Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old May 13th, 2014, 04:31 PM   #1
SE green to international green conversion? List of part numbers?
My nephew is interested in a Ninja 300 ABS, which has piqued my curiosity again. As a 250 owner many times over, I'm really only interested if I can get ABS and the non-SE green which was never sold here. I talked with a local dealer who said he can order them if I can find the part numbers. I'm sure it will be expensive so, of course, I need to see the price to know if this is even worth pursuing.
First, I know any graphics on the 250 tanks were clear-coated on. Is that the case for both the 2013 and 2014 Green SE EX300?
Next, I know most of the fairing graphics are removable, but are they ALL removable? If not, which aren't?
I assume that all the graphics are stickers except the tank, so all this will take for a proper conversion is a tank and a lower (international non-SE green has a black lower). Is that right? Now, for a cheap conversion I am sure I can get a black lower from one of the other US color schemes and hide the mismatched tank graphics behind a tank bra, but that got me thinking: Does anyone make a bright green tank bra close to Kawi-green?
I'm assembling part numbers now and will update this thread when I have them ready.
Edit:
This isn't looking good so far. Are the green SE side fairings, side covers, and lowers black with green graphics or green with black graphics?
Last futzed with by CZroe; May 13th, 2014 at 06:33 PM.
Old May 13th, 2014, 05:32 PM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
2013 SE green main fairings and underseat fairings are black with green stickers.
2014 SE green main fairings are green with black stickers. The nose and underseat fairings are black. Might be cheapest to buy a 2014 SE and then buy a green nose fairing since that's available from the 2013 model, then paint the underseat fairings with matching colorite paint since those parts are simply not available in green from US model bikes at this time. Or since you'd have to paint something anyway, then paint the tank and nose fairing too.
Tank graphics are clear coated on. All other graphics peel off easily.
The black belly fairings are easily available from any of the other ninja 300 models. I picked up some from ebay.
Maybe this uk website could help you: http://www.cornwallkawasaki.co.uk/sh...INJA-300%20AEF
Old May 13th, 2014, 06:07 PM   #3
Thanks. I don't think the non-SE green was available in the UK but I know it was available in AUS. Unlike the US Kawasaki site, their official site in every other country I have checked on has no parts diagram. I've been poking around on Australian parts sites with little luck. For example, www.mototech.com.au site has part numbers for green lowers instead of black even though none of their bikes came with green lowers. They also have no part number for the green side fairings but at least now I know I can get those here (thanks!).
Old May 13th, 2014, 08:34 PM   #4
OK, here's what I have so far:
Upper fairing
Available in the US on the 2013 SE Green (2014 SE Green upper is black)
55028-0472-777 US/AUS Green Upper (2013)
55028-0496-777 AUS Green Upper (2014)
Front fender
Available in the US on both the 2013 and 2014 SE Green
35004-0318-777 US/AUS Green Front Fender
Side fairings
Available in the US on the 2014 SE Green (2013 side fairings are black); AUS part numbers are different
55055-5428-777 US Green LH Side Center Fairing
55055-5440-777 US Green LH Side Center Fairing
55028-0475-777 AUS Green LH Side Center Fairing
55028-0417-777 AUS Green RH Side Center Fairing
Lower fairings
Similar lower fairings available in the US on colors other than SE Green; no part numbers match exactly
55055-5164-H8 US Ebony LH Lower
55055-5165-H8 US Ebony RH Lower
55055-5403-18T US S.Black LH Lower
55055-5404-18T US S.Black RH Lower
55028-0420-18T AUS S.Black LH Lower
55028-0421-18T AUS S.Black RH Lower
Side covers
NOT available in SE Green on any US model
53065-0026-777 AUS Green LH Side Covers
53065-0027-777 AUS Green RH Side Cover
Tail
Different green sides are available in the US on both the 2013 and 2014 SE Green (what changed?)
53065-5018-777 US/AUS Green Left Tail Fairing (2013)
53065-5019-777 US/AUS Green Right Tail Fairing (2013}
53065-0060-777 US/AUS Green Left Tail Fairing (2014)
53065-0061-777 US/AUS Green Right Tail Fairing (2014)
Tail center is available in the US on the 2013 SE Green (2014 SE Green tail center is black)
53065-0062-777 US/AUS Green Tail Center
Solo seat cowl
Solo seat cowl is available in the US as an option
99994-0354-777 US/AUS Green Solo Seat Cowl
Tank
Available in the US with SE graphics on SE Green, possibly without graphics as a replacement (2013 US/AUS part numbers match)
51088-5059-777 US/AUS Green Tank (2013)
51088-5327-777 US Green Tank (2014)
51088-5213-777 AUS Green Tank (2014)
For a total conversion:
a US 2014 SE Green will need a replacement tank, side covers, upper fairing, center tail fairing, and lower fairings.
a US 2013 SE Green will need a replacement tank, side covers, side fairings, and lower fairings.
The 2013 US SE Green tank part number matches the AUS non-SE Green. It's possible that replacements are solid colors and require ordering/installing separate graphics like many replacement fairings despite original having graphics under the clear-coat. Ordering it could be an expensive gamble. People report randomly getting graphics on replacement fairings so it all may depend on what stage of assembly the newly-manufactured parts were in when they were redirected to the warehouse as spare parts. I'm sure AUS riders don't want to get a tank with US SE Green graphics as a replacement, so the factory may have taken extra precautions. I think that either the AUS site I used had the wrong part number or they all ship in solid colors. Having different part numbers in 2014 may have been particularly to eliminate the need to take this precaution. Anyone getting a green SE tank replaced by insurance? I'd really like to know what your dealer/body shop gets before they might clear-coat it.
Old May 14th, 2014, 10:43 AM   #5
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
What about having it wrapped with a color film?
accumack is offline   Reply With Quote
Old May 14th, 2014, 12:14 PM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
For whatever it's worth, ColorRite lists "Lime Green" as the only green color for both the '13 and '14 300. That color is listed as manufacturer code 777, which is the same as the suffix on the parts you listed (just more credence that it's correct info).
It might be easiest to just get the factory-color paint and paint whatever is the wrong color. If you're completely anal about getting "100% factory correct" stuff for your not-actually-available-from-the-factory configuration, this isn't quite that. However, it should all match, and also gives you options that you can't get OEM (like clearcoating all/no decals or painting parts green that "should be" but were never offered in that color).
Looking up stuff on Partzilla, it looks like most of the pieces are $100-$200 each. The tank alone is $590 MSRP, $450 on Partzilla. Lord knows I've spent way more than I needed to on things to make sure they were just right, but if you want real OEM, new parts, I think you're looking at a pretty good chunk of cash. It'll probably be cheaper to just have all the necessary parts (and maybe just toss in all the body parts to make sure they match perfectly) professionally resprayed to the factory color.
Help with brake part numbers Riverdale 2008 - 2012 Ninja 250R Tech Talk 2 September 14th, 2013 01:35 PM
The Green Hell on a Green Monster Kevin2109 Videos 40 August 25th, 2012 11:25 AM
