Old March 2nd, 2011, 10:05 AM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Tire recommendations for commuters?
I travel 40 miles a day round trip and about 38 of those are freeway miles. I only have 1 bend which allows me to lean the bike. Otherwise, even the entrance and exit ramps are shallow turns. This has lead me to have a noticeable flat wear in the middle of the tire. Are there tires out there built for this type of riding that will fit our bikes? Grip in turns is always important, but I could give some of it up for a tire that won't wear out the middle too fast. I also don't ride in the rain, so wet traction can be minimal.
The www.ModMy250.com guy
Old March 2nd, 2011, 10:29 AM   #2
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
darkside tires...
caps is offline   Reply With Quote
Old March 2nd, 2011, 10:37 AM   #3
CThunder-blue
ModMy250.com
That helps me not at all.
I'm thinking of Michelin Pilot Activ Rear Tire. Anyone have experience with them? http://www.motorcycle-superstore.com...Rear-Tire.aspx
Old March 2nd, 2011, 11:01 AM   #4
almost40
ninjette.org Monkey Spank
almost40's Avatar
GT 501's or BT-45's would be a good choice also.
None of the tires will last forever but the harder compounds will last longer.
these 2 are a little harder but still stick good in an emergency.
Black 250R
Full Area P QC
Old March 2nd, 2011, 11:08 AM   #5
what tires do you have now?
Old March 2nd, 2011, 11:08 AM   #6
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
I commute 70 miles a day so once the IRC's are gone I am picking up the BT-45's since they were recommended and offer better traction.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old March 2nd, 2011, 12:01 PM   #7
CThunder-blue
ModMy250.com
I have BT 003's I believe.
Old March 2nd, 2011, 12:07 PM   #8
KGar
Mid Life Crisis
KGar's Avatar
Motorcycle(s): 2010 Ninja 250r (Passion Red); 1999 BMW K1200RS (Marrakesh Red)
I commute 75 round trip and will go through the stockers in no time. This is good info. Are the BT-45's dual compound?
KGar is offline   Reply With Quote
Old March 2nd, 2011, 12:29 PM   #9
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
bt-45's no question. better grip than 501's, similar treadlife. i put 300+ miles on the bike a week - my bt-45's have 10k on them - still look good.
want1sobad is offline   Reply With Quote
Old March 2nd, 2011, 12:33 PM   #10
KGar
Mid Life Crisis
KGar's Avatar
Excellent, bt-45s it is.
Old March 2nd, 2011, 12:50 PM   #11
these are not stock tires... were the tires changed previously? what size tires are presently on the bike?
Old March 2nd, 2011, 01:52 PM   #12
CThunder-blue
ModMy250.com
The PO installed the new tires just before he sold the bike to me. I have about 4k on them.
Old March 2nd, 2011, 01:54 PM   #13
want1sobad
Ninjette CPT
want1sobad's Avatar
good choice - best source:
http://motorcycle.motorcycle-superst.../search#w=bt45
Old March 2nd, 2011, 02:17 PM   #14
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
Where's the best place to buy BT-45's? When the weather warms up a little more I'll be commuting (110 miles round trip) on the bike occasionally. Gonna go through tires pretty quickly...
Edit: Oops, didnt see the previous post.
Last futzed with by NJD022588; March 3rd, 2011 at 06:49 AM.
NJD022588 is offline   Reply With Quote
Old March 2nd, 2011, 02:47 PM   #15
those are very sticky, race compound tires which is surprising that you got 4k out of them. if you go with the OEM bt045 tires, which is a bias ply tire, I'd say you will be in for a significant change in bike handing as well as grip level that you've most likely have taken for granted by starting off with the 003s.
my recommendation for a good radial tire is the bt016 in 110/70 and 150/60 sizes. It remains sticky, wears well and improves the grip level over the OEM bias ply tires.
if you decide to stick with an OEM bias ply type tire in stock sizes, the 045s are a good choice as well as the Dunlop gt501s for a good mix of grip and longevity.
btw, you are planning to change both tires, correct? it is not advisable to use mixed tire construction types between front and rear. (ie. radial front and bias ply rear)
Old March 2nd, 2011, 02:55 PM   #16
CThunder-blue
ModMy250.com
Thanks for the advice Kelly. I will need to check out the front tire to see what I have and will match it up accordingly to the rear. I don't see a reason to throw away a good tire if it's not worn. So no opinion on the michelin's?
