Old December 7th, 2015, 07:30 AM   #1
[visordown.com] - Triumph Bonneville Street Twin price and specs revealed
TRIUMPH has just reveal pricing and specifications for its new Bonneville Street Twin.
The entry-level model in the new Bonneville range starts from £7,300 on the road and makes 55hp and 59lbft.
Here are the full specifications:
Engine and Transmission
Type
Liquid cooled, 8 valve, SOHC, 270° crank angle parallel twin
Capacity
900cc
Bore/stroke
84.6 x 80 mm
Compression ratio
10.55:1
Maximum power
55 PS / 54 BHP (40.5kW) @ 5900 rpm
Maximum torque
80Nm @ 3230 rpm
Fuel system
Multipoint sequential electronic fuel injection
Exhaust
Brushed 2 into 2 exhaust system with twin brushed silencers
Final drive
O ring chain
Clutch
Wet, multi-plate assist clutch
Gearbox
5-speed
Chassis
Frame
Tubular steel cradle
Swingarm
Twin-sided, tubular steel
Front wheel
Cast aluminium alloy multi-spoke 18 x 2.75in
Rear wheel
Cast aluminium alloy multi-spoke 17 x 4.25in
Front tyre
100/90-18
Rear tyre
150/70 R17
Front suspension
Kayaba 41mm forks, 120mm travel
Rear suspension
Kayaba twin shocks with adjustable preload, 120mm rear wheel travel
Front brake
Single 310mm disc, Nissin 2-piston floating caliper, ABS
Rear brake
Single 255mm disc, Nissin 2-piston floating caliper, ABS
Instrument display/functions
LCD multi-functional instrument pack with analogue speedometer, gear position indicator, fuel gauge, range to empty indication, service indicator, clock, trip computer, scroll button on handlebars, TPMS ready, heated grips ready, fuel consumption display and traction control status display.
Dimensions and weights
Length
2090 mm
Width (handlebars)
785 mm
Height Without Mirrors
1114 mm
Seat Height
750 mm
Wheelbase
1439 mm
Rake
25.1º
Trail
102.4 mm
Dry weight
198 Kg
Fuel tank capacity
12 L
Fuel consumption
Constant speed 56 mph: 87.4 MPG
Constant speed 75 mph: 62.4 MPG
Mixed riding*: 76 MPG
* Figures obtained according to the emissions procedure GTR2 of the World Motorcycle Test Cycle (WMTC).
Emissions
EUR4 Standard: CO2 - 87.0 g/km
Standard equipment
ABS, traction control, ride-by-wire, immobiliser, USB socket, LED rear light
Click here for full story...
[visordown.com] - Honda Africa Twin price revealed Ninjette Newsbot Motorcycling News 0 November 28th, 2015 02:11 AM
[motorcycle.com] - 2016 Triumph Street Twin Ninjette Newsbot Motorcycling News 0 October 27th, 2015 06:40 PM
[visordown.com] - New Triumph Bonneville family revealed Ninjette Newsbot Motorcycling News 0 October 27th, 2015 05:10 PM
[visordown.com] - Honda Africa Twin gallery and full specs Ninjette Newsbot Motorcycling News 0 July 28th, 2015 03:12 AM
[visordown.com] - Erik Buell Racing 1190SX specs and price revealed Ninjette Newsbot Motorcycling News 0 July 2nd, 2014 04:11 AM
