Old July 2nd, 2022, 10:30 AM   #1
[webbikeworld.com] - 2022 Kawasaki Ninja 400 ABS [Specs, Features, Photos]
Click here for full story...
The 2022 Kawasaki Ninja 400 ABS: Welcome to Your Ninja Training
Contents
The Kawasaki Ninja 400 ABS comes up pretty often in listicles of the best beginner sport bikes, and with good reason. While you certainly wouldn’t want to start your riding career on a Ninja H2 (unless you want it to be short and end painfully), this smaller and more approachable Ninja makes an excellent starter sport bike that can still propel you around the track at a decent clip.
Kawasaki loves to over-engineer their sport bikes, but they’ve focused on the fundamentals for the Ninja 400 ABS—like the compact 399cc parallel-twin engine that purrs away between your legs as you ride, providing 49 hp @ 10500 rpm and 28.0 lb-ft of torque @ 8000 rpm. The bike also has a lightweight trellis frame, which means you’ll never feel like you’ve got to lug it around corners or curves. There are no major upgrades from last year’s version for 2022, other than new colors.
An assist & slipper clutch, economical riding indicator, and Kawasaki’s ergo-fit technology all help make this a user-friendly bike for riders of many shapes, sizes, and experience levels. No, it’s not going to help Kawi pull ahead of the other big Japanese bike brands in terms of sheer performance—but it might help them capture a larger chunk of the growing market for new motorcyclists, and it will certainly hold its own against rivals like the Suzuki GSX 250R and the Yamaha YZF R3.
This year’s Ninja 400 ABS makes an admirable and approachable addition to the 2022 Kawasaki motorcycle lineup. It comes in Metallic Carbon Gray/Metallic Flat Spark Black and starts at $5,599 USD / $6,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Ninja 400 ABS in one place.
Model Overview
</p> General Info
  • Price: $5,599 USD / $6,599 CAD
  • Key Features:
    • Assist & slipper clutch
    • Economical riding indicator
    • Ergo-fit technology
    • Lightweight trellis frame
Main Specs
  • Engine: 399cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
  • Power: 49 hp @ 10500 rpm
  • Torque: 28.0 lb-ft of torque @ 8000 rpm
  • Dry Weight: 366 lbs (166kg)
  • Seat Height: 30.9 inches (785 mm)
Competitors
2022 Kawasaki Ninja 400 ABS Specifications
ENGINE
Engine 399cc, 4-stroke, Parallel Twin, DOHC, liquid-cooled Power 49 Hp Bore x Stroke 70.0 x 51.8mm Compression Ratio 11.5:1
Fuel System DFI® with dual 32mm throttle bodies Starter Electric Electronic Rider Aids ABS DRIVETRAIN
Clutch Transmission 6-speed, Manual, Return Shift, Dog Ring Final Drive Sealed chain CHASSIS
Suspension Front 41mm hydraulic telescopic fork/4.7 in Suspension Rear Horizontal back-link with adjustable spring preload/5.1 in Brakes Front Single 310mm semi-floating petal-type disc with 2-piston calipers and ABS Brakes Rear Single 220mm petal-type disc with single-piston caliper and ABS
Tires Front 110/70-17 Tires Rear 150/70-17 Fuel Tank Capacity 3.7 gal Color Metallic Matte Twilight Blue/Metallic Graphite Gray, Metallic Carbon Gray/Metallic Flat Spark Black
ELECTRICAL
Ignition TCBI w/Digital Advance Spark Plugs Headlight LED Tail Light LED DIMENSIONS
Overall Length 78.3 in Overall Width 28 in Overall Height 44.1 in Wheelbase 53.9 in Ground Clearance 5.5 in Seat Height 30.9 in Curb Weight 366* WARRANTY
Warranty 12 Months Kawasaki Protection Plus 12, 24, or 36 months
2022 Kawasaki Ninja 400 ABS Features
Assist & Slipper Clutch
Based on feedback from racing activities, the Assist & Slipper Clutch uses two types of cams (an assist cam and a slipper cam) to either drive the clutch hub and operating plate together or apart.
Under normal operation, the assist cam functions as a self-servo mechanism, pulling the clutch hub and operating plate together to compress the clutch plates. This allows the total clutch spring load to be reduced, resulting in a lighter clutch lever feel when operating the clutch.
When excessive engine braking occurs – as a result of quick downshifts (or an accidental downshift) – the slipper cam comes into play, forcing the clutch hub and operating plate apart. This relieves pressure on the clutch plates to reduce back-torque and helps prevent the rear tire from hopping and skidding. This race-style function is particularly useful when sport or track riding.
Economical Riding Indicator
Using high-precision electronic control for engine management, Kawasaki models can achieve a high level of fuel efficiency. However, fuel consumption is greatly affected by throttle use, gear selection, and other elements under the rider’s control. The Economical Riding Indicator is a function that indicates when current riding conditions are consuming a low amount of fuel. The system continuously monitors fuel consumption, regardless of vehicle speed, engine speed, throttle position and other riding conditions. When fuel consumption is low for a given speed (i.e. fuel efficiency is high), an “ECO” mark appears on the instrument panel’s LCD screen. By riding so that the “ECO” mark remains on, fuel consumption can be reduced.
While effective vehicle speed and engine speed may vary by model, paying attention to conditions that cause the “ECO” mark to appear can help riders improve their fuel efficiency – a handy way to increase cruising range. Further, keeping fuel consumption low also helps minimize negative impact on the environment.
ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.
ERGO-FIT
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.
ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
2022 Kawasaki Ninja 400 ABS Photos
2022 Kawasaki Ninja 400 ABS Videos
2022 KAWASAKI NINJA 400 | WHAT’S NEW?
2022 Kawasaki Ninja 400 First Ride | REVIEW
Links
Kawasaki Official Websites
Social Media Links
The post 2022 Kawasaki Ninja 400 ABS [Specs, Features, Photos] appeared first on webBikeWorld.
Old July 5th, 2022, 04:27 PM   #2
Bump!
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-14R [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 July 2nd, 2022 10:14 AM
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-6R [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 July 2nd, 2022 10:03 AM
[webbikeworld.com] - 2022 Kawasaki Ninja H2 SX SE [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 24th, 2022 04:53 PM
[webbikeworld.com] - 2022 Kawasaki Ninja H2 [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 June 24th, 2022 04:41 PM
[webbikeworld.com] - 2022 Honda CB650R ABS [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 05:14 AM
