September 1st, 2013, 09:56 PM | #1 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
Here's a video that illustrates the benefits of a shimmed needle
Link to original page on YouTube. Last futzed with by IF13; September 2nd, 2013 at 08:59 AM. |
September 1st, 2013, 09:57 PM | #2 |
Embed isn't working, neither does the link.
September 1st, 2013, 10:45 PM | #3 |
WOT WOT WOT
September 2nd, 2013, 01:38 AM | #4 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
it works for me, interesting video.
question, can this be done on FI bikes too? Or does the FI system not allow for a similar change?
I can not be a true player by playing around. |
September 2nd, 2013, 04:56 AM | #5 |
Join Date: Mar 2013 Motorcycle(s): 2012 Kawasaki Ninja 250 Posts: 33
FI bikes don't use carb needles, for FI you would need to change the fuel injection map.
The more difficulties one has to encounter, within and without, the more significant and the higher in inspiration his life will be. |
September 2nd, 2013, 05:26 AM | #6 |
Very informative video. I bookmarked the website.
I hate a computer generated voice but the info was worth it. |
September 2nd, 2013, 07:38 AM | #7 |
WOT WOT WOT
September 2nd, 2013, 07:56 AM | #8 |
For a slipon if the bike runs fine no need to really remap, if you replace the air filter, yes a remap is needed. Power Commander is usual what everyone uses on the FI bikes. I know over the winter I get to have fun doing this since I am pulling the carbs and throwing an EFI on my 250. Mine has a K&N High Flow filter and a Danmoto XG-1 slipon.
September 2nd, 2013, 08:00 AM | #9 |
Join Date: May 2013 Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F Posts: 125
noob question: what's the benefit of having more fuel flow?
September 2nd, 2013, 08:18 AM | #10 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Nothing in and off itself.
The reason to change your fuel flow is to optimize the fuel air ratio. If you increase the fuel flow without increasing the amount of air you'll run rich, too much fuel. When you install an air filter or a full exhaust system and in some cases a slip on you increase the amount of air the engine gets. The more air it gets the more fuel it needs. So if you add more air and additional fuel you can increase power. |
September 2nd, 2013, 09:23 AM | #11 |
Certified looney toon
MOTM Jul '13, Jul '14
You are welcome.
I clicked the little calculator thing to see what that site recommends for me. At my home elevation (4000 ft) it recommends a kit to shim the needle. But at the elevations I tend to ride at (6000-8000) no kit is needed. Trouble with living in a region with large elevation changes. I can go anywhere from 1000-9000 ft in a single ride. Guess I'll leave it alone.
September 2nd, 2013, 03:54 PM | #12 |
This vid makes me want to play Portal...
so i shimmed.. | Josh_kcco | 1986 - 2007 Ninja 250R Tech Talk | 10 | February 28th, 2014 08:55 PM |
[motorcycledaily.com] - Yamaha?s 2015 YZF-R125 Illustrates Massive Effort on Small Di | Ninjette Newsbot | Motorcycling News | 0 | February 14th, 2014 01:50 PM |
Shimmed, Not sure if it was necessary | Floki | 2008 - 2012 Ninja 250R Tech Talk | 23 | December 3rd, 2013 12:10 PM |
[roadracingworld.com] - Tuesday Video: Jeff Wood's Struggle At Daytona Illustrates Th | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 10:10 PM |
[superbikeplanet.com] - First Issue of Moto Retro Illustrated Illustrates Lawson's Ra | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2009 04:51 AM |
