Old June 29th, 2013, 12:15 PM   #4001
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Originally Posted by tfkrocks View Post
Finally remembered that I should put some fuel stabilizer in the tank of the 300 so did that.
Put a drift camera on the 250 and then promptly lost it on the way to oakland
Aw, that sucks . What happen? How did you have it hooked up?
antiant is offline   Reply With Quote
Old June 29th, 2013, 12:45 PM   #4002
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I guess the base wasn't screwed in tight enough so it unscrewed while driving. The base was still clipped into the mount.
Old June 29th, 2013, 02:45 PM   #4003
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Originally Posted by mrjasey View Post
adjusted tank bag straps, adjusted throttle play, lubed chain with chain wax using rear stand, and tinkered with plastidip on the front to see what it would look like without the green teeth under the headlights
looks like
installed SS lines and EBC HH pads.
Old June 29th, 2013, 05:05 PM   #4004
Daks
Jersey Devil
Daks's Avatar
Motorcycle(s): '06 Ninja 250
Cruised Redwood with a local AFM racer. It's amazing how things can go so much better with someone who knows what the hell they're doing.
Daks is offline   Reply With Quote
Old June 29th, 2013, 05:19 PM   #4005
Obsidia
Quantum Creatrix
Obsidia's Avatar
Motorcycle(s): 2012 Ninja 250R Special Edition
Met up with a fellow rider this morning, rode out to Powell Butte and then decided to ride down the old hwy 30 and go up the Columbia Gorge a bit :-) Outside of the cyclists riding in their event, it was a pretty smooth trip.
Ran into a pair of bikes up at the viewpoint I stopped at and the rider on the black Ninja followed me back into Gresham. Hopefully I didn't slow him down too much
Obsidia is offline   Reply With Quote
Old June 29th, 2013, 06:33 PM   #4006
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Lubed my dry ass chain!
Boyfriend noticed the nose it was making on the way home today... Oops.
Old June 29th, 2013, 08:36 PM   #4007
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Added over 450 miles in just over 12 hours, found a WICKED new road, and learned a way to lube the chain without a rear wheel stand.
<-- Linky
Old June 30th, 2013, 07:57 AM   #4008
allanoue
allanoue's Avatar
MOTM - Sep '14
Old June 30th, 2013, 08:37 AM   #4009
LittleRedNinjette
My method involves my boyfriend rolling my bike forward while i spray the chain.
Old June 30th, 2013, 08:48 AM   #4010
NevadaWolf
NevadaWolf's Avatar
Well, I'm solo so needed a way to do it while on the road and without help.
<-- Linky
Old June 30th, 2013, 10:54 AM   #4011
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Lubed the clutch cable.
Cleaned and oiled the air filter for the first time. There was lots of grime on the pod filter and had to degrease/wash it twice before it was thoroughly cleaned.
Hopefully the cleaned filter won't affect the jetting too much. Plan on going down one size in the main jets with the summer heat.
menikmati is offline   Reply With Quote
Old June 30th, 2013, 11:29 AM   #4012
LittleRedNinjette
I'll have to keep that one in mind! My luke the bike would fall on me.
Old June 30th, 2013, 12:17 PM   #4013
NevadaWolf
NevadaWolf's Avatar
Surprisingly I was able to balance it enough to use my toe to turn the wheel. I gripped the part of the plastic that's square right above the passenger peg. It worked.
<-- Linky
Old June 30th, 2013, 01:46 PM   #4014
allanoue
allanoue's Avatar
MOTM - Sep '14
I will give it a shot
Old June 30th, 2013, 01:47 PM   #4015
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Been saying this for years
Old June 30th, 2013, 05:15 PM   #4016
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Installed a 28 liter coocase
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old June 30th, 2013, 06:07 PM   #4017
rcruz17
rcruz17's Avatar
Motorcycle(s): 09 250r
went from this....
To THIS!!!
along with black screws and black double bubble
now that I have it I dont like the windscreen its way to dark and wont work with the gopro I have on the way and the gas tank mount I had planned out to use....and kinda like the single bubble look anyways...up for trades for a light smoke one if anyones interested?
rcruz17 is offline   Reply With Quote
Old July 1st, 2013, 10:38 AM   #4018
BIGREDIOWAN
Motorcycle(s): Kawasaki Ninja 250R
In the process of plasti-dipping my windshield. Looks good so far, but really won't know until I remove the tape and newspaper and see how it looks. I have about 5 coats on now.
Addendum: Just finished the windshield and went to install it. Bottom screws of the windshield won't go back in now because the stupid rubber nuts that the screws go into are dry rotted and destroyed........................just awesome! The top ones went back in, but I have no idea what I need to remove to get to the bottom ones well enough to fix this problem. Anyone had to replace those before? How'd you do it, point me to a thread if there is one on this process.
Last futzed with by BIGREDIOWAN; July 1st, 2013 at 12:11 PM.
