Old May 8th, 2014, 09:39 PM   #1
heroin300
Motorcycle(s): Ninja 300
'07 250 won't start
My buddy just got a 2007 Ninja 250 not too long ago. It started having problems on Sunday, having problems staying on, and eventually not even starting. Here's a video we just took of the bike trying to start. http://youtu.be/j6qxU7DyXuk
Things we did recently was change the oil/filter, changed the spark plugs, clean the carbs, adjust the jets to 2 1/2 turns out, removed baffles from stock exhaust(beginning of our problems), replaced baffles(got worst), tried removing gas from motor(nothing came out), changed oil again, all in that order. We also disassembled and reassembled the bike multiple times in between. Buddy and I are both fairly new to bike and don't want to have to take the bike to mechanic, so any help would be greatly appreciated.
Thanks!
heroin300 is offline   Reply With Quote
Old May 8th, 2014, 10:07 PM   #2
jschorr
jschorr's Avatar
Motorcycle(s): 1995 ninja 250r
did you check out the petcock. ie make sure the carbs were getting gas?
jschorr is offline   Reply With Quote
Old May 8th, 2014, 10:29 PM   #3
heroin300
At one point I figured that might be the problem, so I disconnected the vacuum hose from the carbs and sucked it. The gas filter began to fill with gas so I assumed the petcock was working properly. When we try to start the bike after reassembling it, the filter fills with gas, but doesn't seem to happen any time after that. We will disassemble the petcock tomorrow to see if that's the problem.
Thanks.
Old May 9th, 2014, 08:34 AM   #4
DaBlue1
DaBlue1's Avatar
Originally Posted by heroin300 View Post
....My buddy just got a 2007 Ninja 250 not too long ago. It started having problems on Sunday, having problems staying on, and eventually not even starting
...... tried removing gas from motor(nothing came out),
If you tried draining gas from the carbs and nothing came out, your carb floats are most likely the problem. They are not allowing the carbs to fill with gas.
Old May 9th, 2014, 03:10 PM   #5
heroin300
If so, what are the floats doing(or not doing) to cause this? Does that mean the floats are bad and have to be replaced, or is it a simple cleaning and reassembling?
Old May 9th, 2014, 03:24 PM   #6
jschorr
jschorr's Avatar
Not even a full strip down for floats. Take off the bottom, slide out the hinge pin and the float will come right out.
No floats don't go bad, they just....float. Not to high tech. The part that stops up is the hole leading into the float bowl. Inspect the rubber tip on the....stopper...forget the right name.
Old May 9th, 2014, 03:28 PM   #7
jschorr
jschorr's Avatar
Not to be an ass but did you make sure there was gas in the tank?
did you get to pull the petcock and check the vacuum diaphragm and screen?
Old May 9th, 2014, 03:34 PM   #8
heroin300
The tank does have gas but is beginning to run low. Have not had a chance to remove the petcock yet, will be doing that this evening after work.
Old May 10th, 2014, 07:26 PM   #9
heroin300
Ok, guys, time for an update. Yesterday we inspected the petcock and the floaters, everything seems to be fine. Thanks for your guys' help! We reassembled everything and attempted to start the bike. Well the bike started. Now we'd like to think that our week of hard work finally paid off, but in reality, it was our ignorance that was holding us back all along. Although the bike still had about half a gallon of gas, it wasn't enough to keep the bike running and eventually not start, we had to turn the petcock to "RES" to get it running.
Now I have another question. Although the bike is running better than before, the idle RPMs still vary. The bike can shut going around a corner, and then idle at about 3500. Is there a way to fix this? Any help is appreciated.
Old May 10th, 2014, 07:55 PM   #10
Yarhj
Yarhj's Avatar
Motorcycle(s): Ninja 250 (2001)
Glad to hear it was just out of gas!
<storytime>
I ran out of gas at a stoplight once, which stalled the bike. I looked down at the dash and saw that the oil pressure light was on and freaked out, thinking I had run the bike without oil and melted the engine into a solid lump of failure. After pushing the bike a block or two, I realized that the oil light comes on when the bike is on, but not running. I then rode off feeling equal parts shame and relief. And I was very relieved.
</storytime>
You can adjust the idle speed with the knob under the carbs on the left side of the bike. The bike is supposed to idle around 1300 RPMs, though anything below 2000 should be OK. Set the idle when the bike is warmed up after at least a 20 minute ride. After that, if you have trouble keeping it running with choke after a cold start, bump the idle up a bit until it's less finicky.
An unstable or rough idle (i.e. surging from 1500 to 3000 and back again randomly) when the bike is warmed up can be a sign of improper valve clearances, but other issues could cause the same symptom.
Yarhj is offline   Reply With Quote
Old May 10th, 2014, 08:59 PM   #11
jschorr
jschorr's Avatar
first
glad you got it running.
so... running like crap. ok. you probably have water in the tank. don't know if that is the problem but it is probabley there. if the gas is over a few weeks old and it is running like crap, esp if there isnt much in there, dump it and try new gas. did you install an inline filter yet?
are we talking about a properly warmed up bike here? lots of variables.
you should read this
http://faq.ninja250.org/wiki/Main_Page
all of it.
everything you need is there well explained with great pictures it will save you some time.
05 Ninja 250 won't start on its own - help! AmyF 1986 - 2007 Ninja 250R Tech Talk 59 July 8th, 2014 11:46 AM
06 250 Won't Start, Please Help! aspenratt07 1986 - 2007 Ninja 250R Tech Talk 39 May 16th, 2013 09:32 AM
06 ninja 250 won't start wolfpuss 1986 - 2007 Ninja 250R Tech Talk 7 February 21st, 2012 05:57 PM
'08 250 won't start Rynownd 2008 - 2012 Ninja 250R Tech Talk 84 September 8th, 2009 10:20 PM
'06 250 won't start Nemy 1986 - 2007 Ninja 250R Tech Talk 24 May 23rd, 2009 04:17 AM
