Old August 26th, 2013, 09:28 AM   #1
bond343
Motorcycle(s): 2004 ninja 250
no spark need help 2004 ninja 250
can't get spark on a 2004 ninja 250
I'm aware of all the necessary wiring and have the 100 ohm resistor wired in from the brown to grey wire, but am not getting spark still.
I've used a spark tester to verify power thru the coils and back to the box on the trip wire and can make it spark manually so i know the coils and power from the kill switch is ok. getting an ac pulse from the trigger at the box on the yellow and the black/white stripe wires. 12V DC on both trips and the brown/black stripe power wire. able to read 12V thru the black/yel and green/black ground wires. getting about 10V on the grey don't hot wire me wire, which i think is the culprit, but i'm not sure how much voltage is expected on this grey wire.
made a video in case what i've written above isn't making sense - http://youtu.be/RByFOFZtjtc
need to get this baby going, all help is appreciated
thanks for looking
bond343 is offline   Reply With Quote
Old August 26th, 2013, 09:52 AM   #2
Have you checked that the tab of the micro-switch by the clutch lever is not broken?
Check this out:
http://faq.ninja250.org/wiki/Underst...afety_switches
Old August 27th, 2013, 06:01 AM   #3
bond343
clutch switch in tact
yes, everything at the clutch lever is in tact fine and the switch grounds when lever is pulled in and sends thru the diode and to the neutral switch when the lever is out. on the green/black wire at the ecu that grounds thru the neutral switch or the clutch and side stand combo I'm receiving a good ground reading, and since the bike is in neutral, why would the clutch switch prevent it from getting spark?
Old August 27th, 2013, 06:03 AM   #4
bond343
any chance you can check the voltage on the grey wire at your ecu and let me know what you are getting?
Old August 27th, 2013, 06:12 AM   #5
Sorry Joe, cannot do it.
Old August 27th, 2013, 06:28 AM   #6
bond343
any other clues as to why this thing won't spark for me?
Old August 27th, 2013, 06:29 AM   #7
bond343
also is that a can't or won't?!?
Old August 27th, 2013, 08:02 AM   #8
No access to the bike + multimeter this week.
I see no reason for the reduced voltage, but I am no expert.
The resistor is for limiting current only.
I would check the diodes next.
Old August 29th, 2013, 05:03 AM   #9
n4mwd
n4mwd's Avatar
Just saw the video. Your bike wont start because your battery is dead. Disconnect to charge back up (never while connected) and it will fire right up.
To test this, get a second battery and battery cables. Ignition on. Neg to rearset. Pos to starter term on starter (or better yet, to nut on same wire on solenoid).
EDIT: Be careful jumping directly to the starter because the carb (gas) is only about an inch away from the nut. Best to use motorcycle jumper cables. FYI - see my blog on battery health.
My Ninja Blog
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) Pocket Sprocket 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 11:13 AM
2004 Ninja 250 forks duckracer Motorcycle-related 5 April 26th, 2012 02:20 PM
2004 Ninja 250 parts/whole - TN ecannon1 Motorcycle-related 26 August 10th, 2010 12:08 PM
2004 Ninja 250 - $900 xero404 Motorcycle-related 2 June 24th, 2010 09:51 PM
FS: 2 2004 Ninja 250's - Georgia MtnCruiser Motorcycle-related 2 October 31st, 2009 05:29 PM
