Old October 18th, 2017, 07:28 AM   #7961
Originally Posted by perplexed View Post
(SNIP)
Front fork seals need doing, so starting to look into how to do that myself... sure hope I have the tools I need to do that. Going to be very expensive if I have to use a mechanic.
any tips welcomed
If you can remove the forks and drain/disassemble them before taking them to a shop it would be a lot less expensive than just bringing the cycle in and having them do the entire project.
Old October 18th, 2017, 08:11 AM   #7962
perplexed
perplexed's Avatar
Motorcycle(s): 09 Ninja 250R..... BLUE, 2000 Kawasaki W650
great idea, thanks! Might call the shop tomorrow for a quote
perplexed is offline   Reply With Quote
Old October 18th, 2017, 08:23 AM   #7963
Ram Jet
Ram Jet's Avatar
Good God. If you go that far why not just grab the appropriate size socket and wack the new seals in?
Bill
Old October 18th, 2017, 08:41 AM   #7964
Bill
Not always quite that simple, but you could try...
Old October 18th, 2017, 08:44 AM   #7965
perplexed
perplexed's Avatar
if its easier than pulling out carbs, cleaning, and reinstalling them, then maybe I should suck it up and have a crack at it.
Old October 18th, 2017, 09:06 AM   #7966
I didn't find it to be difficult. They're a little different from what I was used to, but this helped:
https://faq.ninja250.org/wiki/How_do..._fork_seals%3F
Old October 18th, 2017, 09:31 AM   #7967
Ram Jet
Ram Jet's Avatar
Nearly the same but a-lot more fun.
Bill
Old October 18th, 2017, 10:17 AM   #7968
perplexed
perplexed's Avatar
appreciate the link, thanks! Hadn't come across that one just yet.
Old October 18th, 2017, 09:41 PM   #7969
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
finished cam phasing and putting top end together. getting to measure carb dimensions for velocity stack price quote.
"trying not to get old"
Old October 19th, 2017, 04:15 PM   #7970
If you haven't purchased stacks yet, I'd recommend a different more effective design...
As with every type of manufacturing, you have to balance costs-of-production vs. performance-results. In this case, I believe they have compromised performance for ease-of-manufacturing.
Old October 19th, 2017, 05:08 PM   #7971
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
The parts fairy dropped off a GSXR shock!!!
Dave Wolfe is offline   Reply With Quote
Old October 19th, 2017, 05:10 PM   #7972
mgentz
Board Member
Found out the block was warped causing overheating issues due to coolant loss.
Old October 19th, 2017, 05:23 PM   #7973
Awesome! Please take pictures when you install, I'm going to do that soon too!
Old October 19th, 2017, 09:37 PM   #7974
maverick9611
MOTM - Feb '18
no i have purchased yet, waiting on price quote. what’s your design idea?
Old October 19th, 2017, 09:56 PM   #7975
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I took the chain off and dropped it in diesel for the next couple days.
TEAM ALFALFA
www.apexassassins.com
Old October 20th, 2017, 01:28 PM   #7976
For the effort, you can get decent performance. The bellmouth shape is most critical area of the stacks.
Angle of the tube also contributes tremendously and you'll want a 7-15 degree taper. Between 0-7 degrees is a no-mans-land with no benefits. The heyday of velocity stacks were in the 60s with GP Ferraris. For same amount of time and effort that you're going to expend, might as well get most out of it.
I suggest an elliptical bellmouth with at least 180-degree rollback and 10-15 degree taper. And made from stainless steel for much better heat-insulation than aluminium. I try to keep as much heat out of the intake-air as possible. You'll want bellmouth about 2x diameter of inlet.
Old October 21st, 2017, 07:01 AM   #7977
maverick9611
MOTM - Feb '18
thank you jac, i fwd info to steel dragon.
Old October 21st, 2017, 07:02 AM   #7978
maverick9611
MOTM - Feb '18
shock off 600 model? which years? thanx
Old October 21st, 2017, 08:17 AM   #7979
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Yep, gsxr 600 2006-07.
Looks like the hardest part of the conversion will be figuring how to prop up the bike.
Old October 21st, 2017, 12:29 PM   #7980
Hang it from rafters in garage!!!
Old October 21st, 2017, 08:28 PM   #7981
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Took off the back lenses and changed out a tail light. Not as bad as I'd feared it could be, one screw for the side plate and the lens came right out. Change the lamp, and the lens goes back in. I was pleased at how easily it fit back.
Then, of course, one has to take the bike out riding. The Snake in the late afternoon was lovely, almost deserted.
Old October 22nd, 2017, 04:35 PM   #7982
coast2coast
Motorcycle(s): 09 ninja 250, 2016 zx10r
I pulled the 250 out of the storage shed where its been sitting unused for 3-4 years. It started to rain so tomorrow ill find out just how much work it needs before I can use it again. It needs a valve job for sure.
coast2coast is offline   Reply With Quote
Old October 22nd, 2017, 04:37 PM   #7983
Hi Dennis, welcome to the board. Unfortunately it is almost sure to need the carburetors completely disassembled and thoroughly cleaned. The fuel tank will probably need to be cleaned out with something to remove the crud, if it looks bad inside. The petcock and fuel lines may have suffered too. I stored a motorcycle for a friend here in my climate controlled garage for about that long, and it needed all of the above to run properly again.
