Old May 24th, 2022, 04:50 PM   #1
[webbikeworld.com] - 2022 Ducati Diavel 1260 & Diavel 1260S [Specs, Features, Photos]
Click here for full story...
The 2022 Ducati Diavel 1260: Powerful and Muscular
Contents
Ducati’s coveted Diavel has always been somewhat of the ‘Lamborghini’ of their esteemed lineup. Heck, they even did a collaboration with Lamborgini on a previous version of the Diavel. Its extreme looks paired with its torque-focused performance capabilities brings something fresh to the Ducati lineup, and it has managed to stay fresh since it first hit the scene in 2010.
If you’re familiar with Ducati’s most popular model – the Monster – the best way to explain the Diavel to someone who hasn’t seen it before would be to liken it to a Monster that has been fed human growth hormone (or some motorcycle-based variant). To be frank, the thing is jacked. Italians may not be too keen on American football, but the Diavel 1260 is the prototype for an all-star linebacker. The exotic and muscley appearance alone gives it a one-of-a-kind aesthetic that is completely unique to the Diavel family heritage. The unique look paired with its spec sheet combines for a truly special riding experience.
The steel trellis frame and oversized fuel tank perfectly “frames” (pardon the pun) the masterpiece of a Testastretta DVT 1,262cc engine capable of laying down a hot 155 horsepower to its oversized 240mm rear tire thanks to its ride-by-wire system and three rider modes.
As with the majority of expensive Italian motorcycles, the Diavel 1260 comes fully loaded with any and every electronic riding aid you could ever need (ABS, TC, wheelie control, etc). The Italian motorcycle manufacturer’s 2022 lineup also brings the Diavel 1260 in two variants: the ‘standard’ 1260, and an ‘S’ version to top it off.
For some extra spice (and extra coin), the ‘S’ version of the 1260 comes with some aesthetic changes such as gold finishing on the front forks, a special colorway, and some other key performance parts.
Although both models feature a 3.5 inch TFT instrument cluster, the ‘S’ comes with Ducat’s Multimedia System (DMS) which allows for hands-free calling and navigation on the roads. A quick-shifter paired with an Ohlins 48mm adjustable front fork allows for a weight difference of 4 lbs when compared to the standard version, but beyond that small sliver of weight being shed the bikes still remain virtually identical on the spec sheets.
The 2022 Ducati Diavel 1260 starts at $20,295 USD / $ 26,695 CAD.
The 2022 Ducati Diavel 1260S starts at $23,395 USD / $28,195 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Diavel 1260 in one place.
Model Overview
</p>General Info
  • Price: Starting at $20,295 USD / $26,695 CAD
  • Key Features:
    • Styling completely unique to the Diavel
    • Testastretta DVT 1,262cc L-Twin engine
    • ‘S’ edition with performance and aesthetic upgrades
Main Specs
  • Engine: 1,262cc L-Twin
  • Power: 157 HP
  • Torque: 95 lbs-ft at the crank
  • Wet Weight: 549 lb (249 kg)
  • Seat Height: 30.7* inches (780 mm) at lowest point
Competitors
2022 Ducati Diavel 1260 & Diavel 1260S Specifications
ENGINE
Engine1262cc, Ducati Testastretta DVT 1262, L-Twin cylinder, 4 valves per cylinder, Dual Spark, Liquid cooled, Desmodromic Variable TimingPower162 HPBore x Stroke106 x 71.5 mmCompression Ratio13.0 : 1Fuel InjectionBosch electronic fuel injection system, Øeq 56 mm elliptical throttle bodies with Ride-by-Wire system.StarterElectricExhaustStainless steel muffler, catalytic converter and 2 lambda probesTorque13.2 kgm (129 Nm, 95 lb ft) @ 7,500 rpmDRIVETRAIN
ClutchSlipper and self-servo wet multiplate clutch with hydraulic controlTransmission6 speedFinal DriveChain, Front sprocket Z15, Rear sprocket Z43CHASSIS
Suspension Front*Ø 50 mm adjustable usd forkSuspension RearMonoshock, preload and rebound adjustable, Aluminium casted single-sided swingarmBrakes Front2 x Ø 320 mm semifloating discs, radial mounted Brembo monobloc 4-piston M4.32 callipers, PR18/19 radial master cylinder, Cornering ABSBrakes RearØ 265 mm disc, Brembo 2-piston floating calliper, Cornering ABSTires FrontPirelli Diablo Rosso III 120/70 ZR17Tires RearPirelli Diablo Rosso III 240/45 ZR17Fuel Tank Capacity17 l (4.5 US Gal)** ** 16 l (4.2 US Gal) for US/Canada/Mexico versionColorDark StealthELECTRICAL
IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS
Max LengthMax WidthMax heightWheelbase1,600 mm (63.0 in)Rake27°Trail120 mm (4.7 in)Seat Height780 mm (30.7 in)Dry Weight223 kg (487 lbWARRANTY
Warranty24 months, Unlimited mileageExtension
2022 Ducati Diavel 1260 & Diavel 1260S Features
Design
A contemporary character
Muscular lines and an imposing front bring out the strong and restless personality of the new Diavel, featuring a long, slender rear with a 240 mm rear wheel. The S version with the distinctive golden Öhlins suspensionsis the maximum expression of the decisive and refined style of the Diavel 1260. A new sporty Diavel 1260 S, without sacrificing the style that distinguishes it.
