Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old June 12th, 2016, 04:20 PM   #1
lizardywizard
green stig
lizardywizard's Avatar
Motorcycle(s): '15 Ninja 300 ABS (Hurricane)
MOTM - May '16
How to stop bugs going up the windscreen?
So the floating windscreen design on the 300 is very cute, but the gap between the screen and the rest of the bodywork tends to suction up bugs, which then get stuck in there. They particularly like to gather up by where the mirrors connect, which is an almost impossible space to get to with just about any cleaning tool (even a q-tip is too fat).
I could take it off to clean it, I guess, but given I don't want to do that every time, does anyone make some sort of seal or guard for the bottom of the windscreen that'll keep the bugs out?
You treat her like a lady. And she'll always bring you home. --Admiral Leonard H. "Bones" McCoy
lizardywizard is offline   Reply With Quote
Old June 12th, 2016, 04:36 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I take mine off and clean it when it is really bad. I use damp rags to get down as far as I can when I clean it on the bike.
Old June 13th, 2016, 01:43 PM   #3
So the floating windscreen design on the 300 is very cute, but the gap between the screen and the rest of the bodywork tends to suction up bugs, which then get stuck in there........
A picture would help, as well as changing the ride's time away from sunrises and sunsets when bugs are more active.
Old June 13th, 2016, 02:55 PM   #4
Brother Michigan
Motorcycle(s): 2013 Ninja 300
I have actually never noticed this on my 300, even driving through literal clouds of gnats and mosquitoes.
DISCLAIMER: I generally have no idea what I'm talking about.
Old June 14th, 2016, 06:24 PM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I think the OP is talking about how the bugs get between the screen and front faring. I have this issue and I get big bugs that splatter all the way up on the inside.
Old June 14th, 2016, 09:10 PM   #6
lizardywizard
green stig
MOTM - May '16
Classy decals! I love the way your bike looks
And yes, that's exactly it. It's the stock windscreen and there's a gap between it and the front fairing that lets stuff get stuck up there.
I guess I should just take off the mirrors and screen and clean under it, but I wondered if anyone had come up with some sort of seal for around the bottom of the screen that will fill up the gap between the screen and fairing.
Why is it like that anyway? It doesn't seem like a very convenient design, either for bugs or wind noise.
Old June 14th, 2016, 10:04 PM   #7
Kevin1956
Kevin1956's Avatar
It's a very narrow gap, right? You could try a piece of auto door edge trim on the bottom edge of the windscreen to close the gap. It's available in many colors and in clear. It very flexible and just presses on. It's available from auto parts stores, automotive paint stores, and most any body shop.
Kevin1956 is offline   Reply With Quote
Old June 14th, 2016, 10:43 PM   #8
lizardywizard
green stig
MOTM - May '16
Originally Posted by Kevin1956 View Post
It's a very narrow gap, right? You could try a piece of auto door edge trim on the bottom edge of the windscreen to close the gap. It's available in many colors and in clear. It very flexible and just presses on. It's available from auto parts stores, automotive paint stores, and most any body shop. Attachment 40822
Looks like about the solution I was looking for - thanks!
Old June 15th, 2016, 02:35 AM   #9
snot
sammich maker
snot's Avatar
MOTM - Apr '15
there is a product (bug slide) that helps the bugs slide off and easier to clean.
Old June 15th, 2016, 03:29 PM   #10
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
It's specifically designed that way, to get airflow under/behind the windscreen. I thought it was something about helping the wind flow over the screen better, but my Google searches only turned up stuff about vents for rider comfort on cruisers. I'm sure someone knows the technicalities behind it. The older bikes didn't have this - it's something they've specifically added to newer bikes (as opposed to a flaw they missed fixing).
Old June 15th, 2016, 03:58 PM   #11
snot
sammich maker
snot's Avatar
MOTM - Apr '15
^ I heard the same thing
Old June 15th, 2016, 04:16 PM   #12
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Just because I don't know the facts; it won't stop me from having an opinion!
I guarantee its to stop buffeting behind the windscreen by eliminating a low pressure area. By venting, smoother, laminar airflow is created which would be perceived by the rider as a smoother ride experience.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old June 15th, 2016, 04:30 PM   #13
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I use an old t-shirt and soak it in soapy water and pull it through (gently), when I am in a hurry.