Old March 2nd, 2011, 03:06 PM   #17
sorry, no info on the michelin, though I think I have seen them mentioned on ninjette. have you done a search to see if someone has provided feedback on these particular tires?
Old March 2nd, 2011, 04:16 PM   #18
CThunder-blue
ModMy250.com
I read the wiki on tires on here, but that's about it. There's a lot of good reviews on it from MC superstore. I may go with the BT45's. I've had michelins on my car before and was pretty unhappy with them. Not sure if their philosophy of car tires also applies to their bike tires.
Old March 2nd, 2011, 04:41 PM   #19
bob706
bob706's Avatar
I have pilots front and rear and love them. Only have a little over 2K on them. My original tires were 501's and they lasted about 14K but ended up with pretty good cupping.
Old March 2nd, 2011, 04:54 PM   #20
CThunder-blue
ModMy250.com
Thanks Sean. You have the Pilot Activ or a different model?
Old March 2nd, 2011, 05:25 PM   #21
littledog
littledog's Avatar
Motorcycle(s): 2009 Special Edition Ninja 250 a good memory, 2011 Suzuki DL 650 the new ride
kenda 671 is an inexpensive bias ply tire that comes in the right sizes.
littledog is offline   Reply With Quote
Old March 2nd, 2011, 06:04 PM   #22
bob706
bob706's Avatar
I have the Activs - 140 rear 110 front
Old March 2nd, 2011, 08:29 PM   #23
CThunder-blue
ModMy250.com
Cool. That looks to be the size of my rear. Does anyone know if the BT 003's are radial?
Old March 3rd, 2011, 04:06 AM   #24
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Yes. It is a multi-compound radial, with a different compound for center tread and shoulder, with a belt underneath. These should probably be thought of as track-day tires not designed primarily for street use and bad in the wet. They would make a bad every day tire, imho, even the 003RS. The BT-016 would be the better street tire and still offers excellent grip. KKim has the 016s and swears by them.
Old March 3rd, 2011, 06:15 AM   #25
dubojr1
dubojr1's Avatar
I LOOOOOVE my 016's....
My commute is approx. 50 miles round trip.
Last futzed with by dubojr1; March 3rd, 2011 at 06:16 AM. Reason: add additional info
Old March 3rd, 2011, 08:44 AM   #26
CThunder-blue
ModMy250.com
Thanks Floyd. Looks like I'll need to do both front and rear at the same time then. Jason, how many miles on them do you have and what's the wear like?
Old March 3rd, 2011, 09:07 AM   #27
dubojr1
dubojr1's Avatar
Well I will first say I'm a prolly a bit harder on my 250's tires than most. Being used to riding a 1000RR, I generally push my lil ninja to its limits often with hard acceleration and heavy braking. This is one of the reasons I went with the 016's. Grip is excellent BTW. As far as wear, I've got about 2,500 miles on them now and I'm pleased with the way they are wearing. Even with my commute, they seem to be keeping their circular shape. I haven't really noticed a "flat" spot on them yet. If I had to guess right now I'd say there is prolly about 30% worn but I'll try to snap a couple high quality pics of both front a rear and post them so you can judge for yourself. As far as I am concerned though, these are by far the best tires for my riding style.
Here is a baseline to start with. First couple is when I installed them. The 3rd picture was with about 500 miles.
