Old March 11th, 2010, 05:00 PM   #1
cnichols79us
Fastly Slow!!!
cnichols79us's Avatar
Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125
HID Conversion for Pre-Gen on Ebay/Link..
Looks interesting!
http://cgi.ebay.com/ebaymotors/Slim-...Q5fAccessories
cnichols79us is offline   Reply With Quote
Old March 11th, 2010, 11:15 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Looks interesting... I'd love to know if something like this would work, especially considering the fact that I never use my high-beam anyway.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old March 13th, 2010, 03:39 PM   #3
saber63
Motorcycle(s): '90 250 project, '03 250r, '14 STR,12 STR, '01 R6
ouch, those are over priced IMO
check out
http://www.ddmtuning.com/index.php?p...=106&parent=61
you get a set with a working HI/Low beam i have a set and like them very much, and will be doing a write up soon.
(they also sell non high/low H4 kits for cheaper....)
plus lifetime warranty, they are also super popular on other forms as well.
-Levi
saber63 is offline   Reply With Quote
Old March 13th, 2010, 05:28 PM   #4
cnichols79us
Fastly Slow!!!
Thats Cool Saber, thanks for the link. I look forward to your right up! Any heat problems and what Color did you go with? Do they make a difference in visible light???
Old March 13th, 2010, 07:25 PM   #5
saber63
im not sure what your asking about "visable light" but ill give you the low down and hope i awnser all your questions
i picked up a set of 55W ballists with 6000K bulbs. i also have a set of 55W 4500K's in my 600RR
i find the 4.5K's to be a tad yellow with the 55W ballist (perfect for a 35W) and the 6K are to blue for me. for best light onto the road, i would go with 5K at 55W and 4.5K for 35W. form what ive seen it should be crystal clear light at those points
when i was testing the stock vs HID the stock bulb put out WAY more heat then the HID, so nothing to worry about there!
the light output is WAY better than the stock bulb, WAY WAY better, i can see the lights on the walls of some tunnels during the day, when i cant see anyone else's lights
with a bit of E-tape or other mask, all the nasty scatter can be removed and no blinding will be done(on low beam ) and theres a good change from low beam to high beam so it works well.
-Levi
HID headlight conversion. agentbad General Motorcycling Discussion 6 May 21st, 2014 07:13 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
DIY - HID Headlight Conversion g21-30 2008 - 2012 Ninja 250R Tech Talk 406 August 30th, 2011 11:41 PM
HID conversion b_eastep 1986 - 2007 Ninja 250R Farkles 84 August 4th, 2010 10:10 AM
Proper HID conversion? jonthechron 2008 - 2012 Ninja 250R Tech Talk 23 February 9th, 2010 02:09 PM
