Old November 2nd, 2013, 10:42 PM   #1
berserk81
berserk81's Avatar
Motorcycle(s): '06 Kawasaki Ninja 500
Removing the vacuum spring from the petcock.
Do you have to twist the gasket piece off or do you just pull it of?
berserk81 is offline   Reply With Quote
Old November 3rd, 2013, 07:25 AM   #2
Twist not needed.
Be gentle, the diaphragm is delicate.
Old November 3rd, 2013, 07:42 AM   #3
berserk81
berserk81's Avatar
Originally Posted by Motofool View Post
Twist not needed.
Thanks so I am just to pull the diaphragm off gentely, OK thanks for the help.
Old November 3rd, 2013, 08:27 AM   #4
It may stick to the body, but inserting some thin blade in between should liberate it.
It is made of two layers, if I remember correctly.
You are welcome
Old November 5th, 2013, 07:48 PM   #5
berserk81
berserk81's Avatar
You are welcome
Yup came apart a lot simpler than I thought it would. I stretched the spring and put a thin coat of petroleum jelly on all the gaskets now my petcock does not leak. Thanks for the help.
Old November 5th, 2013, 08:07 PM   #6
..........Thanks for the help.
You are welcome
Vacuum-Less Petcock ninjunk 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2023 11:30 AM
Removing Rear Shock Spring? TBC 1986 - 2007 Ninja 250R Tech Talk 22 December 29th, 2014 03:11 PM
88-07 Gas Cap Gasket, Petcock, Vacuum Slides shiftdrift06 Items Wanted 2 December 4th, 2014 02:38 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
removing gas tank - petcock question james250ninja 2008 - 2012 Ninja 250R Tech Talk 5 August 25th, 2011 11:23 AM
