back to the times before torque wrenches were invented, the big no-no has been torquing the plugs with the aluminum threads of the head being hot. The approach changes for new or used plugs: new ones will use some of the torquing for deforming the seal washer. Aluminum and steel tend to make an electrolytic bond with time: that is the reason for the anti-seizure agent.
July 1st, 2013, 05:58 PM | #10 |
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250R Posts: 86
Hand tight + 1/4 turn for me as well. I went 1/3 turn once and felt that I might have overtorqued it. I used anti-seize too.
July 3rd, 2013, 11:55 AM | #11 | |
Spark Plugs.... | DmbShn41 | 2008 - 2012 Ninja 250R Tech Talk | 13 | August 8th, 2014 04:13 AM |
Spark plugs, which and why? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 3rd, 2014 08:49 AM |
spark plugs | juanpak87 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 3rd, 2013 09:44 AM |
Which spark plugs? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 23rd, 2013 09:13 PM |
Removing spark spark plugs? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 26th, 2013 03:48 PM |
