Old July 11th, 2013, 03:14 PM   #1
The_big_dill
The_big_dill's Avatar
Motorcycle(s): 1987 Ninja 250 custom gold
Loss of power at certain RPM
Hi all,
Recently, i have noticed that when i hit about 4-5k RPM there is very little power in the bike... feels somewhat like running low on gas.
When i get to about 6-7k RPM the power kicks in and gets me going.
The bike just rolled over 40,000 KM. Carbs have been cleaned at the beginning of the season, however i know i need to synchronize them.
I have a feeling the valves may need reseatting, what do you guys think?
Thanks,
Phil.
The_big_dill is offline   Reply With Quote
Old July 11th, 2013, 03:34 PM   #2
Lychee
sail away
Lychee's Avatar
Are you sure the power loss is related to RPM and not to throttle position?
Old July 11th, 2013, 03:43 PM   #3
The_big_dill
Well, if i go WOT it isn't very responsive at 4-5k, but once i pass that range its a lot more responsive.
And what would poor throttle point to?
I also want to mention that someone pointed out to me that my valves are loud and i did notice that they are clapping louder than usual. I do not know of the history of this bike, owned it since 37,000 km.
Old July 11th, 2013, 04:28 PM   #4
Lychee
sail away
Lychee's Avatar
I had a bog at 4k-5k before that ended up being too many washers under the needles... But it was really related to throttle position and my bike was reaching 4-5k during a my roll on.
Poor response to throttle position would point to the carburetor.
You can eliminate the valves as a starting point if you like, but generally valves out of adjustment would give you low rpm issues such as odd idles and hard to start in the morning situations. I've also thought that the valves get quieter when they are getting out of adjustment, since the ideal adjustment is toward the looser (and louder) end of the spectrum.
Old July 11th, 2013, 04:33 PM   #5
The_big_dill
The idle is bad, but i have no trouble starting. Sometimes i start with half a second on the crank on a cold engine.
The way i understand it is that valves get louder from carbon build up, and they become "sticky".
I have never touched the needle shims in the carb... and it was find before.
Old July 11th, 2013, 04:58 PM   #6
Lychee
sail away
Lychee's Avatar
I thought the noise came from the increased distance traveled by the valve stem (hammer) to meet the rocker (anvil).
Old July 12th, 2013, 08:12 AM   #7
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Surprised nobody has mentioned the main jets being clogged. It's probably the most probable scenario and it is definitely the first thing I would look at. Might as well plan a carb clean.
Old July 12th, 2013, 09:33 AM   #8
Lychee
sail away
Lychee's Avatar
He said carbs were cleaned recently and that he had plenty of power up top. Do you still think main jets?
Old July 12th, 2013, 11:45 AM   #9
FvnnyL3tt3r1ng
Yeah, I'd take a guess and say higher air flow could be why there is power up top but not in the mid range....
Old July 12th, 2013, 12:07 PM   #10
xaple
xaple's Avatar
I had this problem and it turned out to be water in the bowls
xaple is offline   Reply With Quote
Old July 12th, 2013, 01:30 PM   #11
The_big_dill
I hope its just a carb clean
Will get back when i figure it out
Old July 12th, 2013, 02:10 PM   #12
KELPHYN
KELPHYN's Avatar
Sounds like dirty carb. 4-5000rpm is around where the carb starts switching circuits(low speed to high speed) If it is a problem that has just started I would suspect a clogged passage in carb. I would try some carb cleaner in the gas first and go out and run it hard for half tank if you can. Hopefully that will clean it out. Check you plugs and air filter too.
Old July 12th, 2013, 04:05 PM   #13
I'm betting it's not main jets.
Is there damage to any of the slides or diaphragms inside the carburetors?
Old July 13th, 2013, 10:24 AM   #14
The_big_dill
How can damage occur?
I have not really touched the carbs since the rebuild months ago and this problem only appeared now.
Old July 13th, 2013, 01:40 PM   #15
FvnnyL3tt3r1ng
Have you installed a new fuel filter recently?
Old July 13th, 2013, 02:18 PM   #16
Plastic and rubber parts crack and rot over time. It's also possible that the lip of the diaphragm was kinked or something when you it back in the carb. This can cause creases, which wear.
I'm just suggesting things to look for, that's all.
Old July 13th, 2013, 02:58 PM   #17
The_big_dill
And i appreciate your suggestions
I have no fuel filter on the bike.
Old July 14th, 2013, 10:28 AM   #18
FvnnyL3tt3r1ng
No fuel filter as in you removed the OEM one???? If thats the case then you're letting anything that can get past the screens in your gas tank in the carbs. It takes the smallest flake to completely clog one jet and take out the cylinder...
Old July 14th, 2013, 11:10 AM   #19
The_big_dill
Well for one thing, this bike never came with a fuel filter. Furthermore, if it clogs the carb, it can't take out a cylinder...
Old July 14th, 2013, 11:12 AM   #20
FvnnyL3tt3r1ng
It takes out the power to that cylinder. Aren't you the one asking for help? Good luck Dill pickle
Old July 14th, 2013, 11:37 AM   #21
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
We're supposed to helping one another not insulting. I can't find any evidence that Dill's bike has a fuel filter.
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old July 14th, 2013, 01:32 PM   #22
The_big_dill
From what i have read, these bikes don't come with fuel filters. I may be wrong, but i heard people put them on optionally. I think its a good idea, just never got around to finding an appropriate filter for the hose sizes i have locally.
@FunnyLettering, i didn't mean to offend you, i tend to over do the periods at the end of a sentence, trying to fix that habit :P
Loss of Power, Won't go past 7k RPM denshidereku 1986 - 2007 Ninja 250R Tech Talk 38 March 17th, 2015 08:18 PM
loss of power reignman 1986 - 2007 Ninja 250R Tech Talk 7 June 1st, 2013 04:04 AM
Loss of power on highway (all the power) aldenso 2008 - 2012 Ninja 250R Tech Talk 10 May 7th, 2011 10:27 PM
Loss of power? sudapuff 1986 - 2007 Ninja 250R Tech Talk 1 October 19th, 2010 10:48 AM
Power loss at high rpm ///NR 2008 - 2012 Ninja 250R Tech Talk 4 June 29th, 2010 09:34 PM
