Old May 8th, 2010, 08:42 PM   #1
Cab305
Cab305's Avatar
Motorcycle(s): Blue 10 250r
GP gear shifting
Is it possible to set factory rear set for GP, or do I have to wait till I buy aftermarket? If poss. how complicated is it to change?
If someone can explain I'll attempt a DIY thread.
Maybe
Cab305 is offline   Reply With Quote
Old May 9th, 2010, 12:42 AM   #2
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
Maybe
Yes you can. But you will need to trim away a recess on the sprocket cover. http://www.kawiforums.com/ninja-250r...ml#post1488196
Here's a link to a thread on this http://www.kawiforums.com/ninja-250r...-rearsets.html
Old May 9th, 2010, 12:48 AM   #3
Haider87
Learning by doing
Haider87's Avatar
Motorcycle(s): '08 Ninja 250R
Well.. if you take a look at the gear shift lever(im going off of memory) it is attached by a rod to the footpeg. essentially one could flip the arm for the shift lever and attach the rod so the footpeg shifts register backwards... Ill draw a pic of what I mean, just theoretically right now. Ill take a look at my bike later on and see if this can be done easily.
Hope this makes any sense.
Haider87 is offline   Reply With Quote
Old May 9th, 2010, 12:49 AM   #4
Haider87
Learning by doing
Haider87's Avatar
Hahah kewl! Thnx crx..
Pats self on back
Old May 9th, 2010, 01:02 AM   #5
kawiwut????
http://www.ninjette.org/forums/showthread.php?t=17797&
Old May 9th, 2010, 01:04 AM   #6
CRXTrek
CRXTrek's Avatar
Old May 9th, 2010, 05:46 AM   #7
Thrak
Motorcycle(s): Lots
Thrak is offline   Reply With Quote
Old May 9th, 2010, 04:49 PM   #8
Key007
Ride Rain or Shine
Key007's Avatar
Motorcycle(s): '09 Ninja 250
What are the advantages of GP style of shifting? Is it faster to change gears when you push down to gear up?
The Optimist says the cup is half full
The Pessimist says the cup is half empty
The Engineer says the cup is twice the size it needs to be.
Key007 is offline   Reply With Quote
Old May 9th, 2010, 04:54 PM   #9
Haider87
Learning by doing
Haider87's Avatar
Yeah, faster upshifting.
For me the big shot would be the ability to turn with my left foot sitting above the lever instead of beneath it.
Old May 9th, 2010, 06:09 PM   #10
Thrak
Motorcycle(s): Lots
Its also better for your trans, you have alot more force pressing down on the pedal then pulling up which makes for a more positive shift.
Weird noise when shifting to first gear Animoto 2008 - 2012 Ninja 250R Tech Talk 29 June 27th, 2014 11:07 AM
shifting robertkh100 Riding Skills 13 June 11th, 2012 07:26 AM
2011 Ninja 250R Strange Gear Shifting Greyfox General Motorcycling Discussion 3 January 30th, 2012 07:13 AM
Gear-shifting problem Anthony_marr General Motorcycling Discussion 16 March 28th, 2011 09:07 PM
Shifting haligen 2008 - 2012 Ninja 250R Tech Talk 3 October 23rd, 2009 05:31 PM