BIGREDIOWAN is offline   Reply With Quote
Old July 1st, 2013, 01:14 PM   #4019
CanyonKid
CanyonKid's Avatar
Motorcycle(s): '04 250r
Just beat the rain. I wanted to put some miles on the new Sport Demons. What a difference over the stock Dunlops. I feel a bit more confident to say the least. Not happy with the size of my strips though, I'll give 'er some time.
CanyonKid is offline   Reply With Quote
Old July 1st, 2013, 01:36 PM   #4020
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Put a few dry and wet miles on it... Still ain't to keen on wet miles
Old July 1st, 2013, 02:15 PM   #4021
Driddle
Driddle's Avatar
Took it in to have the tires changed and brake pads replaced. But not before I went on an almost hour ride (:
Driddle is offline   Reply With Quote
Old July 1st, 2013, 05:48 PM   #4022
Jred
Motorcycle(s): Several
Cut the kickstand bracket off - going racing this weekend.
Jred is offline   Reply With Quote
Old July 1st, 2013, 11:56 PM   #4023
Kokosun
Are you sure about that?
Name: That's "Sir" to you!
Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF
Sport Demons
I really like the Sport Demons too. Despite Pirelli's less than stellar performance on McLaren F1 cars this last weekend, they're performed admirably on my little ninjette.
Kokosun is offline   Reply With Quote
Old July 1st, 2013, 11:58 PM   #4024
Kokosun
Of course, it's all down to personal taste, but I think that your bike looks fantastic ... and I love the new screen.
Old July 2nd, 2013, 04:44 AM   #4025
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Link to levers
Originally Posted by antiant View Post
I got my CRG R/C Spectrum brake and clutch levers installed and my Yoshimura FE Kit installed. The friction zone is a lot better for me with these, now that I can adjust them accordingly.
Antiant, do you have a link to these levers?
baxtc1 is offline   Reply With Quote
Old July 2nd, 2013, 08:13 AM   #4026
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Yes, I do... http://stores.sportbiketrackgear.com/Detail.bok?no=7667
Old July 2nd, 2013, 01:43 PM   #4027
rcruz17
rcruz17's Avatar
thanks I havent taken the bike out yet after that but the main problem I have with it is that I wont be able to use the gopro like I originally intended
Old July 3rd, 2013, 03:10 AM   #4028
leogenesis
Motorcycle(s): Kawasaki Ninja 250r 2010 Black
put on my R&G blanking plate for the footpeg removal and the exhaust hanger.
leogenesis is offline   Reply With Quote
Old July 3rd, 2013, 03:25 AM   #4029
psych0hans
psych0hans's Avatar
Old July 3rd, 2013, 03:27 AM   #4030
baxtc1
baxtc1's Avatar
Thanks for the link, they look good, but a bit too expensive for me.
Old July 3rd, 2013, 07:15 PM   #4031
sunspots
sunspots's Avatar
Motorcycle(s): 08 Plasma Blue 250
Changed the oil. My first oil change ever. Easy peasy lemon squeasy.
sunspots is offline   Reply With Quote
Old July 3rd, 2013, 08:01 PM   #4032
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Installed hyper-lite rear blinkers to complement my intergrated tail light.
Old July 3rd, 2013, 09:45 PM   #4033
tfkrocks
tfkrocks's Avatar
Went on a ride and on the way back I started having major issues shifting gears. Downshifting to 1st and 2nd was a bit of a fight. Realized I wasn't even getting into 1st when I stalled at a light. Had to stomp the hell out of shifter to get back into 1st to start the bike. Also noticed that the clutch isn't completely disengaging when pulled in because I would also start moving at lights if I didn't stay on the brake. Got home and noticed that the clutch cable isn't in the greatest shape.
Would replacing the cable solve the problems I was having?
Old July 3rd, 2013, 09:49 PM   #4034
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
What makes you think it not in best of shape?
When the bikes off and in neutral is there a lot of play(slack) in the lever or is it tight( no slack)?
Old July 3rd, 2013, 09:59 PM   #4035
tfkrocks
tfkrocks's Avatar
It looks partially unraveled. There's quite a bit of slack in the lever.
Ah ****, I just went to check from the front and cable is frayed halfway through. Definitely replacing that...
Old July 3rd, 2013, 10:03 PM   #4036
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
So no group ride for you tomorrow
Old July 3rd, 2013, 10:06 PM   #4037
tfkrocks
tfkrocks's Avatar
Nope. Hopefully the dealer has a clutch cable for me.
Old July 3rd, 2013, 10:10 PM   #4038
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
If it's that loose then tighten it up a couple turns and it should shift again so you can get to the shop to get a new cable. A general rule of thumb is to have 1/16"-1/8" of slack in the cable. Just lightly with one finger pull the lever till it snugs and check the gag between the lever and perch at the widest point.
like this
Old July 3rd, 2013, 10:16 PM   #4039
tfkrocks
tfkrocks's Avatar
I wonder if anywhere is even open on July 4th... Need to get in lots of riding this long weekend!
Old July 3rd, 2013, 10:30 PM   #4040
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Independent day sales at all the car dealerships, maybe motos as well.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