Old March 3rd, 2011, 09:09 AM   #28
CThunder-blue
ModMy250.com
Is your commute mostly straight?
Old March 3rd, 2011, 09:20 AM   #29
dubojr1
dubojr1's Avatar
Mostly...
The "Florida 9A" and I-95 are highway speeds. Like I said though, I prolly corner faster than most too. Every chance I get I have mine leaned as far as I can. I'm thinking this along with the 016's different compounds allows the tire to wear more evenly.
Old March 3rd, 2011, 09:24 AM   #30
CThunder-blue
ModMy250.com
Yeah, the leans that you get to have most likely help. It looks like you have 4 bends in your commute that allows you to get a lean. I get 1 and that's on my way to work. On my way home, I take a different route that doesn't even have 1 bend except for an exit.
Old March 3rd, 2011, 11:07 AM   #31
almost40
almost40's Avatar
Kudos to KKim for asking what tires you are riding now. I assumed you were on the stockers. I agree with the above comments and would go with the BT-16's. Great tire for track and street.(thats whats on my 250 now)
Black 250R
Full Area P QC
Old March 3rd, 2011, 12:36 PM   #32
CThunder-blue
ModMy250.com
are the bt 16's better than the 45's?
Old March 3rd, 2011, 12:40 PM   #33
dubojr1
dubojr1's Avatar
Define better...
Better for commuting?
Old March 3rd, 2011, 12:54 PM   #34
almost40
almost40's Avatar
YES BT-16's are dual compound tires. Wont last as long, but much better grip. On top of that they are radials.
Black 250R
Full Area P QC
Old March 3rd, 2011, 12:54 PM   #35
CThunder-blue
ModMy250.com
Yes. I'm not interested in track use.
Old March 3rd, 2011, 12:57 PM   #36
dubojr1
dubojr1's Avatar
You need 016's then. Bottom line IMHO.
Old March 3rd, 2011, 01:00 PM   #37
Really? The thread is started with a request for tires that are good for commuting, have long wear, and consistent handling, and the answer is the BT-016's? Color me skeptical.
Old March 3rd, 2011, 01:02 PM   #38
again, define "better". what's good to you? what are you looking for in a tire? it's all about priorities between grip, mileage and price. rank those and I can possibly recommend a tire based on your priorities.
Old March 3rd, 2011, 01:03 PM   #39
dubojr1
dubojr1's Avatar
Old March 3rd, 2011, 01:06 PM   #40
almost40
almost40's Avatar
If your running the 003's the BT-16's are a little step down in traction and a big step up in tire life.
The BT-45's are a much bigger step down in traction (and safety IMO) but you will get longer tire life than the 16's
The 16's are a dual compound radial
The 45's are a single compound bias-ply.
I dont know the mileage difference between the 16's and the 45's but I would assume that its not huge. Im sure the 003's wear mega fast because they are more of a track tire than a street tire. The 16's are the best of both worlds. Im sure someone here has a mileage total for the 16's, Im not that guy. I can say that I did 2 weekends on the track (in I-group, and I wasnt taking it easy out there )on my 16's and 2000 miles on the street and they still have tons of tread left.
Best bang for the buck = BT16
Black 250R
Full Area P QC
Tire recommendations for NYC rider? nliu314 2008 - 2012 Ninja 250R Tech Talk 2 June 11th, 2012 12:53 PM
Got a flat...now need a new tire. Need recommendations on an upgrade Hitman 2008 - 2012 Ninja 250R Tech Talk 4 July 25th, 2011 05:10 AM
To the commuters CThunder-blue General Motorcycling Discussion 66 July 15th, 2011 08:05 PM
Ideal Tire repair kit and portable air pump recommendations? setasai General Motorcycling Discussion 12 July 6th, 2011 08:44 AM
Tire Pressure recommendations 2up GeorgiaHooligan 1986 - 2007 Ninja 250R Tech Talk 9 April 14th, 2011 08:08 AM
