Old November 1st, 2016, 06:24 AM   #1
eulark
Motorcycle(s): 2003 Blue Ninja 250, 98 ZX6E, 06 ZX636
Front End Swap
I have a zx6e project I havent done much with in about a year, and I'm thinking about parting out or just slapping the motor in there finally and selling it. But something I was wondering was if I could swap the front end on my 03 250.
I have the whole front end, so handle bars, wheels, etc isnt a worry. But I've never done work on this area of the bike. My main concern is stem length and then getting the right bearings correct?
Thanks!
eulark is offline   Reply With Quote
Old November 1st, 2016, 10:16 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
assuming you could adapt the steering stem and bearings to the frame on the 250, you would then run into the issue of clearance between the forks and the inside of the fairings, the clipons and the top the fairings, and other associated fitment issues (lines, cables, etc.) It can be done but perhaps would require a significant amount of work (and maybe dollars) to complete and have factory finish.
Old November 1st, 2016, 10:31 AM   #3
eulark
Not worries about front fairing since wife seems to like the naked/street fighter look. And she'll be the primary rider on this eventually.
I havent had a chance to look at my manual yet, but does it state the bearing sizes and the stem length in there?
Old November 1st, 2016, 11:29 AM   #4
spent_too_much
spent_too_much's Avatar
The "All Balls" bearings website has an extensive guide for all kinds of swaps.
http://www.allballsracing.com/index.php/forkconversion
Old November 1st, 2016, 12:31 PM   #5
eulark
Thanks for that link! According to the site, these are the bearings I need for the conversion.
top: http://www.allballsracing.com/99-3509-5.html
bottom: http://www.allballsracing.com/99-3513-5.html
So what I really need to know is stem fitment I suppose. All the rest is workable.
Old November 4th, 2016, 03:43 PM   #6
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
All you need to know are the stock bearing sizes & the donor bike bearing sizes. The stem length can be measured as you have both to hand. Just stick a rod up the inside of the stem on the 250 to get a rough measure of its full length, then compare to the 600's !
Old November 4th, 2016, 06:09 PM   #7
eulark
Unfortunately I do not have both on hand. I'll have to see if I can get someone to measure one for me. At least the 250 one. I think I can pull my 6e one, the 250 I just got back on the road so I'm loath to pull it apart now. I need it rolling while I mess with my 6r.
But I think bearings are fine since the website up there had them listed.
Old November 5th, 2016, 12:19 AM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Old something or other did a front swap... You searched the forums for swaps yet?
Old November 5th, 2016, 01:42 AM   #9
Mohawk
Mohawk's Avatar
I thought you said you had a a 250 & the 600 parts ? Just get a rod & push it up the inside of the stem on the 250 they are hollow ! Mark & measure where it stops this will be the stem length. Compare to the 600, if they are close it will be fine.
You can find the bearings inner & outer diameter + thickness online.
I put a KR1-S frontend on my ZZR, so one bearing is ZZR the other is KR1-S !
Once you have the bearing sizes, you can buy seperate one from a bearing provider !
Old November 5th, 2016, 01:56 AM   #10
JohnnyBravo
636 fork swap stuff
https://www.ninjette.org/forums/showthread.php?t=102014
Old November 6th, 2016, 06:06 PM   #11
eulark
I did do a search, but I was specifically looking for 6e or other traditional forks. The 636 link is helpful. I'll keep digging.
Old November 6th, 2016, 06:22 PM   #12
JohnnyBravo
Idk if you will find that specific swap.. But there are a few swaps around. Some just in passing conversation, some in more detail. Best of luck
Old November 20th, 2016, 08:49 PM   #13
Petrolh34d
Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr
If you want a nice upgrade. 2008+ 250r front ends swap on easily. I actually installed ninja 300 springs in my pregen. Rides amazing!
Petrolh34d is offline   Reply With Quote
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
Gixxer front end swap nguyener 2008 - 2012 Ninja 250R Tech Talk 4 June 20th, 2013 01:53 PM
2011 front sprok swap eddiekay 2008 - 2012 Ninja 250R Tech Talk 2 July 12th, 2012 01:05 PM
15t front sprocket swap! play2pwn 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:17 AM
'86 Front End Swap? Roblas 1986 - 2007 Ninja 250R Tech Talk 2 June 21st, 2011 02:36 AM
