Old August 23rd, 2009, 04:28 PM   #1
ScorpionNinja
ScorpionNinja's Avatar
Cover-Comp,Chain #14041
Its raining and storming atm, so i cant pull my Nate outta the shed for PICS of what im asking about atm. So im wondering what besides the 3 bolts you remove to take off the front sprocket guard? i noticed yesterday the cover has a TON of grime i need to scrap and clean, only Easy and Optimal cleaning with this front cover taken off! I noticed the shifter linkage also passes through this front cover... ummm im unsure of specs and torques needed, or a manual that shows how this to be taken apart step by step. I dont have a 250R shop manual. Anyone have exp in taking off their front sprocket cover with some Pics and DIY instructions by chance?
Thanks! dave
Old August 23rd, 2009, 07:15 PM   #2
ScorpionNinja
i found the DIY on here. Ummm it doesnt give any info on the torque spec of that bolt that the shifter attaches too, nor the correct positioning on putting it back on. Ummm mark it with a Paint slash prior to taking it apart....to help re-line that bolt up once putting it back together, would be good enuff?
Old August 23rd, 2009, 07:26 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
torque specs for all fasteners are in the wiki
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 23rd, 2009, 07:41 PM   #4
ScorpionNinja
im confused, you have FT.LBS listed on some things (bold top listings)
but right under it says IN.LBS ... so which is it? or what is IN.LBS = FT.LBS?
I need a IN.LBS torque wrench too now?
Torque
N*M | kgf*M | ft*lb
____________________
|>>>>>>>>>| 87in*lb
this is listed for teh front sprocket cover thingy, what is ft lbs Equal too in IN lbs?
Old August 24th, 2009, 07:29 AM   #5
g21-30
g21-30's Avatar
Torque
N*M | kgf*M | ft*lb
|>>>>>>>>>| 87in*lb
12"=1 ft; therefore, 87 in-lb = 87/12= 7 ft-lbs and 3 in-lbs, i.e. roughtly 7 1/2 ft-lbs
To convert ft-lbs to in-lbs, multiply by 12, i.e. 80 ft-lbs = 80*12 = 960 in=lbs
Old August 24th, 2009, 08:32 AM   #6
rockNroll
rockNroll's Avatar
Motorcycle(s): black
It's marked from the factory, there's a mark on both pieces... they look like center-punch marks, for aligning the two pieces. Put a dab of blue thread locker on the pinch bolt
Plastic chain guard / cover walty87 General Motorcycling Discussion 14 June 25th, 2014 05:35 PM
swing arm covers? chain cover? shift lever? ac9im11 2008 - 2012 Ninja 250R Tech Talk 1 April 30th, 2014 11:11 PM
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? CZroe 2008 - 2012 Ninja 250R Tech Talk 56 July 7th, 2012 05:42 PM
Aftermarket chain guard/swingarm cover drumm3r9 2008 - 2012 Ninja 250R Farkles 11 November 4th, 2010 08:29 AM
