Old July 23rd, 2017, 02:07 PM   #1
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
'06 won't run when kickstand is down even in neutral
Something I'm missing? Something faulty? It's slightly annoying lol.
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old July 23rd, 2017, 02:23 PM   #2
A.J.
A.J.'s Avatar
Oh and if it's some kind of switch make sure and let me know where it's located so I can see the dumb thing. Nothing major just annoying.
Old July 23rd, 2017, 02:24 PM   #3
Does the starter crank the engine? Does pulling the clutch lever make a difference? Your kill switch is in the run position, right?
Old July 23rd, 2017, 07:31 PM   #4
A.J.
A.J.'s Avatar
Yep kill switch in run position. No engine doesn't crank it doesn't do anything like it's a safety feature that might be faulty. Need to check out an '06 owners manual perhaps and see how the thing operates. I mean I get how it's supposed to work but if she's in neutral then it shouldn't engage. You know what this makes no sense but I started the bike today while I was off of it. Did it a few times. So I'm thinking it's some kind of weight sensor that won't allow it to run with me on it and the kick stand down. I'll test this theory out tomorrow afternoon when I get off work. Pretty sure that's it.
Old July 23rd, 2017, 07:50 PM   #5
Maybe this has some answers for you - https://faq.ninja250.org/wiki/Unders...afety_switches
Old July 23rd, 2017, 08:06 PM   #6
A.J.
A.J.'s Avatar
Actually that helps and is really great info to have. Thank you. I'm gonna test out my theory that it's when I'm sitting on the bike. If I'm not on the bike she will run with the kick stand down and in neutral. And it makes sense since it's trying to protect me not neccesarily the bike. I'll know tomorrow afternoon.
Old July 23rd, 2017, 08:27 PM   #7
There is no seat switch. Maybe a wire with bare insulation shorting when you sit though.
Old July 23rd, 2017, 09:50 PM   #8
Yeah, your weight is loading up the kickstand differently than when you're off. The switch may not be aligned properly or is defective (or wiring).
Here's a test:
1. Unplug kickstand switch
2. Bend a paperclip into U-shape
3. Plug it to bridge two terminals on harness-side connector
4. Try starting with kickstand up, down, you on or off bike. Neat huh?
Old July 24th, 2017, 05:45 AM   #9
A.J.
A.J.'s Avatar
Here's a test:
A paper clip? Hell yes that's neat. lol
I'll give it a try when I get home and report back. Someone is selling their '06 636 on facebook and they have the exact same issue. Said I would check with you guys and give him an answer. Thanks man. Seems like it's somewhat of a common issue but no one really has an answer.
Ninja 250 no neutral light, goes into gear, won't move Deathjunior 1986 - 2007 Ninja 250R Tech Talk 12 April 11th, 2019 11:20 PM
Won't shift into neutral. Why? puma22 2008 - 2012 Ninja 250R Tech Talk 5 February 17th, 2013 10:39 AM
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE Jiggyfly 2008 - 2012 Ninja 250R Tech Talk 5 May 16th, 2012 09:50 AM
Laid it down in dirt (right)-now only starts in neutral: NOT kickstand sensor/switch! CZroe 2008 - 2012 Ninja 250R Tech Talk 16 September 7th, 2011 04:00 AM
2007 won't start, not even getting neutral or oil warning lights! davidfriend 1986 - 2007 Ninja 250R Tech Talk 13 May 6th, 2011 09:51 PM