Old October 22nd, 2017, 05:09 PM   #7984
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
cleaned and lubed the chain. fabricated an exhaust pipe to kill DB level in hopes to go to laguna next summer.
File Type: jpg 22766756_10155896151207010_1227532159_o.jpg (86.5 KB, 7 views)
TEAM ALFALFA
Old October 23rd, 2017, 05:54 AM   #7985
maverick9611
MOTM - Feb '18
put all the plastic back on😵filled up tank and getting ready to ride
Old October 23rd, 2017, 06:39 AM   #7986
As TJ noted - carbs and fuel are going to be the first things that will need attention most likely.
I would expect it may need a "valve adjustment" (setting clearances between the valve and rocker) , but not a "valve job" (removing the head, valves, and grinding the valves and seats).
We bought a 2004 with 250 mi that had been sitting for over 8 years, and after carefully cleaning/adjusting the carbs, completely draining the tank and adding fresh gas, replacing the battery, and changing the oil/filter it fired right up.
Old October 23rd, 2017, 07:12 AM   #7987
Ram Jet
Ram Jet's Avatar
[/B]
250 miles!?!? it must have still had the little "hairs" on the tire tread. Lucky find - I don't want to know what you paid for it.
Bill
Old October 23rd, 2017, 08:01 AM   #7988
Bill
Ha - we have been lucky. That was my oldest son's first street bike. PO bought it new for his ex-girlfriend back in '04. She dropped it in the driveway from the looks of it (broken front signal) and never rode it again. We bought it in 2012, not running, with 250 mi and sold it last year.
We paid $750 for it (sorry...). Sold it for $2000 with about 5000 mi, but it had new tires and all maintenance (valve adjustment, carb sync, new fluids, etc) done and not a scratch on it.
Old October 23rd, 2017, 08:59 AM   #7989
Ram Jet
Ram Jet's Avatar
Looks like you go paid to ride it! Proud of you!
Bill
Old October 23rd, 2017, 11:28 AM   #7990
Looks like you got paid to ride it! Proud of you!
Bill
Thanks, but my son did all the work and got the profit.
His second Ninja 250 project was a '90 that went down pretty hard (trashed the fairings) that he got for $150. Put tires on that as well, and did all the maintenance. Ran good - looked bad. Sold it last year for $850 after putting about 8000 mi on it.
The profits helped him buy a decent older VFR800.
Old October 23rd, 2017, 01:09 PM   #7991
coast2coast
[/B]
Yeah was meaning to say valve adjustment, slip of the keyboard
Its going to be my first carb cleaning so that should interesting, and lengthy. Thankfully there are about a million how to videos and threads even on this forum on how to do it.
First track bike as well, so lots of new stuff for me to learn. Just wish I had a heated garage since its now pretty much winter here.
Old October 23rd, 2017, 01:14 PM   #7992
If you have trouble with the carbs or just don't have time to mess with them, Ducatiman here on the board is known for excellent full refurbishments at a reasonable price.
Old October 23rd, 2017, 01:35 PM   #7993
Beat me to it TJ.
Depending on their skill level, patience, attention to detail, and tools, some people prefer to have it done professionally.
If Gordon does your carbs you will get them back looking like new, properly adjusted, and bench tested.
Some of the info out there makes it sound easier than it really is to get it right.
Old October 23rd, 2017, 07:44 PM   #7994
coast2coast
I'm in Canada so shipping the carbs down to the states is basically a no go, although its awesome the option is available and by someone who knows the specific carbs. I'll try and bumble**** my way through my first carb cleaning. Thankfully i know a few folks who know small engine stuff if I get into a little too deep of water.
Worst case scenario, I gotta ebay another set of carbs and pay someone to fix those but I'm hoping it doesn't get to that.
Gotta try and save some cash, need some more parts since its a track bike now.
Old October 23rd, 2017, 07:57 PM   #7995
Ram Jet
Ram Jet's Avatar
Hey Dennis,
I've purchased several eBay items from my Canadian brothers in the past and the Canadian/U.S. post seems to work very well. It's Australia and China that's the big pain in the tail feathers.
Bill
Old October 25th, 2017, 06:13 AM   #7996
maverick9611
MOTM - Feb '18
installed 112 mains. still testing
Old October 30th, 2017, 06:08 AM   #7997
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Thought it would be fun to have a yard sale in turn 15 yesterday battling for 4th.
File Type: jpg 16757E69-04AF-4454-945D-32611BA567C9.jpg (156.6 KB, 6 views)
File Type: jpg 524863F9-A6DE-4AAA-9917-D2CA3795B2C7.jpg (163.6 KB, 3 views)
TEAM ALFALFA
Old October 30th, 2017, 06:31 AM   #7998
Ram Jet
Ram Jet's Avatar
Eeeeeyowww! Oh, Chris, you got some splainin' to do! Are you OK? And you thought you were going to be bored this winter.
Bill
Old October 30th, 2017, 07:28 AM   #7999
Bummer. Hope you are OK.
You know the saying - "You should see the other guy!"
Old October 30th, 2017, 08:09 AM   #8000
Oh no!!!
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
