Old January 14th, 2010, 05:06 PM   #1
CGNY87
Motorcycle(s): 2007 Kawi Ninja 250
WTB: Ninja 250 turn signal wiring
I am looking for the silver "bullet" wire connectors that connect the turn signal wires to the bikes wires. I only need the male (turn signal end) connectors.
Hopefully someone on here is selling thier stock turn signals. I would prefer just to by the wire with the connector attached but if I had to I would possibly buy the whole turn signal [rear or front -- it doesn't matter]
PS - I need four (two for each turn signal)
Last futzed with by CGNY87; January 18th, 2010 at 04:13 PM.
CGNY87 is offline   Reply With Quote
Old January 15th, 2010, 01:04 AM   #2
currentsea
currentsea's Avatar
Hey CGNY87,
The folllowing thread contains links to OEM electrical connectors:
http://www.ninjette.org/forums/showt...ght=connectors
currentsea is offline   Reply With Quote
Old January 15th, 2010, 01:15 PM   #3
HKr1
IC2(SW)
HKr1's Avatar
Moto911 sells some too:
http://www.moto911.com/product_info....218ff883d63fc3
Old January 18th, 2010, 04:08 PM   #4
CGNY87
thanks for the posts guys but I dont think those will work.
Moto911 only sells the female end. and the .50 connectors from eastern beaver look way to big.
I just bit the bullet and ended up cutting off the stock turn signals wires and am using a "twisty cone" thing (cant think of the name) to connect it to my asiancycle flushmounts. Then wrapping in electrical tape. Just tested them and they work.
Just need to bolt them on when the temp gets above 20 F - LOL
Last futzed with by CGNY87; January 18th, 2010 at 06:14 PM.
Old January 20th, 2010, 07:01 AM   #5
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
Those twisty cone things are marrettes, and I would recomend doing it right and soldering it properly. Marrettes are good for residential wiring that won't be moving at all. I'd be worried about them falling off. If you don't know how to solder the crimp style connectors would be a better bet. If you use the spade type crimp connectors wrap them in electrical tape to seal it. Best thing though would be to solder
Using Pedal Power
divingtigger is offline   Reply With Quote
Old January 20th, 2010, 08:55 PM   #6
CGNY87
yea i haven't soldered anything since like 9th grade tech class.
I have some of the wire crimp connectors. Im gonna try the marrettes- for now anyways. I'll just have to keep an eye on them. At the first sign of somethiong wrong i'll switch to the crimpers. Thanks for the advice.
2007 250 | Shoei Camino RF-1000 | Cortech FSX Series 2 Jacket | Castle Sport Mesh Gloves | Joe Rocket Manta Tailbag | Fieldsheer Lid Pack | Fender Eliminator | Integrated & Flush Mount Turn Signals
Old January 20th, 2010, 08:58 PM   #7
Momaru
Momaru's Avatar
Might consider looking thru this thread; soldering effectively is fairly easy even if making it pretty isn't. I'm actually just getting ready to sit down and solder some extensions to some flush-mounts.
http://www.ninjette.org/forums/showthread.php?t=35703
Proud member of the Blue Army
Old January 20th, 2010, 09:08 PM   #8
CGNY87
actually i just did some research and you guys seem to be right - not that i really doubted you.
im looking into some methods and will probably end up removing the wire nuts and using another method. I would love to solder but dont have any equipment for it. I may have to bribe some workers at Lowes or a buddy or two. LOL
i was hoping to be done wit this project but i want it done right.
i do have some wire crimp connectors made by AMP. They are size 12-10. What size are the turn signal wires?
Old January 20th, 2010, 09:38 PM   #9
Shano22
Shano22's Avatar
Motorcycle(s): 2005 Kawi Ninja 250, 2004 Honda CBR600 F4I, 1999 Yamaha TTR225(dirtbike)
i have 2 rear turn signals off my fender cause i did the fender chop and integrated the signals. I have the housings, sockets, lense, and the wire you need but its only the 2 pairs if your interested, PM me if you are.
Shano22 is offline   Reply With Quote
Old January 21st, 2010, 04:57 PM   #10
CGNY87
I found what im using either Posi-Tite or Posi-Lock. Tite are 100% waterproof, vibration proof and extremely easy to install. Apparently Posi tested them by submerging them for over 12 months with no water getting in. The only problem is they cost like 9$ for 3 of the Tites or 9$ for 6 of the Tites. I think I may go with the tites and just wrap them in electrically tape
Old January 22nd, 2010, 01:32 AM   #11
jonthechron
Motorcycle(s): magHitVE
Soldering is the way to go, or at least use some crimp connectors with shrink tubing to do the job, wire-nuts (Marrettes) are used in areas where exposure to weather or vibration are not a major concern)
wiring for flush mount front turn signals for 07 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 October 4th, 2013 01:35 PM
WTB: Turn Signal/License Plate Bracket for 09 Ninja 250 + More UjaasG35 Items Wanted 3 May 16th, 2012 05:03 PM
WFF or WTB 2008 Plasma Blue Ninja right fairing, brake lever and peg, turn signal mrpl2e5t0n Items Wanted 4 November 5th, 2011 03:12 AM
WTB: Right side front turn signal and passenger seat for 08+ Ninja 250r... maichang Items Wanted 0 May 9th, 2011 07:00 PM
WTB: 08 250 left front turn signal badcop621 Items Wanted 1 June 25th, 2009 10:35 PM
