Old February 4th, 2013, 10:57 PM   #1
sLick415
Bike won't start
So today I successfully fixed my leaking petcock. I figured I may as well clean my carbs while im in there even though my bike ran just fine. After removing the carbs, I realised I wasnt gonna be taking out any of the JIS screws without stripping them so I decided to just the put the carb back into the bike. All the hoses are back where they should be, tank back on, petcock set to prime and engine just wont turn over. Any ideas?
sLick415 is offline   Reply With Quote
Old February 4th, 2013, 11:04 PM   #2
tubarney
set petcock to on.
Old February 4th, 2013, 11:06 PM   #3
sLick415
Tried that as well. Checked the vacuum as well when i crank it and it is working
Old February 4th, 2013, 11:07 PM   #4
tubarney
wait it doesn't turn over or it doesn't start? Two completely different problems.
Old February 4th, 2013, 11:10 PM   #5
sLick415
Sorry itll turn over but wont start.
Old February 4th, 2013, 11:19 PM   #6
tubarney
put it in neutral and turn the throttle all the way (WOT) then start it. Assuming you have done everything right and somethings not stuffed I think its either flooded or got no fuel in bowls of carbs. WOT when starting puts it in 'clear flood mode'.
Old February 4th, 2013, 11:25 PM   #7
KELPHYN
KELPHYN's Avatar
turn petcock to PRIME. in the ON postion it will take a fair bit of cranking to fill the carbs.
Old February 4th, 2013, 11:38 PM   #8
sLick415
Hey that worked. Thanks!!
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
Bike won't start FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 127 November 17th, 2013 03:18 PM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