Black and Steel
The Diavel 1260 S “Black and Steel” is inspired by the Diavel “Materico” concept, presented to the public in 2019 at the “Beautiful Boldness / Visionary Design” event during Milan Design Week and subsequently exhibited at the MOARD (Motorcycle Art & Design) exhibition dedicated to two-wheel design.
Engine
The engine is the king
The new Diavel is built around the Testastretta DVT 1262 engine, a beacon of power, beauty and sophistication. Its 162 hp translate to unbelievable acceleration and pick-up, while the flat and consistent torque curve since low rpm allows steady and easy to handle delivery. The Ride by Wire (RbW) control matched with three Riding Modes and three Power Modes allows to personalise engine responsiveness. A true beauty, as far as mechanics and design go, and a real game changer on the road.
Ergonomics
Riding pleasure at its best
Sportiness and comfort meet in the new Diavel. The trellis frame ensure lightness and torsional rigidity, while the adjustable fork provides comfort and stability. The care devoted to ergonomics is complemented by the perfect combination of a higher handlebar, a lower seat and central footpegs, with a comfortable and versatile riding position. The S version is fitted with Öhlins suspensions, for a guaranteed fun and an exciting riding experience.
Details
Cheeky elegance
The new Diavel is an ode to elegance and sophisticated details: carbon fibre components and a finely stitched premium quality seat complement the Diavel’s outstanding style. An aggressive character, with no compromises, as Marchesini forged rims and the Thrilling Black & Dark Stealth liveries testify. The Daytime Running Light (DRL) headlight, available on the S version, is an unmistakeable hallmark of the new Diavel.
2022 Ducati Diavel 1260 & Diavel 1260S Photos
2022 Ducati Diavel 1260 & Diavel 1260S Videos
2022 Ducati Diavel 1260 S “Black and Steel” // First Impression
Triumph Rocket III R vs Ducati Diavel 1260 S | Drag Race
Links
Ducati Motorcycle Official Websites
Social Media Links
The post 2022 Ducati Diavel 1260 & Diavel 1260S [Specs, Features, Photos] appeared first on webBikeWorld.
Old May 24th, 2022, 05:57 PM   #2
It is purty. But $24K for what's essentially a naked bike is quiet steep!
Old May 30th, 2022, 08:26 AM   #3
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Yes 100%, Ducati can definitely design a gorgeous bike. No Duc in my garage for at least 5 years lol.
jcgss77 is offline   Reply With Quote
[webbikeworld.com] - 2022 Ducati DesertX [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 19th, 2022 02:12 PM
[webbikeworld.com] - The Ducati Diavel 1260 Lamborghini Touches Down on the Tarmac Ninjette Newsbot Motorcycling News 0 November 25th, 2020 02:02 PM
[webbikeworld.com] - 2020 Ducati Diavel 1260 / 1260 S [Model Overview] Ninjette Newsbot Motorcycling News 0 April 11th, 2020 12:31 PM
[RoadRUNNER] - 2019 Ducati Diavel 1260 S: Diavel at the Crossroads Ninjette Newsbot Motorcycling News 0 December 19th, 2019 06:17 AM
[webbikeworld.com] - Ducati Starts Production of the Diavel 1260 in Bologna Ninjette Newsbot Motorcycling News 0 January 22nd, 2019 06:00 AM