Old June 17th, 2016, 12:38 PM   #14
allanoue
allanoue's Avatar
MOTM - Sep '14
New floating windscreen design helps reduce turbulence and rider fatigue
from https://ultimatemotorcycling.com/201...a-300-preview/
Old June 17th, 2016, 05:42 PM   #15
........... Why is it like that anyway? It doesn't seem like a very convenient design, either for bugs or wind noise.
Letting some air flow next to the rear face of the windshield energizes that bubble of turbulence and low pressure created between the windshield and your upper body/head.
That extra velocity energy creates a higher throw of the flow at the top edge.
It is just a shame that bugs don't help or care about aerodynamics.
That principle has been used in airplanes as slots at the leading edges of wings, flaps, etc.
Last futzed with by Motofool; June 17th, 2016 at 06:50 PM.
Old July 29th, 2016, 06:45 AM   #16
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Love them vids
Old July 29th, 2016, 09:37 PM   #17
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I took a peek behind my windscreen once and threw up in my mouth a little.
I actually found a perfect solution for this issue. This mod cost nothing and is the most effective way resolve the issue.
Solution: I just stopped looking behind the windscreen. As far as I know, it's really clean there. Not a single bug. But I'm not going to look and confirm that. Just have to take my word for it.
Riding it like I financed it.
Old July 30th, 2016, 10:28 AM   #18
snot
sammich maker
snot's Avatar
MOTM - Apr '15
A little wax also helps with removal.
I keep mine fairly clean with just a wet towel and fishing it through. It only takes a few minutes to remove the screen and clean it.
Old August 3rd, 2016, 05:09 PM   #19
3ØØ
3ØØ's Avatar
Motorcycle(s): '13 ninja 300
if you are too lazy to take the windscreen off to properly clean your bike, plasti dip the inside of it and you never have to see the bugs again
3ØØ is offline   Reply With Quote
Old August 4th, 2016, 11:09 AM   #20
Neanderthal
Motorcycle(s): Triumph Street Triple, Suzuki SV650S, Kawasaki Ninja 300
... It only takes a few minutes to remove the screen and clean it.
Unfortunately - some dumbass either over-tightened, or Loc-Tited the top screw @ each mirror bracket on my screen and I can't remove them. I have all sorts of good-quality tools, including Easy-Outs, and the damn screw heads just strip out. The only thing that I can think of next to try is to carve a slot in the head with a dremel to try to use a flat blade screwdriver to remove them.
Neanderthal is offline   Reply With Quote
Old August 4th, 2016, 12:11 PM   #21
snot
sammich maker
snot's Avatar
MOTM - Apr '15
A little heat might help. I can take pics later of how I fish the towel.
Old August 4th, 2016, 12:50 PM   #22
Neanderthal
Yepper, I already tried holding a both a heat gun and a soldering iron on it to no avail. Tried an impact driver too, no dice.
Old August 4th, 2016, 11:11 PM   #23
JohnnyBravo
Yikes... I hate working on stuff after a dumbass!
Old September 21st, 2016, 07:28 AM   #24
travellingtenor
travellingtenor's Avatar
Motorcycle(s): 2013 Kawasaki Ninja 300, 2001 Honda Goldwing, 1996 Honda Pacific Coast, 1994 Honda Magna 750
Winner Winner Chicken Dinner! That's exactly why there is a gap. Air will rush into a low pressure area and cause buffeting. Allowing air into the low pressure area evens out the pressure to neutral and provides a better airflow.
travellingtenor is offline   Reply With Quote
[motorcycle.com] - Stop Sale and Stop Ride Ordered for Polaris Slingshot Ninjette Newsbot Motorcycling News 0 January 20th, 2015 02:00 PM
Bugs on your face shield userjh160 General Motorcycling Discussion 59 September 30th, 2012 03:38 PM
Not bugs! akima Videos 10 April 4th, 2012 09:47 AM
Does anyone like bugs? JoeLansing Off-Topic 19 June 28th, 2011 05:21 PM
Got Bugs?! Yeeech! kkim General Motorcycling Discussion 34 January 18th, 2009 04:02 AM
