Old May 12th, 2014, 06:05 AM   #1
Dj9384
Unhappy Chain broke while riding- sprocket help needed
Hey guys,
I was riding yesterday and the chain on my 2010 250r snapped. Luckily I was just pulling out from a stop sign so I didn't fall or anything but now I have to replace it. I've watched a few videos on how to replace the chain and sprockets and the ones I've seen say to hold the back brake to get the front sprocket off, but since I have no chain, this won't work. Any ideas how I might remove the front sprocket? Also what are people's suggestions for sprocket sizes? Do differing sizes affect performance by much?
Thanks
Dj9384 is offline   Reply With Quote
Old May 12th, 2014, 06:40 AM   #2
kashun84
kashun84's Avatar
Motorcycle(s): 2010 Lime Green 250R
remove it with your new chain on. 15T CS sprocket is a good place to start with and it's really depends on your riding style. I do 100% highway riding and I am aiming for lowest RPM at highway speed, 15/38 setup treat me well but it might be too long for another rider. http://www.gearingcommander.com/ is a good place to play around your gearing.
kashun84 is offline   Reply With Quote
Old May 12th, 2014, 06:48 AM   #3
CajunNinjaR
ninjette coonass
Motorcycle(s): 08 ninja 250, 06 wr450f, x15 110, tiny 50
You couldn't use the broken chain? If your holding the back brake it can't spin around to the broken spot. So just run it from the top of the rear sprocket to the front one? If the nut spins clock wise you will have to loop it under. Not sure which way the nut on the front sprocket has to spin and I can't seem to do a search on my mobile...
Posted via Mobile Device
CajunNinjaR is offline   Reply With Quote
Old May 12th, 2014, 06:59 AM   #4
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
A worthwhile investment is an impact wrench, 1/2" drive. Picked one up at Harbor Freight for $40. Using this with a quick trigger finger will release that nut. Make sure it's properly torqued when reinstalling.
Old May 12th, 2014, 07:28 AM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
impact guns work wonders on sprocket removal.
TEAM ALFALFA
www.apexassassins.com
Old May 12th, 2014, 08:35 AM   #6
Dj9384
Thanks for the quick responses! I'm going to try using the broken chain only because I'm stuck at home until I get a ride to the store from a friend. If not I'll try to get my hands on an impact gun. I'm going to play around with these sprocket combinations. Thanks again guys!
Old May 12th, 2014, 10:35 AM   #7
I used their "Emergency 12v Impact Wrench" that was $24 after coupon (same 20% off coupon they have everywhere). It worked beautifully. That one was particularly useful because I had no air compressor and couldn't work near an electrical outlet (connect it to the bike's battery).
Make sure to get the right-sized impact socket (can't recall)!
Old May 12th, 2014, 10:51 AM   #8
harbor freight, electric impact gun, $25
Old May 12th, 2014, 01:33 PM   #9
Are you talking about the ones that take a battery pack or the ones that connect to your bike's battery? The $30 ones that are normally $25 after coupon and the emergency 12v one are all on sale right now for $16 after coupon.
I still like the emergency 12v one because it's good enough for our bikes and there's nothing else to buy besides metric impact sockets (of course). The included SAE sockets are worthless for our bikes but they came in handy for changing car tires recently, so it is another positive attribute for the 12v emergency one.
If you get hex socket adapters for other jobs make sure to get the long ones. Almost everything that has needed them has needed the longer ones (reaching the fork oil drain bolts, for example).
Old May 12th, 2014, 01:40 PM   #10
i use a big orange one that plugs into a wall
Old May 12th, 2014, 06:11 PM   #11
Ah. I think it's a bit more expensive than that. The two I can find are both on sale for $50, $40 after coupon (normally $70).
I was interested since the "Emergency" 12v one may not be designed for long-term use and has lower specs, but they probably describe it as "Emergency" because it's intended to be kept in your trunk for "Emergency" situations (roadside tire changes). That's also why it comes in a plastic case.
Old May 12th, 2014, 06:27 PM   #12
Originally Posted by Dj9384 View Post
Hey guys,
I was riding yesterday and the chain on my 2010 250r snapped. Luckily I was just pulling out from a stop sign so I didn't fall or anything but now I have to replace it.........
Welcome to Ninjette.org, Dave !!!
What will prevent the next chain from snapping?
It is possible that your current chain and sprockets are perfectly fine, needing only a decent riveted master link.
Old May 15th, 2014, 12:00 PM   #13
reroka
Biker Noob
reroka's Avatar
Motorcycle(s): 2004 Honda Shadow 750 Aero
Per this website the current set I have I should be at 76 MPH at 8800 rpm
My set up is a 14/43 and right now I am at between 65 and 70 at 8800rpm
So something is messed up. I am going to a 14/42 to drop it some more but I dubt it will drop much.
reroka is offline   Reply With Quote
Old May 15th, 2014, 12:08 PM   #14
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Are you using your stock speedometer to reference the speed? Ninja 250 is notoriously known for over stating the speed.
Old May 15th, 2014, 12:10 PM   #15
The error on both the tach and speedo themselves can be significant. You can calculate what it actually is right from the gear ratios (use www.gearingcommander.com to tweak at will), regardless of what the gauges are telling you.
Old May 15th, 2014, 12:12 PM   #16
reroka
Biker Noob
reroka's Avatar
Yes That is all I have to go by. I am on the Highway going 65 70 and I am around 9000rpms even though I am a 14/43 it much less than the stock 14/45 but I am going to go to a 14/42 to see if that lowers it a bit more. Since I ride on the highway a lot it seems I burn through gas faster.
Old May 17th, 2014, 05:55 AM   #17
mgentz
Board Member
At least my odometer is dead on.
Chain for Sprocket Configurations Maddawg 2008 - 2012 Ninja 250R Tech Talk 9 December 25th, 2014 07:13 PM
My chain broke without warning the big mike General Motorcycling Discussion 58 February 2nd, 2014 11:42 AM
Getting a new chain and sprocket kittyslasher 2008 - 2012 Ninja 250R Tech Talk 10 December 9th, 2013 12:55 AM
chain adjuster cap broke help! Pics included. jon.b.calderon 2008 - 2012 Ninja 250R Tech Talk 22 February 20th, 2013 01:57 PM
Sprocket swap tweak needed ? eddiekay 2008 - 2012 Ninja 250R Tech Talk 13 February 16th, 2011 06:09 AM
