Old July 9th, 2010, 08:10 PM   #1
nsgirl
Sore left hand
I've been finding that my thumb is really sore and my pinkie is numb (and stays numb for weeks) after riding and not even that far. I've tried changing the postion of my arms, elbow, hand (relaxing my grip), fingers, new gloves with extra palm padding, etc., but nothing helps. I was wondering if anyone has had this problem and had luck with gel grips or have any other solutions.
nsgirl is offline   Reply With Quote
Old July 9th, 2010, 08:27 PM   #2
2WheelGuy
2WheelGuy's Avatar
Sorry...couldn't help myself
AFM #278
Old July 9th, 2010, 08:28 PM   #3
I've found not cinching up the gloves tight at the wrists has helped prevent my fingers from tingling/falling asleep. In fact, I now keep the velcro closures as loose as possible when I put the gloves on.
Old July 9th, 2010, 08:41 PM   #4
2WheelGuy
2WheelGuy's Avatar
Try adjusting your levers. I've found that most people have them too high causing an unnatural bend at the wrist.
AFM #278
Old July 9th, 2010, 09:24 PM   #5
Ramen
Frak It
Ramen's Avatar
I find relaxing my arms will naturally relax my grip as well. Also, concentrate on proper posture and straddle to keep the weight off your wrists.
Ramen is offline   Reply With Quote
Old July 9th, 2010, 10:59 PM   #6
Postiez
Postiez's Avatar
Motorcycle(s): Red '08 250
On an 848 its soooooo much worse
Postiez is offline   Reply With Quote
Old July 10th, 2010, 09:17 AM   #7
nsgirl
Thanks for all of the suggestions. I will try them all.
Old July 10th, 2010, 09:44 AM   #8
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Kari - that is exactly why I switched to the Pazzo levers - as soon as I did, it made everything better
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 12th, 2010, 04:22 AM   #9
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
I used to have sore, tingly, numb hands too. Read Keith Code's, "A Twist of the Wrist". A common rider error is gripping the bars too tightly. It's a survival reaction and you really have to practice being as loose as possible, even though it feels really weird. the bike doesn't need us to grip it. it actually hinders its physical ability to work with the grooves in the road, so just barely holding on will really help that pain in your wrist/hands PLUS it has the added benefit of making the bike happier too!
Postwhores are COOL! ~Allyson
Old July 12th, 2010, 05:30 AM   #10
TenaciousD
TenaciousD's Avatar
Motorcycle(s): 2009 250R
nsgirl,
I am having the exact same issue, except it's my right hand and it's my thumb that's gone numb. I've ruled out the levers because 98% of the time I'm not covering the brake lever. It definitely gets better if I make myself relax and keep a loose grip on the bars. I also think my gloves may be too small, so that is something else you can look at. I think mostly I just have to train my body to do this new activity that it finds very unnatural. Good luck!
Kevin
2009 Ninja 250R
TenaciousD is offline   Reply With Quote
Old July 12th, 2010, 06:13 AM   #11
tabogon
Motorcycle(s): 2010 Ninja 250R (Metallic Island Blue)
Relax your grip and adjust your levers. I was getting pain in my hands when I first got the 250, tried everything as well except the levers. Just lossen the bolt and rotate the levers until they feel comfortable. And if you tried loosening your grip and it doesn't help, you aren't as loose as you think.
http://dudetravel.blogspot.com/
tabogon is offline   Reply With Quote
Old July 12th, 2010, 09:46 AM   #12
LuxMundi
LuxMundi's Avatar
Motorcycle(s): '09 250R Black
I've had problems with my heels being numb, so I feel ya.
If it's your left hand, maybe just ride right hand only unless you need to shift?
Posted via Mobile Device
LuxMundi is offline   Reply With Quote
Old July 12th, 2010, 01:53 PM   #13
SCREEM
SCREEM's Avatar
Motorcycle(s): 09 250R, 08 connie 14, 08 honda ruckus(gave to mom)
great suggestions above, also try taking your hand off the bar and shake it out once in a while. You should build up some tolerance after a while. gl
SCREEM is offline   Reply With Quote
Old July 12th, 2010, 02:05 PM   #14
bdavison
Wartown, USA
bdavison's Avatar
Im betting its your gloves, and not your grasp...
If the tip of the finger on the glove is applying pressure to the tip of your finger IN the glove...it will make it go numb really quick.
Im willing to bet that this is your problem, try riding minus gloves for the same distance, and see if it still goes numb....if it doesnt....its your gloves.
Many times people try on the gloves in the store, with their hand out flat...but when you wrap your hand around a handlebar, it trys to compress your fingers.
Look for gloves that have still have space left in the fingertips when you grasp a handlebar.
Old July 14th, 2010, 01:18 PM   #15
DRivero
DRivero's Avatar
Motorcycle(s): 2001 Ninja 250 (Sold); 2008 Ninja EX500
I have pretty poor circulation in general, but my right hand while riding goes numb: first the fingers, then the whole hand, eventually workikng its way up my arm until it's useless and feels like a toothache, and I absolutely have to let go of the grip. It was so bad that I couldn't take the highway at all, because there's no way, really, to let off the throttle. I finally wised up and bought a (mechanical) cruise control apparatus. It was like 25 bucks, and I put it on myself. I don't use it steady.....I flip it on when I need to shake the feeling back into my hand.
Nsgirl, I don't know if the above will work for you (maybe the occasional shake-out will keep your problem in check? IDK), but for me it was a great and inexpensive solution.
www.facebook.com/#!/profile.php?id=1568567524
DRivero is offline   Reply With Quote
Old July 14th, 2010, 01:21 PM   #16
DRivero
DRivero's Avatar
Originally Posted by nsgirl View Post
Sore left hand
Never mind, I'm a moron. Wrong hand. Damn, and my right hand fell asleep typing all of that, too! (JK)
Upshifting during left hand cornering Sirref Riding Skills 39 September 27th, 2013 09:34 AM
Anyone removed left hand controls whylee Ninjettes At Speed 12 August 26th, 2012 10:43 PM
left hand side handle bar and rearset sharky nrk Motorcycle-related 1 June 24th, 2012 10:02 AM
WTB left hand tail plastic, Black, for 08+ rothwem Items Wanted 1 January 12th, 2012 08:55 PM
wtb; left hand handlebar and stock windscreen stang65pony Items Wanted 3 December 18th, 2010 11:25 AM
